Is it dangerous to use return; inside loop()?
Hi everyone, I'm writing a new piece of code and I'm trying to avoid using nested if() statements to help readability. For example, when creating functions, I avoid this:
void myFunction(int var){
  //if var is positive, execute myFunction()
  if(var > 0){
    //execute all of myFunction() inside if() statement, could lead to nested if statements!
  return;
in favour of this:
  //if var is not positive, return, i.e. don't execute myFunction()
  if(var <= 0)
    return;
  //execute all of myFunction(), except this time we're not inside a big if() statement!
  return;
plus I've also been told by a friend who's a software developer/programmer that it's good practice to avoid nesting if() statements.
This is fine for functions, but for the Arduino loop statement, I was wondering if I could do the same. I'm aware that the main.c file has defined the main() function in Arduino as:
int main(void)
	init();
	initVariant();
#if defined(USBCON)
	USBDevice.attach();
#endif
	setup();
	for (;;) {
		loop();
		if (serialEventRun) serialEventRun();
	return 0;
so I know that if I return from loop(); then it will just execute again as it is inside an endless for(;;) loop. so, for example, when I run this code:
bool someVariable = false;
void setup(){
  Serial.flush();
void loop(){
  Serial.println(F("Hello!"));
  if(!someVariable)
    return;
  Serial.println(F("Hi!"));
the only message I see in the Serial monitor is "Hello", and the Serial.println(F("Hi!")); will never execute due to the if() statement.
So, my questions are, am I correct in how I have described the way the final code will run? and if so, is it bad practice or potentially dangerous to rely on return; inside loop()?
If you want to quit any function immediately and return to where it was called then you use return;
loop() is just a function called from main() and as such it is legitimate to return; from it and have it called again from the start
of course not
void loop ()
    if (! Serial.available ())
        return;
As a fun bonus, if someVariable is static or const the compiler will eliminate the if and the second println because it's dead code.
ah cool! that's cool that the compiler actually figures out how a code will run, I thought it just eliminated functions and variables that were never used
But only to a limited extent. It can not grasp semantics, only look for definite patterns that have easily predictable outcomes. Here there is no magic, though - surely if it can eliminate a function, it can eliminate a code block.
A logical test of a constant value, is a pretty easy thing to detect, if you see what I mean...
