Hi, im making MP3 player, with some buttons, potentiometer and a speaker.
I dont want to use batteries for it, I think it could be to expensive over time.
So Im using a 9v 1 Amp DC adapter, and the case is made with a MDF 5mm with a Laser Cut especially for this project.
Could this be a problem if some part heat to much and a start a fire?
Paul_KD7HB:
If you have parts that get too hot, you already have problems with your project. Fix that before you put anything into a box.
Paul
Well the project is like this:
I dont know too much about electronic, so I think a 9v 1amp adapter coul be less risky than a 12v that maybe heat much more than a 9v.
Do you think that any of these parts could heat in normal situations?
larryd:
A thin wire carrying 1 Amp can cause a fire.
It is your responsibility to have components run at cool temperatures.
Hey thanks for your response. After the 9v from the adapter enter to the arduino uno, I use the 5v pin.
what wire do you recomend for this kind of project?
Are you proposing to put the 9 V adapter in the MDF box? If so, why?
Why would you use a 9 V adapter? The Arduino runs on 5 V, not 9. A UNO has a fairly useless regulator on-board and the references misleadingly suggest it is usable to power it from 9 V. In fact, it is far better to use a common USB "phone charger" providing the necessary regulated 5 V and if your current draw is less than 400 mA, then it just plugs into the USB connector.
The "phone charger" does not need to be in the MDF box - it just plugs into the power socket.
No, the adapter is 9v 1 amp external, like this:
Should I use a regular phone charger with 5v 500mah?
