is the ethernet shield compatible with the arduino fio?
hi,
Is the ethernet shield v2.0 compatible with the arduino fio? and can I use arduino uno and fio simultaneously with the ethernet shield?
I'm working on a monitoring system project, I need to assign to each arduino an IP address, I will program the uno to read from the sd card through the browser, and want to program the fio to send wirelessly a readings from some sensors to the ethernet shield and view the results on the browser with different IP address than the one assigned for the uno.
but the problem that until now I couldn't even let the fio work alone with the shield.
this is a sample code I want to program the arduino fio with, but i couldn't get the readings on the browser, even that when i use the same code on the uno it will work without any problems...
any help guys? Thanks :slight_smile:
#include <SPI.h>
#include <Ethernet.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192,168,2,154);
// Initialize the Ethernet server library
// with the IP address and port you want to use
// (port 80 is default for HTTP):
EthernetServer server(80);
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
// start the Ethernet connection and the server:
Ethernet.begin(mac, ip);
server.begin();
Serial.print("server is at ");
Serial.println(Ethernet.localIP());
// listen for incoming clients
if (client) {
Serial.println("new client");
// an http request ends with a blank line
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) {
char c = client.read();
Serial.write(c);
// if you've gotten to the end of the line (received a newline
// character) and the line is blank, the http request has ended,
// so you can send a reply
if (c == '\n' && currentLineIsBlank) {
// send a standard http response header
client.println("Content-Type: text/html");
client.println("Connnection: close");
client.println();
client.println("");
client.println("");
// add a meta refresh tag, so the browser pulls again every 0.5 seconds:
client.println("<meta http-equiv="refresh" content="0.5">");
// output the value of each analog input pin
for (int analogChannel = 0; analogChannel < 6; analogChannel++) {
int sensorReading = analogRead(analogChannel);
client.print("analog input ");
client.print("");
client.print(analogChannel);
client.println("
client.print(" is ");
client.print("");
client.print(sensorReading);
client.println("
client.println("
client.println("");
if (c == '\n') {
// you're starting a new line
else if (c != '\r') {
// you've gotten a character on the current line
currentLineIsBlank = false;
// give the web browser time to receive the data
delay(2);
// close the connection:
client.stop();
Serial.println("client disonnected");
