Is there a way to check if nRF24L01 module is working?
This transceiver module is supposed to work on 3.3v but I unknowingly connected it to 5v.
It worked when I first started using it. I wouldn't keep it continuously powered on. But it doesn't seem to work now. Even when I connect it to 3.3v.
I am using Nano as transmitter and UNO as reciever.
Following THIS guide
Connections: HERE
Library I used: GitHub - nRF24/RF24: OSI Layer 2 driver for nRF24L01 on Arduino & Raspberry Pi/Linux Devices
Code is attached.
Nothing appears on the serial monitor of receiver.
Is the problem with the code or connection or did I burn my module and should get a new one?
wireless_Tx.ino (428 Bytes)
wireless_Rx.ino (438 Bytes)
Get a new one.
They are cheap and you will have a known good module to test with
Have a look at this Simple nRF24L01+ Tutorial.
It includes an example to test communication between the Arduino and its nRF24.
As @UKHeliBob has said you really need some spare nRF24s.
...R
