Hello, I can't get my nRF24 modules to work, I know it is not the modules because I have bought more modules and they are also not working. These are my connections. GND - gnd, VCC - 3.3V, CE - 5, CSN - 10, SCK - 13, MOSI - 11, MISO - 12. I have also tried switching CE to 7 and CSN to 8 but no success. I am using the code from Robin2.
TRANSMITTER
// SimpleTx - the master or the transmitter
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
#include <printf.h>
#define CE_PIN 5
#define CSN_PIN 10
const byte slaveAddress[5] = {'R','x','A','A','A'};
RF24 radio(CE_PIN, CSN_PIN); // Create a Radio
char dataToSend[10] = "Message 0";
char txNum = '0';
unsigned long currentMillis;
unsigned long prevMillis;
unsigned long txIntervalMillis = 1000; // send once per second
printf_begin();
Serial.println("SimpleTx Starting");
radio.begin();
radio.setDataRate( RF24_250KBPS );
radio.setRetries(3,5); // delay, count
radio.openWritingPipe(slaveAddress);
currentMillis = millis();
if (currentMillis - prevMillis >= txIntervalMillis) {
send();
prevMillis = millis();
void send() {
radio.stopListening();
bool rslt;
rslt = radio.write( &dataToSend, sizeof(dataToSend) );
// Always use sizeof() as it gives the size as the number of bytes.
// For example if dataToSend was an int sizeof() would correctly return 2
Serial.print("Data Sent ");
Serial.print(dataToSend);
if (rslt) {
Serial.println(" Acknowledge received");
updateMessage();
else {
Serial.println(" Tx failed");
void updateMessage() {
// so you can see that new data is being sent
txNum += 1;
if (txNum > '9') {
txNum = '0';
dataToSend[8] = txNum;
RECIEVER
// SimpleRx - the slave or the receiver
#include <SPI.h>
#include <RF24.h>
#define CE_PIN 5
#define CSN_PIN 10
const byte thisSlaveAddress[5] = {'R','x','A','A','A'};
char dataReceived[10]; // this must match dataToSend in the TX
bool newData = false;
Serial.println("SimpleRx Starting");
radio.begin();
radio.openReadingPipe(1, thisSlaveAddress);
radio.startListening();
getData();
showData();
void getData() {
if ( radio.available() ) {
radio.read( &dataReceived, sizeof(dataReceived) );
newData = true;
void showData() {
if (newData == true) {
Serial.print("Data received ");
Serial.println(dataReceived);
newData = false;
I am also using the library from Robin2's nRF24 demo.
I have the VCC connected to 3.3V and I have checked that my Arduino gives of 3.3V. When I run the SimpleTx code I get "Data Sent Message 0 Tx failed" in the Serial Monitor. When I run the SimpleRx code I get "Data received" in the Serial Monitor. I do not get any message in the Arduino logs other than "avrdude done. Thank you." so I guess there are no syntax problems. If you could help me out I would greatly appreciate it. Thanks in Advance :). I used this library - https://tmrh20.github.io/RF24/ and I got the code from here - Simple nRF24L01+ 2.4GHz transceiver demo - Exhibition / Gallery - Arduino Forum
Thanks for the reply, I tried the check connection code and I am getting this
CheckConnection Starting
FIRST WITH THE DEFAULT ADDRESSES after power on
Note that RF24 does NOT reset when Arduino resets - only when power is removed
If the numbers are mostly 0x00 or 0xff it means that the Arduino is not
communicating with the nRF24
I too was having trouble with the NRF24L01+ modules and it all boiled down to incorrect wiring and poor connections with the fly leads (especially with a breadboard). Check and check again. One of them is working so you know the script is good on that arduino; try swapping the NRF24’s and see if the same arduino still works. If it does that shows the NRF24’s are ok.
