Hey guys,
I am new to circuitry and I need help verifying if my circuit is right according to a wiring diagram. The circuit is for a weight scale with the HX711 ADC amplifier.
Please refer to the following link for the project on Instructables. Please see the attached schematic and code that allows one to calibrate the sensor. I am supposed to get a relevant weight reading but all I get are zeros
. At this stage, I load the sensor with a known weight, and all i get is zeros.
I've posted this before, however i was advised to re-submit with a schematic of what I did.
I am unfortunately a noob at this, but hoping I can get some help and advice from experts like you all.
Kind Regards
V
Setup your scale and start the sketch WITHOUT a weight on the scale
Once readings are displayed place the weight on the scale
Press +/- or a/z to adjust the calibration_factor until the output readings match the known weight
Arduino pin 6 -> HX711 CLK
Arduino pin 5 -> HX711 DOUT
Arduino pin 5V -> HX711 VCC
Arduino pin GND -> HX711 GND
#include "HX711.h"
HX711 scale(5, 6);
float calibration_factor = 48100; // this calibration factor is adjusted according to my load cell
float units;
float ounces;
Serial.println("HX711 calibration sketch");
Serial.println("Remove all weight from scale");
Serial.println("After readings begin, place known weight on scale");
Serial.println("Press + or a to increase calibration factor");
Serial.println("Press - or z to decrease calibration factor");
scale.set_scale();
scale.tare(); //Reset the scale to 0
long zero_factor = scale.read_average(); //Get a baseline reading
Serial.print("Zero factor: "); //This can be used to remove the need to tare the scale. Useful in permanent scale projects.
Serial.println(zero_factor);
scale.set_scale(calibration_factor); //Adjust to this calibration factor
Serial.print("Reading: ");
units = scale.get_units(), 10;
if (units < 0)
units = 0.00;
ounces = units * 0.035274;
Serial.print(units);
Serial.print(" kg");
Serial.print(" calibration_factor: ");
Serial.print(calibration_factor);
if(Serial.available())
char temp = Serial.read();
if(temp == '+' || temp == 'a')
calibration_factor += 1;
else if(temp == '-' || temp == 'z')
calibration_factor -= 1;
