Issue compiling BleKeyboard.h
I am trying to compile the ESP32 BLE Keyboard library.
ESP32-BLE-Keyboard
I followed the instructions to download the latest release zip file and used the library manager to install it.
name=ESP32 BLE Keyboard
version=0.3.0
author=T-vK
maintainer=T-vK
sentence=Bluetooth LE Keyboard library for the ESP32.
paragraph=Bluetooth LE Keyboard library for the ESP32.
category=Communication
url=https://github.com/T-vK/ESP32-BLE-Keyboard
architectures=esp32
The ESP32_BLE_Keyboard file is in my Libraries folder however a search using the library manager does not find it.
The board I'm using is a generic ESP32 DEV Board.
When I try to compile the "SendKeyStrokes" Example included I get the following output.
It seems excessive to me but I'm not sure what to expect.
The errors are beyond my limited knowledge of c++ programming...
Any help gratefully accepted. Thanks.
loading library from c:\Users\richa\OneDrive\Documents\Arduino\libraries\credentials: invalid library: no header files found
FQBN: esp32:esp32:esp32
Using board 'esp32' from platform in folder: C:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3
Using core 'esp32' from platform in folder: C:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3
cmd /c if exist "C:\\Users\\richa\\AppData\\Local\\Temp\\.arduinoIDE-unsaved2024620-27948-sobyxp.pw0n\\SendKeyStrokes\\partitions.csv" COPY /y "C:\\Users\\richa\\AppData\\Local\\Temp\\.arduinoIDE-unsaved2024620-27948-sobyxp.pw0n\\SendKeyStrokes\\partitions.csv" "C:\\Users\\richa\\AppData\\Local\\Temp\\arduino\\sketches\\2551584DA21E5CA062E8AEE6B0506FBC\\partitions.csv"
cmd /c if not exist "C:\\Users\\richa\\AppData\\Local\\Temp\\arduino\\sketches\\2551584DA21E5CA062E8AEE6B0506FBC\\partitions.csv" if exist "C:\\Users\\richa\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.3\\variants\\esp32\\partitions.csv" COPY "C:\\Users\\richa\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.3\\variants\\esp32\\partitions.csv" "C:\\Users\\richa\\AppData\\Local\\Temp\\arduino\\sketches\\2551584DA21E5CA062E8AEE6B0506FBC\\partitions.csv"
cmd /c if not exist "C:\\Users\\richa\\AppData\\Local\\Temp\\arduino\\sketches\\2551584DA21E5CA062E8AEE6B0506FBC\\partitions.csv" COPY "C:\\Users\\richa\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.3\\tools\\partitions\\default.csv" "C:\\Users\\richa\\AppData\\Local\\Temp\\arduino\\sketches\\2551584DA21E5CA062E8AEE6B0506FBC\\partitions.csv"
        1 file(s) copied.
cmd /c IF EXIST "C:\\Users\\richa\\AppData\\Local\\Temp\\.arduinoIDE-unsaved2024620-27948-sobyxp.pw0n\\SendKeyStrokes\\bootloader.bin" ( COPY /y "C:\\Users\\richa\\AppData\\Local\\Temp\\.arduinoIDE-unsaved2024620-27948-sobyxp.pw0n\\SendKeyStrokes\\bootloader.bin" "C:\\Users\\richa\\AppData\\Local\\Temp\\arduino\\sketches\\2551584DA21E5CA062E8AEE6B0506FBC\\SendKeyStrokes.ino.bootloader.bin" ) ELSE ( IF EXIST "C:\\Users\\richa\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.3\\variants\\esp32\\bootloader.bin" ( COPY "C:\\Users\\richa\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.3\\variants\\esp32\\bootloader.bin" "C:\\Users\\richa\\AppData\\Local\\Temp\\arduino\\sketches\\2551584DA21E5CA062E8AEE6B0506FBC\\SendKeyStrokes.ino.bootloader.bin" ) ELSE ( "C:\\Users\\richa\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esptool_py\\4.6\\esptool.exe" --chip esp32 elf2image --flash_mode dio --flash_freq 80m --flash_size 4MB -o "C:\\Users\\richa\\AppData\\Local\\Temp\\arduino\\sketches\\2551584DA21E5CA062E8AEE6B0506FBC\\SendKeyStrokes.ino.bootloader.bin" "C:\\Users\\richa\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-dc859c1e67\\esp32\\bin\\bootloader_qio_80m.elf" ) )
esptool.py v4.6
Creating esp32 image...
Merged 1 ELF section
Successfully created esp32 image.
cmd /c if exist "C:\\Users\\richa\\AppData\\Local\\Temp\\.arduinoIDE-unsaved2024620-27948-sobyxp.pw0n\\SendKeyStrokes\\build_opt.h" COPY /y "C:\\Users\\richa\\AppData\\Local\\Temp\\.arduinoIDE-unsaved2024620-27948-sobyxp.pw0n\\SendKeyStrokes\\build_opt.h" "C:\\Users\\richa\\AppData\\Local\\Temp\\arduino\\sketches\\2551584DA21E5CA062E8AEE6B0506FBC\\build_opt.h"
cmd /c if not exist "C:\\Users\\richa\\AppData\\Local\\Temp\\arduino\\sketches\\2551584DA21E5CA062E8AEE6B0506FBC\\build_opt.h" type nul > "C:\\Users\\richa\\AppData\\Local\\Temp\\arduino\\sketches\\2551584DA21E5CA062E8AEE6B0506FBC\\build_opt.h"
cmd /c type nul > "C:\\Users\\richa\\AppData\\Local\\Temp\\arduino\\sketches\\2551584DA21E5CA062E8AEE6B0506FBC/file_opts"
Detecting libraries used...
C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/defines -IC:\Users\richa\AppData\Local\Temp\.arduinoIDE-unsaved2024620-27948-sobyxp.pw0n\SendKeyStrokes -iprefix C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/include/ @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/includes -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/qio_qspi/include -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\cores\esp32 -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\variants\esp32 @C:\Users\richa\AppData\Local\Temp\arduino\sketches\2551584DA21E5CA062E8AEE6B0506FBC/build_opt.h @C:\Users\richa\AppData\Local\Temp\arduino\sketches\2551584DA21E5CA062E8AEE6B0506FBC/file_opts C:\Users\richa\AppData\Local\Temp\arduino\sketches\2551584DA21E5CA062E8AEE6B0506FBC\sketch\SendKeyStrokes.ino.cpp -o nul
Alternatives for BleKeyboard.h: [ESP32 BLE Keyboard@0.3.0]
ResolveLibrary(BleKeyboard.h)
  -> candidates: [ESP32 BLE Keyboard@0.3.0]
C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/defines -IC:\Users\richa\AppData\Local\Temp\.arduinoIDE-unsaved2024620-27948-sobyxp.pw0n\SendKeyStrokes -iprefix C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/include/ @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/includes -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/qio_qspi/include -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\cores\esp32 -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\variants\esp32 -Ic:\Users\richa\OneDrive\Documents\Arduino\libraries\ESP32_BLE_Keyboard @C:\Users\richa\AppData\Local\Temp\arduino\sketches\2551584DA21E5CA062E8AEE6B0506FBC/build_opt.h @C:\Users\richa\AppData\Local\Temp\arduino\sketches\2551584DA21E5CA062E8AEE6B0506FBC/file_opts C:\Users\richa\AppData\Local\Temp\arduino\sketches\2551584DA21E5CA062E8AEE6B0506FBC\sketch\SendKeyStrokes.ino.cpp -o nul
Alternatives for BLEHIDDevice.h: [BLE@3.0.3]
ResolveLibrary(BLEHIDDevice.h)
  -> candidates: [BLE@3.0.3]
C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/defines -IC:\Users\richa\AppData\Local\Temp\.arduinoIDE-unsaved2024620-27948-sobyxp.pw0n\SendKeyStrokes -iprefix C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/include/ @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/includes -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/qio_qspi/include -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\cores\esp32 -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\variants\esp32 -Ic:\Users\richa\OneDrive\Documents\Arduino\libraries\ESP32_BLE_Keyboard -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src @C:\Users\richa\AppData\Local\Temp\arduino\sketches\2551584DA21E5CA062E8AEE6B0506FBC/build_opt.h @C:\Users\richa\AppData\Local\Temp\arduino\sketches\2551584DA21E5CA062E8AEE6B0506FBC/file_opts C:\Users\richa\AppData\Local\Temp\arduino\sketches\2551584DA21E5CA062E8AEE6B0506FBC\sketch\SendKeyStrokes.ino.cpp -o nul
C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/defines -IC:\Users\richa\AppData\Local\Temp\.arduinoIDE-unsaved2024620-27948-sobyxp.pw0n\SendKeyStrokes -iprefix C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/include/ @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/includes -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/qio_qspi/include -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\cores\esp32 -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\variants\esp32 -Ic:\Users\richa\OneDrive\Documents\Arduino\libraries\ESP32_BLE_Keyboard -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src @C:\Users\richa\AppData\Local\Temp\arduino\sketches\2551584DA21E5CA062E8AEE6B0506FBC/build_opt.h @C:\Users\richa\AppData\Local\Temp\arduino\sketches\2551584DA21E5CA062E8AEE6B0506FBC/file_opts c:\Users\richa\OneDrive\Documents\Arduino\libraries\ESP32_BLE_Keyboard\BleKeyboard.cpp -o nul
C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/defines -IC:\Users\richa\AppData\Local\Temp\.arduinoIDE-unsaved2024620-27948-sobyxp.pw0n\SendKeyStrokes -iprefix C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/include/ @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/includes -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/qio_qspi/include -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\cores\esp32 -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\variants\esp32 -Ic:\Users\richa\OneDrive\Documents\Arduino\libraries\ESP32_BLE_Keyboard -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src @C:\Users\richa\AppData\Local\Temp\arduino\sketches\2551584DA21E5CA062E8AEE6B0506FBC/build_opt.h @C:\Users\richa\AppData\Local\Temp\arduino\sketches\2551584DA21E5CA062E8AEE6B0506FBC/file_opts C:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src\BLE2901.cpp -o nul
C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/defines -IC:\Users\richa\AppData\Local\Temp\.arduinoIDE-unsaved2024620-27948-sobyxp.pw0n\SendKeyStrokes -iprefix C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/include/ @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/includes -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/qio_qspi/include -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\cores\esp32 -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\variants\esp32 -Ic:\Users\richa\OneDrive\Documents\Arduino\libraries\ESP32_BLE_Keyboard -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src @C:\Users\richa\AppData\Local\Temp\arduino\sketches\2551584DA21E5CA062E8AEE6B0506FBC/build_opt.h @C:\Users\richa\AppData\Local\Temp\arduino\sketches\2551584DA21E5CA062E8AEE6B0506FBC/file_opts C:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src\BLE2902.cpp -o nul
C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/defines -IC:\Users\richa\AppData\Local\Temp\.arduinoIDE-unsaved2024620-27948-sobyxp.pw0n\SendKeyStrokes -iprefix C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/include/ @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/includes -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/qio_qspi/include -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\cores\esp32 -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\variants\esp32 -Ic:\Users\richa\OneDrive\Documents\Arduino\libraries\ESP32_BLE_Keyboard -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src @C:\Users\richa\AppData\Local\Temp\arduino\sketches\2551584DA21E5CA062E8AEE6B0506FBC/build_opt.h @C:\Users\richa\AppData\Local\Temp\arduino\sketches\2551584DA21E5CA062E8AEE6B0506FBC/file_opts C:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src\BLE2904.cpp -o nul
C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/defines -IC:\Users\richa\AppData\Local\Temp\.arduinoIDE-unsaved2024620-27948-sobyxp.pw0n\SendKeyStrokes -iprefix C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/include/ @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/includes -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/qio_qspi/include -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\cores\esp32 -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\variants\esp32 -Ic:\Users\richa\OneDrive\Documents\Arduino\libraries\ESP32_BLE_Keyboard -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src @C:\Users\richa\AppData\Local\Temp\arduino\sketches\2551584DA21E5CA062E8AEE6B0506FBC/build_opt.h @C:\Users\richa\AppData\Local\Temp\arduino\sketches\2551584DA21E5CA062E8AEE6B0506FBC/file_opts C:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src\BLEAddress.cpp -o nul
C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/defines -IC:\Users\richa\AppData\Local\Temp\.arduinoIDE-unsaved2024620-27948-sobyxp.pw0n\SendKeyStrokes -iprefix C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/include/ @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/includes -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/qio_qspi/include -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\cores\esp32 -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\variants\esp32 -Ic:\Users\richa\OneDrive\Documents\Arduino\libraries\ESP32_BLE_Keyboard -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src @C:\Users\richa\AppData\Local\Temp\arduino\sketches\2551584DA21E5CA062E8AEE6B0506FBC/build_opt.h @C:\Users\richa\AppData\Local\Temp\arduino\sketches\2551584DA21E5CA062E8AEE6B0506FBC/file_opts C:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src\BLEAdvertisedDevice.cpp -o nul
C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/defines -IC:\Users\richa\AppData\Local\Temp\.arduinoIDE-unsaved2024620-27948-sobyxp.pw0n\SendKeyStrokes -iprefix C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/include/ @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/includes -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/qio_qspi/include -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\cores\esp32 -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\variants\esp32 -Ic:\Users\richa\OneDrive\Documents\Arduino\libraries\ESP32_BLE_Keyboard -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src @C:\Users\richa\AppData\Local\Temp\arduino\sketches\2551584DA21E5CA062E8AEE6B0506FBC/build_opt.h @C:\Users\richa\AppData\Local\Temp\arduino\sketches\2551584DA21E5CA062E8AEE6B0506FBC/file_opts C:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src\BLEAdvertising.cpp -o nul
C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/defines -IC:\Users\richa\AppData\Local\Temp\.arduinoIDE-unsaved2024620-27948-sobyxp.pw0n\SendKeyStrokes -iprefix C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/include/ @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/includes -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/qio_qspi/include -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\cores\esp32 -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\variants\esp32 -Ic:\Users\richa\OneDrive\Documents\Arduino\libraries\ESP32_BLE_Keyboard -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src @C:\Users\richa\AppData\Local\Temp\arduino\sketches\2551584DA21E5CA062E8AEE6B0506FBC/build_opt.h @C:\Users\richa\AppData\Local\Temp\arduino\sketches\2551584DA21E5CA062E8AEE6B0506FBC/file_opts C:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src\BLEBeacon.cpp -o nul
C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/defines -IC:\Users\richa\AppData\Local\Temp\.arduinoIDE-unsaved2024620-27948-sobyxp.pw0n\SendKeyStrokes -iprefix C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/include/ @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/includes -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/qio_qspi/include -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\cores\esp32 -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\variants\esp32 -Ic:\Users\richa\OneDrive\Documents\Arduino\libraries\ESP32_BLE_Keyboard -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src @C:\Users\richa\AppData\Local\Temp\arduino\sketches\2551584DA21E5CA062E8AEE6B0506FBC/build_opt.h @C:\Users\richa\AppData\Local\Temp\arduino\sketches\2551584DA21E5CA062E8AEE6B0506FBC/file_opts C:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src\BLECharacteristic.cpp -o nul
C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/defines -IC:\Users\richa\AppData\Local\Temp\.arduinoIDE-unsaved2024620-27948-sobyxp.pw0n\SendKeyStrokes -iprefix C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/include/ @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/includes -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/qio_qspi/include -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\cores\esp32 -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\variants\esp32 -Ic:\Users\richa\OneDrive\Documents\Arduino\libraries\ESP32_BLE_Keyboard -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src @C:\Users\richa\AppData\Local\Temp\arduino\sketches\2551584DA21E5CA062E8AEE6B0506FBC/build_opt.h @C:\Users\richa\AppData\Local\Temp\arduino\sketches\2551584DA21E5CA062E8AEE6B0506FBC/file_opts C:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src\BLECharacteristicMap.cpp -o nul
C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/defines -IC:\Users\richa\AppData\Local\Temp\.arduinoIDE-unsaved2024620-27948-sobyxp.pw0n\SendKeyStrokes -iprefix C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/include/ @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/includes -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/qio_qspi/include -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\cores\esp32 -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\variants\esp32 -Ic:\Users\richa\OneDrive\Documents\Arduino\libraries\ESP32_BLE_Keyboard -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src @C:\Users\richa\AppData\Local\Temp\arduino\sketches\2551584DA21E5CA062E8AEE6B0506FBC/build_opt.h @C:\Users\richa\AppData\Local\Temp\arduino\sketches\2551584DA21E5CA062E8AEE6B0506FBC/file_opts C:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src\BLEClient.cpp -o nul
C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/defines -IC:\Users\richa\AppData\Local\Temp\.arduinoIDE-unsaved2024620-27948-sobyxp.pw0n\SendKeyStrokes -iprefix C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/include/ @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/includes -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/qio_qspi/include -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\cores\esp32 -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\variants\esp32 -Ic:\Users\richa\OneDrive\Documents\Arduino\libraries\ESP32_BLE_Keyboard -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src @C:\Users\richa\AppData\Local\Temp\arduino\sketches\2551584DA21E5CA062E8AEE6B0506FBC/build_opt.h @C:\Users\richa\AppData\Local\Temp\arduino\sketches\2551584DA21E5CA062E8AEE6B0506FBC/file_opts C:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src\BLEDescriptor.cpp -o nul
C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/defines -IC:\Users\richa\AppData\Local\Temp\.arduinoIDE-unsaved2024620-27948-sobyxp.pw0n\SendKeyStrokes -iprefix C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/include/ @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/includes -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/qio_qspi/include -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\cores\esp32 -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\variants\esp32 -Ic:\Users\richa\OneDrive\Documents\Arduino\libraries\ESP32_BLE_Keyboard -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src @C:\Users\richa\AppData\Local\Temp\arduino\sketches\2551584DA21E5CA062E8AEE6B0506FBC/build_opt.h @C:\Users\richa\AppData\Local\Temp\arduino\sketches\2551584DA21E5CA062E8AEE6B0506FBC/file_opts C:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src\BLEDescriptorMap.cpp -o nul
C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/defines -IC:\Users\richa\AppData\Local\Temp\.arduinoIDE-unsaved2024620-27948-sobyxp.pw0n\SendKeyStrokes -iprefix C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/include/ @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/includes -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/qio_qspi/include -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\cores\esp32 -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\variants\esp32 -Ic:\Users\richa\OneDrive\Documents\Arduino\libraries\ESP32_BLE_Keyboard -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src @C:\Users\richa\AppData\Local\Temp\arduino\sketches\2551584DA21E5CA062E8AEE6B0506FBC/build_opt.h @C:\Users\richa\AppData\Local\Temp\arduino\sketches\2551584DA21E5CA062E8AEE6B0506FBC/file_opts C:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src\BLEDevice.cpp -o nul
C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/defines -IC:\Users\richa\AppData\Local\Temp\.arduinoIDE-unsaved2024620-27948-sobyxp.pw0n\SendKeyStrokes -iprefix C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/include/ @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/includes -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/qio_qspi/include -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\cores\esp32 -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\variants\esp32 -Ic:\Users\richa\OneDrive\Documents\Arduino\libraries\ESP32_BLE_Keyboard -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src @C:\Users\richa\AppData\Local\Temp\arduino\sketches\2551584DA21E5CA062E8AEE6B0506FBC/build_opt.h @C:\Users\richa\AppData\Local\Temp\arduino\sketches\2551584DA21E5CA062E8AEE6B0506FBC/file_opts C:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src\BLEEddystoneTLM.cpp -o nul
C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/defines -IC:\Users\richa\AppData\Local\Temp\.arduinoIDE-unsaved2024620-27948-sobyxp.pw0n\SendKeyStrokes -iprefix C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/include/ @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/includes -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/qio_qspi/include -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\cores\esp32 -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\variants\esp32 -Ic:\Users\richa\OneDrive\Documents\Arduino\libraries\ESP32_BLE_Keyboard -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src @C:\Users\richa\AppData\Local\Temp\arduino\sketches\2551584DA21E5CA062E8AEE6B0506FBC/build_opt.h @C:\Users\richa\AppData\Local\Temp\arduino\sketches\2551584DA21E5CA062E8AEE6B0506FBC/file_opts C:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src\BLEEddystoneURL.cpp -o nul
C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/defines -IC:\Users\richa\AppData\Local\Temp\.arduinoIDE-unsaved2024620-27948-sobyxp.pw0n\SendKeyStrokes -iprefix C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/include/ @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/includes -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/qio_qspi/include -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\cores\esp32 -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\variants\esp32 -Ic:\Users\richa\OneDrive\Documents\Arduino\libraries\ESP32_BLE_Keyboard -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src @C:\Users\richa\AppData\Local\Temp\arduino\sketches\2551584DA21E5CA062E8AEE6B0506FBC/build_opt.h @C:\Users\richa\AppData\Local\Temp\arduino\sketches\2551584DA21E5CA062E8AEE6B0506FBC/file_opts C:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src\BLEExceptions.cpp -o nul
C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/defines -IC:\Users\richa\AppData\Local\Temp\.arduinoIDE-unsaved2024620-27948-sobyxp.pw0n\SendKeyStrokes -iprefix C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/include/ @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/includes -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/qio_qspi/include -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\cores\esp32 -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\variants\esp32 -Ic:\Users\richa\OneDrive\Documents\Arduino\libraries\ESP32_BLE_Keyboard -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src @C:\Users\richa\AppData\Local\Temp\arduino\sketches\2551584DA21E5CA062E8AEE6B0506FBC/build_opt.h @C:\Users\richa\AppData\Local\Temp\arduino\sketches\2551584DA21E5CA062E8AEE6B0506FBC/file_opts C:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src\BLEHIDDevice.cpp -o nul
C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/defines -IC:\Users\richa\AppData\Local\Temp\.arduinoIDE-unsaved2024620-27948-sobyxp.pw0n\SendKeyStrokes -iprefix C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/include/ @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/includes -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/qio_qspi/include -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\cores\esp32 -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\variants\esp32 -Ic:\Users\richa\OneDrive\Documents\Arduino\libraries\ESP32_BLE_Keyboard -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src @C:\Users\richa\AppData\Local\Temp\arduino\sketches\2551584DA21E5CA062E8AEE6B0506FBC/build_opt.h @C:\Users\richa\AppData\Local\Temp\arduino\sketches\2551584DA21E5CA062E8AEE6B0506FBC/file_opts C:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src\BLERemoteCharacteristic.cpp -o nul
C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/defines -IC:\Users\richa\AppData\Local\Temp\.arduinoIDE-unsaved2024620-27948-sobyxp.pw0n\SendKeyStrokes -iprefix C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/include/ @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/includes -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/qio_qspi/include -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\cores\esp32 -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\variants\esp32 -Ic:\Users\richa\OneDrive\Documents\Arduino\libraries\ESP32_BLE_Keyboard -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src @C:\Users\richa\AppData\Local\Temp\arduino\sketches\2551584DA21E5CA062E8AEE6B0506FBC/build_opt.h @C:\Users\richa\AppData\Local\Temp\arduino\sketches\2551584DA21E5CA062E8AEE6B0506FBC/file_opts C:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src\BLERemoteDescriptor.cpp -o nul
C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/defines -IC:\Users\richa\AppData\Local\Temp\.arduinoIDE-unsaved2024620-27948-sobyxp.pw0n\SendKeyStrokes -iprefix C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/include/ @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/includes -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/qio_qspi/include -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\cores\esp32 -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\variants\esp32 -Ic:\Users\richa\OneDrive\Documents\Arduino\libraries\ESP32_BLE_Keyboard -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src @C:\Users\richa\AppData\Local\Temp\arduino\sketches\2551584DA21E5CA062E8AEE6B0506FBC/build_opt.h @C:\Users\richa\AppData\Local\Temp\arduino\sketches\2551584DA21E5CA062E8AEE6B0506FBC/file_opts C:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src\BLERemoteService.cpp -o nul
C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/defines -IC:\Users\richa\AppData\Local\Temp\.arduinoIDE-unsaved2024620-27948-sobyxp.pw0n\SendKeyStrokes -iprefix C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/include/ @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/includes -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/qio_qspi/include -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\cores\esp32 -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\variants\esp32 -Ic:\Users\richa\OneDrive\Documents\Arduino\libraries\ESP32_BLE_Keyboard -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src @C:\Users\richa\AppData\Local\Temp\arduino\sketches\2551584DA21E5CA062E8AEE6B0506FBC/build_opt.h @C:\Users\richa\AppData\Local\Temp\arduino\sketches\2551584DA21E5CA062E8AEE6B0506FBC/file_opts C:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src\BLEScan.cpp -o nul
C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/defines -IC:\Users\richa\AppData\Local\Temp\.arduinoIDE-unsaved2024620-27948-sobyxp.pw0n\SendKeyStrokes -iprefix C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/include/ @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/includes -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/qio_qspi/include -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\cores\esp32 -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\variants\esp32 -Ic:\Users\richa\OneDrive\Documents\Arduino\libraries\ESP32_BLE_Keyboard -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src @C:\Users\richa\AppData\Local\Temp\arduino\sketches\2551584DA21E5CA062E8AEE6B0506FBC/build_opt.h @C:\Users\richa\AppData\Local\Temp\arduino\sketches\2551584DA21E5CA062E8AEE6B0506FBC/file_opts C:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src\BLESecurity.cpp -o nul
C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/defines -IC:\Users\richa\AppData\Local\Temp\.arduinoIDE-unsaved2024620-27948-sobyxp.pw0n\SendKeyStrokes -iprefix C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/include/ @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/includes -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/qio_qspi/include -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\cores\esp32 -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\variants\esp32 -Ic:\Users\richa\OneDrive\Documents\Arduino\libraries\ESP32_BLE_Keyboard -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src @C:\Users\richa\AppData\Local\Temp\arduino\sketches\2551584DA21E5CA062E8AEE6B0506FBC/build_opt.h @C:\Users\richa\AppData\Local\Temp\arduino\sketches\2551584DA21E5CA062E8AEE6B0506FBC/file_opts C:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src\BLEServer.cpp -o nul
C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/defines -IC:\Users\richa\AppData\Local\Temp\.arduinoIDE-unsaved2024620-27948-sobyxp.pw0n\SendKeyStrokes -iprefix C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/include/ @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/includes -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/qio_qspi/include -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\cores\esp32 -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\variants\esp32 -Ic:\Users\richa\OneDrive\Documents\Arduino\libraries\ESP32_BLE_Keyboard -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src @C:\Users\richa\AppData\Local\Temp\arduino\sketches\2551584DA21E5CA062E8AEE6B0506FBC/build_opt.h @C:\Users\richa\AppData\Local\Temp\arduino\sketches\2551584DA21E5CA062E8AEE6B0506FBC/file_opts C:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src\BLEService.cpp -o nul
C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/defines -IC:\Users\richa\AppData\Local\Temp\.arduinoIDE-unsaved2024620-27948-sobyxp.pw0n\SendKeyStrokes -iprefix C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/include/ @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/includes -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/qio_qspi/include -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\cores\esp32 -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\variants\esp32 -Ic:\Users\richa\OneDrive\Documents\Arduino\libraries\ESP32_BLE_Keyboard -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src @C:\Users\richa\AppData\Local\Temp\arduino\sketches\2551584DA21E5CA062E8AEE6B0506FBC/build_opt.h @C:\Users\richa\AppData\Local\Temp\arduino\sketches\2551584DA21E5CA062E8AEE6B0506FBC/file_opts C:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src\BLEServiceMap.cpp -o nul
C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/defines -IC:\Users\richa\AppData\Local\Temp\.arduinoIDE-unsaved2024620-27948-sobyxp.pw0n\SendKeyStrokes -iprefix C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/include/ @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/includes -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/qio_qspi/include -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\cores\esp32 -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\variants\esp32 -Ic:\Users\richa\OneDrive\Documents\Arduino\libraries\ESP32_BLE_Keyboard -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src @C:\Users\richa\AppData\Local\Temp\arduino\sketches\2551584DA21E5CA062E8AEE6B0506FBC/build_opt.h @C:\Users\richa\AppData\Local\Temp\arduino\sketches\2551584DA21E5CA062E8AEE6B0506FBC/file_opts C:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src\BLEUUID.cpp -o nul
C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/defines -IC:\Users\richa\AppData\Local\Temp\.arduinoIDE-unsaved2024620-27948-sobyxp.pw0n\SendKeyStrokes -iprefix C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/include/ @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/includes -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/qio_qspi/include -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\cores\esp32 -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\variants\esp32 -Ic:\Users\richa\OneDrive\Documents\Arduino\libraries\ESP32_BLE_Keyboard -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src @C:\Users\richa\AppData\Local\Temp\arduino\sketches\2551584DA21E5CA062E8AEE6B0506FBC/build_opt.h @C:\Users\richa\AppData\Local\Temp\arduino\sketches\2551584DA21E5CA062E8AEE6B0506FBC/file_opts C:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src\BLEUtils.cpp -o nul
C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/defines -IC:\Users\richa\AppData\Local\Temp\.arduinoIDE-unsaved2024620-27948-sobyxp.pw0n\SendKeyStrokes -iprefix C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/include/ @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/includes -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/qio_qspi/include -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\cores\esp32 -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\variants\esp32 -Ic:\Users\richa\OneDrive\Documents\Arduino\libraries\ESP32_BLE_Keyboard -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src @C:\Users\richa\AppData\Local\Temp\arduino\sketches\2551584DA21E5CA062E8AEE6B0506FBC/build_opt.h @C:\Users\richa\AppData\Local\Temp\arduino\sketches\2551584DA21E5CA062E8AEE6B0506FBC/file_opts C:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src\BLEValue.cpp -o nul
C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/defines -IC:\Users\richa\AppData\Local\Temp\.arduinoIDE-unsaved2024620-27948-sobyxp.pw0n\SendKeyStrokes -iprefix C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/include/ @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/includes -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/qio_qspi/include -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\cores\esp32 -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\variants\esp32 -Ic:\Users\richa\OneDrive\Documents\Arduino\libraries\ESP32_BLE_Keyboard -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src @C:\Users\richa\AppData\Local\Temp\arduino\sketches\2551584DA21E5CA062E8AEE6B0506FBC/build_opt.h @C:\Users\richa\AppData\Local\Temp\arduino\sketches\2551584DA21E5CA062E8AEE6B0506FBC/file_opts C:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src\FreeRTOS.cpp -o nul
C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/defines -IC:\Users\richa\AppData\Local\Temp\.arduinoIDE-unsaved2024620-27948-sobyxp.pw0n\SendKeyStrokes -iprefix C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/include/ @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/includes -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/qio_qspi/include -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\cores\esp32 -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\variants\esp32 -Ic:\Users\richa\OneDrive\Documents\Arduino\libraries\ESP32_BLE_Keyboard -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src @C:\Users\richa\AppData\Local\Temp\arduino\sketches\2551584DA21E5CA062E8AEE6B0506FBC/build_opt.h @C:\Users\richa\AppData\Local\Temp\arduino\sketches\2551584DA21E5CA062E8AEE6B0506FBC/file_opts C:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src\GeneralUtils.cpp -o nul
Generating function prototypes...
C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/defines -IC:\Users\richa\AppData\Local\Temp\.arduinoIDE-unsaved2024620-27948-sobyxp.pw0n\SendKeyStrokes -iprefix C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/include/ @C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/includes -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/qio_qspi/include -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\cores\esp32 -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\variants\esp32 -Ic:\Users\richa\OneDrive\Documents\Arduino\libraries\ESP32_BLE_Keyboard -IC:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src @C:\Users\richa\AppData\Local\Temp\arduino\sketches\2551584DA21E5CA062E8AEE6B0506FBC/build_opt.h @C:\Users\richa\AppData\Local\Temp\arduino\sketches\2551584DA21E5CA062E8AEE6B0506FBC/file_opts C:\Users\richa\AppData\Local\Temp\arduino\sketches\2551584DA21E5CA062E8AEE6B0506FBC\sketch\SendKeyStrokes.ino.cpp -o C:\Users\richa\AppData\Local\Temp\1272442619\sketch_merged.cpp
C:\Users\richa\AppData\Local\Arduino15\packages\builtin\tools\ctags\5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives C:\Users\richa\AppData\Local\Temp\1272442619\sketch_merged.cpp
Compiling sketch...
"C:\\Users\\richa\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2302/bin/xtensa-esp32-elf-g++" -MMD -c "@C:\\Users\\richa\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-dc859c1e67\\esp32/flags/cpp_flags" -Wall -Wextra -Os -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\richa\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-dc859c1e67\\esp32/flags/defines" "-IC:\\Users\\richa\\AppData\\Local\\Temp\\.arduinoIDE-unsaved2024620-27948-sobyxp.pw0n\\SendKeyStrokes" -iprefix "C:\\Users\\richa\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-dc859c1e67\\esp32/include/" "@C:\\Users\\richa\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-dc859c1e67\\esp32/flags/includes" "-IC:\\Users\\richa\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-dc859c1e67\\esp32/qio_qspi/include" "-IC:\\Users\\richa\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.3\\cores\\esp32" "-IC:\\Users\\richa\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.3\\variants\\esp32" "-Ic:\\Users\\richa\\OneDrive\\Documents\\Arduino\\libraries\\ESP32_BLE_Keyboard" "-IC:\\Users\\richa\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.3\\libraries\\BLE\\src" "@C:\\Users\\richa\\AppData\\Local\\Temp\\arduino\\sketches\\2551584DA21E5CA062E8AEE6B0506FBC/build_opt.h" "@C:\\Users\\richa\\AppData\\Local\\Temp\\arduino\\sketches\\2551584DA21E5CA062E8AEE6B0506FBC/file_opts" "C:\\Users\\richa\\AppData\\Local\\Temp\\arduino\\sketches\\2551584DA21E5CA062E8AEE6B0506FBC\\sketch\\SendKeyStrokes.ino.cpp" -o "C:\\Users\\richa\\AppData\\Local\\Temp\\arduino\\sketches\\2551584DA21E5CA062E8AEE6B0506FBC\\sketch\\SendKeyStrokes.ino.cpp.o"
Compiling libraries...
Compiling library "ESP32 BLE Keyboard"
"C:\\Users\\richa\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2302/bin/xtensa-esp32-elf-g++" -MMD -c "@C:\\Users\\richa\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-dc859c1e67\\esp32/flags/cpp_flags" -Wall -Wextra -Os -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\richa\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-dc859c1e67\\esp32/flags/defines" "-IC:\\Users\\richa\\AppData\\Local\\Temp\\.arduinoIDE-unsaved2024620-27948-sobyxp.pw0n\\SendKeyStrokes" -iprefix "C:\\Users\\richa\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-dc859c1e67\\esp32/include/" "@C:\\Users\\richa\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-dc859c1e67\\esp32/flags/includes" "-IC:\\Users\\richa\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-dc859c1e67\\esp32/qio_qspi/include" "-IC:\\Users\\richa\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.3\\cores\\esp32" "-IC:\\Users\\richa\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.3\\variants\\esp32" "-Ic:\\Users\\richa\\OneDrive\\Documents\\Arduino\\libraries\\ESP32_BLE_Keyboard" "-IC:\\Users\\richa\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.3\\libraries\\BLE\\src" "@C:\\Users\\richa\\AppData\\Local\\Temp\\arduino\\sketches\\2551584DA21E5CA062E8AEE6B0506FBC/build_opt.h" "@C:\\Users\\richa\\AppData\\Local\\Temp\\arduino\\sketches\\2551584DA21E5CA062E8AEE6B0506FBC/file_opts" "c:\\Users\\richa\\OneDrive\\Documents\\Arduino\\libraries\\ESP32_BLE_Keyboard\\BleKeyboard.cpp" -o "C:\\Users\\richa\\AppData\\Local\\Temp\\arduino\\sketches\\2551584DA21E5CA062E8AEE6B0506FBC\\libraries\\ESP32_BLE_Keyboard\\BleKeyboard.cpp.o"
In file included from c:\Users\richa\OneDrive\Documents\Arduino\libraries\ESP32_BLE_Keyboard\BleKeyboard.cpp:14:
C:\Users\richa\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/include/driver/deprecated/driver/adc.h:19:2: warning: #warning "legacy adc driver is deprecated, please migrate to use esp_adc/adc_oneshot.h and esp_adc/adc_continuous.h for oneshot mode and continuous mode drivers respectively" [-Wcpp]
   19 | #warning "legacy adc driver is deprecated, please migrate to use esp_adc/adc_oneshot.h and esp_adc/adc_continuous.h for oneshot mode and continuous mode drivers respectively"
c:\Users\richa\OneDrive\Documents\Arduino\libraries\ESP32_BLE_Keyboard\BleKeyboard.cpp: In member function 'void BleKeyboard::begin()':
c:\Users\richa\OneDrive\Documents\Arduino\libraries\ESP32_BLE_Keyboard\BleKeyboard.cpp:105:19: error: cannot convert 'std::string' {aka 'std::__cxx11::basic_string<char>'} to 'String'
  105 |   BLEDevice::init(deviceName);
      |                   std::string {aka std::__cxx11::basic_string<char>}
In file included from c:\Users\richa\OneDrive\Documents\Arduino\libraries\ESP32_BLE_Keyboard\BleKeyboard.cpp:7:
C:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src/BLEDevice.h:41:27: note:   initializing argument 1 of 'static void BLEDevice::init(String)'
   41 |   static void init(String deviceName);                                                            // Initialize the local BLE environment.
c:\Users\richa\OneDrive\Documents\Arduino\libraries\ESP32_BLE_Keyboard\BleKeyboard.cpp:116:32: error: no matching function for call to 'BLECharacteristic::setValue(std::string&)'
  116 |   hid->manufacturer()->setValue(deviceManufacturer);
In file included from C:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src/BLEServer.h:23,
                 from C:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src/BLEDevice.h:21:
C:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src/BLECharacteristic.h:77:8: note: candidate: 'void BLECharacteristic::setValue(uint8_t*, size_t)'
   77 |   void setValue(uint8_t *data, size_t size);
C:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src/BLECharacteristic.h:77:8: note:   candidate expects 2 arguments, 1 provided
C:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src/BLECharacteristic.h:78:8: note: candidate: 'void BLECharacteristic::setValue(String)'
   78 |   void setValue(String value);
C:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src/BLECharacteristic.h:78:24: note:   no known conversion for argument 1 from 'std::string' {aka 'std::__cxx11::basic_string<char>'} to 'String'
C:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src/BLECharacteristic.h:79:8: note: candidate: 'void BLECharacteristic::setValue(uint16_t&)'
   79 |   void setValue(uint16_t &data16);
C:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src/BLECharacteristic.h:79:27: note:   no known conversion for argument 1 from 'std::string' {aka 'std::__cxx11::basic_string<char>'} to 'uint16_t&' {aka 'short unsigned int&'}
C:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src/BLECharacteristic.h:80:8: note: candidate: 'void BLECharacteristic::setValue(uint32_t&)'
   80 |   void setValue(uint32_t &data32);
C:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src/BLECharacteristic.h:80:27: note:   no known conversion for argument 1 from 'std::string' {aka 'std::__cxx11::basic_string<char>'} to 'uint32_t&' {aka 'long unsigned int&'}
C:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src/BLECharacteristic.h:81:8: note: candidate: 'void BLECharacteristic::setValue(int&)'
   81 |   void setValue(int &data32);
C:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src/BLECharacteristic.h:81:22: note:   no known conversion for argument 1 from 'std::string' {aka 'std::__cxx11::basic_string<char>'} to 'int&'
C:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src/BLECharacteristic.h:82:8: note: candidate: 'void BLECharacteristic::setValue(float&)'
   82 |   void setValue(float &data32);
C:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src/BLECharacteristic.h:82:24: note:   no known conversion for argument 1 from 'std::string' {aka 'std::__cxx11::basic_string<char>'} to 'float&'
C:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src/BLECharacteristic.h:83:8: note: candidate: 'void BLECharacteristic::setValue(double&)'
   83 |   void setValue(double &data64);
C:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE\src/BLECharacteristic.h:83:25: note:   no known conversion for argument 1 from 'std::string' {aka 'std::__cxx11::basic_string<char>'} to 'double&'
Using library ESP32 BLE Keyboard at version 0.3.0 in folder: C:\Users\richa\OneDrive\Documents\Arduino\libraries\ESP32_BLE_Keyboard
Using library BLE at version 3.0.3 in folder: C:\Users\richa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\BLE
exit status 1
Compilation error: exit status 1
