Issue IPAddress by Serial.read()
I would like to be able to type in a specific IP address into the serial monitor and have that number be used as the NTP website IP address to get the time from. I took the NTP example that came pre-loaded with the arduino library, and combined it with Robins example in post #1
#include <SPI.h>
#include <Ethernet.h>
#include <EthernetUdp.h>
// Enter a MAC address for your controller below.
// Newer Ethernet shields have a MAC address printed on a sticker on the shield
byte mac[] = {
  0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
unsigned int localPort = 8888;      // local port to listen for UDP packets
IPAddress timeServer(132, 163, 4, 101); // time-a.timefreq.bldrdoc.gov NTP server
// IPAddress timeServer(132, 163, 4, 102); // time-b.timefreq.bldrdoc.gov NTP server
// IPAddress timeServer(132, 163, 4, 103); // time-c.timefreq.bldrdoc.gov NTP server
const int NTP_PACKET_SIZE= 48; // NTP time stamp is in the first 48 bytes of the message
byte packetBuffer[ NTP_PACKET_SIZE]; //buffer to hold incoming and outgoing packets
// A UDP instance to let us send and receive packets over UDP
EthernetUDP Udp;
//-----------------------------From Robins Example----------------------
const byte numChars = 32;
char receivedChars[numChars];
boolean newData = false;
   while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  // start Ethernet and UDP
  if (Ethernet.begin(mac) == 0) {
    Serial.println("Failed to configure Ethernet using DHCP");
    // no point in carrying on, so do nothing forevermore:
    for(;;)
  Udp.begin(localPort);
	recvWithStartEndMarkers();
	showNewData();
void recvWithStartEndMarkers() {
	static boolean recvInProgress = false;
	static byte ndx = 0;
	char startMarker = '<';
	char endMarker = '>';
	char rc;
	// if (Serial.available() > 0) {
        while (Serial.available() > 0 && newData == false) {
		rc = Serial.read();
		if (recvInProgress == true) {
			if (rc != endMarker) {
				receivedChars[ndx] = rc;
				ndx++;
				if (ndx >= numChars) {
					ndx = numChars - 1;
			else {
				receivedChars[ndx] = '\0'; // terminate the string
				ndx = 0;
				newData = true;
		else if (rc == startMarker) {
			recvInProgress = true;
void showNewData() {
	if (newData == true) {
//sendNTPpacket(timeServer); // send an NTP packet to a time server
sendNTPpacket(receivedChars);
    // wait to see if a reply is available
  if ( Udp.parsePacket() ) {
    // We've received a packet, read the data from it
    Udp.read(packetBuffer,NTP_PACKET_SIZE);  // read the packet into the buffer
    //the timestamp starts at byte 40 of the received packet and is four bytes,
    // or two words, long. First, esxtract the two words:
    unsigned long highWord = word(packetBuffer[40], packetBuffer[41]);
    unsigned long lowWord = word(packetBuffer[42], packetBuffer[43]);
    // combine the four bytes (two words) into a long integer
    // this is NTP time (seconds since Jan 1 1900):
    unsigned long secsSince1900 = highWord << 16 | lowWord;
    Serial.print("Seconds since Jan 1 1900 = " );
    Serial.println(secsSince1900);
    // now convert NTP time into everyday time:
    Serial.print("Unix time = ");
    // Unix time starts on Jan 1 1970. In seconds, that's 2208988800:
    const unsigned long seventyYears = 2208988800UL;
    // subtract seventy years:
    unsigned long epoch = secsSince1900 - seventyYears;
    // print Unix time:
    Serial.println(epoch);
    // print the hour, minute and second:
    Serial.print("The UTC time is ");       // UTC is the time at Greenwich Meridian (GMT)
    Serial.print((epoch  % 86400L) / 3600); // print the hour (86400 equals secs per day)
    Serial.print(':');
    if ( ((epoch % 3600) / 60) < 10 ) {
      // In the first 10 minutes of each hour, we'll want a leading '0'
      Serial.print('0');
    Serial.print((epoch  % 3600) / 60); // print the minute (3600 equals secs per minute)
    Serial.print(':');
    if ( (epoch % 60) < 10 ) {
      // In the first 10 seconds of each minute, we'll want a leading '0'
      Serial.print('0');
    Serial.println(epoch %60); // print the second
// send an NTP request to the time server at the given address
unsigned long sendNTPpacket(IPAddress& address)
  // set all bytes in the buffer to 0
  memset(packetBuffer, 0, NTP_PACKET_SIZE);
  // Initialize values needed to form NTP request
  // (see URL above for details on the packets)
  packetBuffer[0] = 0b11100011;   // LI, Version, Mode
  packetBuffer[1] = 0;     // Stratum, or type of clock
  packetBuffer[2] = 6;     // Polling Interval
  packetBuffer[3] = 0xEC;  // Peer Clock Precision
  // 8 bytes of zero for Root Delay & Root Dispersion
  packetBuffer[12]  = 49;
  packetBuffer[13]  = 0x4E;
  packetBuffer[14]  = 49;
  packetBuffer[15]  = 52;
  // all NTP fields have been given values, now
  // you can send a packet requesting a timestamp:
  Udp.beginPacket(address, 123); //NTP requests are to port 123
  Udp.write(packetBuffer,NTP_PACKET_SIZE);
  Udp.endPacket();
The error message is
UdpNtpClient.ino: In function 'void showNewData()':
UdpNtpClient:89: error: invalid initialization of non-const reference of type 'IPAddress&' from a temporary of type 'char*'
UdpNtpClient:13: error: in passing argument 1 of 'long unsigned int sendNTPpacket(IPAddress&)'
The problem is here, I just don't know what I need to fix it to make it work. Can it be done?
I did as you suggested, but it still didn't work. I then thought maybe I had to add the comma's into the number thing so I tried that as well. In the end I did this
sendNTPpacket(132,163,4,101); //receivedChars);
Where I put in directly into the code. I recieved the following error message
UdpNtpClient:89: error: invalid initialization of non-const reference of type 'IPAddress&' from a temporary of type 'int'
I also tried to create an IPAddress there like this
sendNTPpacket (IPAddress(132, 163, 4, 101)); //(receivedChars);
I then received this error message
UdpNtpClient:89: error: invalid initialization of non-const reference of type 'IPAddress&' from a temporary of type 'IPAddress'
