Hi! I basically have the same problem as a topic opener evan symonds. I'm having trouble loading bitmaps from a micro SD card to 2.4" Adafruit TFT FeatherWing. I'm using fulltest_featherwing example from ILI9341 library as described in guide on Adafruit web page Drawing Bitmaps. The problem is that images cannot be found on the SD card and the error message says "File not found". Microcontroller I'm using is Sparkfun ESP32 Thing. I'm using 32GB SanDisk Ultra microSDXC UHS-I card. Ofcourse, everything is being programmed in Arduino IDE.
So the main difference between topic opener and me is that I 100% followed the guide. SD card was formatted to FAT32 type, image name loaded to SD card was proper and everything else was working fine before attempting bitmaps. The TFT FeatherWing is actually a board consisting of 3 components (touchscreen display shield with built in microSD card socket, and resistive touchscreen attached to it). I tested every component individually using examples and guides from Adafruit page and other pages. Everything worked fine and SD card test completed with no errors. It successfully created, deleted, renamed and wrote data to textual file (which can be seen on a image below). One SD test actually listed all files on the card and on that list was the bitmap I was trying to upload. So I think there is nothing wrong with my SD card.
Anyways, when uploading an example sketch for drawing bitmaps I noticed some warnings:
C:\Users\Marko\AppData\Local\Temp\arduino_modified_sketch_337946\fulltest_featherwing.ino: In function 'void setup()':
C:\Users\Marko\AppData\Local\Temp\arduino_modified_sketch_337946\fulltest_featherwing.ino:94:29: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
bmpDraw("purple.bmp", 0, 0);
C:\Users\Marko\AppData\Local\Temp\arduino_modified_sketch_337946\fulltest_featherwing.ino: In function 'void bmpDraw(char*, uint8_t, uint16_t)':
C:\Users\Marko\AppData\Local\Temp\arduino_modified_sketch_337946\fulltest_featherwing.ino:148:40: warning: converting to non-pointer type 'int' from NULL [-Wconversion-null]
if ((bmpFile = SD.open(filename)) == NULL) {
Sketch uses 198527 bytes (15%) of program storage space. Maximum is 1310720 bytes.
Global variables use 11732 bytes (3%) of dynamic memory, leaving 283180 bytes for local variables. Maximum is 294912 bytes.
esptool.py v2.1
Connecting........_
Chip is ESP32D0WDQ6 (revision 0)
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 921600
Changed.
Configuring flash size...
Auto-detected Flash size: 4MB
Compressed 8192 bytes to 47...
Writing at 0x0000e000... (100 %)
Wrote 8192 bytes (47 compressed) at 0x0000e000 in 0.0 seconds (effective 4681.1 kbit/s)...
Hash of data verified.
Compressed 12304 bytes to 8126...
Writing at 0x00001000... (100 %)
Wrote 12304 bytes (8126 compressed) at 0x00001000 in 0.1 seconds (effective 871.1 kbit/s)...
Compressed 199680 bytes to 112822...
Writing at 0x00010000... (14 %)
Writing at 0x00014000... (28 %)
Writing at 0x00018000... (42 %)
Writing at 0x0001c000... (57 %)
Writing at 0x00020000... (71 %)
Writing at 0x00024000... (85 %)
Writing at 0x00028000... (100 %)
Wrote 199680 bytes (112822 compressed) at 0x00010000 in 2.2 seconds (effective 718.3 kbit/s)...
Compressed 3072 bytes to 122...
Writing at 0x00008000... (100 %)
Wrote 3072 bytes (122 compressed) at 0x00008000 in 0.0 seconds (effective 1365.3 kbit/s)...
Leaving...
Hard resetting...
After uploading sketch to board, serial monitor shows this:
ets Jun 8 2016 00:22:57
rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
rst:0x10 (RTCWDT_RTC_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0018,len:4
load:0x3fff001c,len:812
load:0x40078000,len:0
load:0x40078000,len:11392
entry 0x40078a9c
FeatherWing TFT
Touchscreen started
Initializing SD card...OK!
Loading image 'purple.bmp'
File not found
Here are images of SD card setup:
In above image there are two bmp files highlighted because I tried running the sketch with both of them, but without luck. I also highlighted txt files which one of the SD tests created just to prove that the SD card is working.
I hope someone helps as this is a part of important school project. I must also say thank you to pylon who already tried helping the topic opener with this issue. Too bad the later mentioned did not respond back.
