Issue when trying to store a value after Serial.parseFloat()
Hi there everyone!
I have been using this sketch that works perfectly.
So as you can see, you send a value through the serial monitor, this value is stored and then send to a ESC (electronic speed controller)
This is the code:
#include <Servo.h>
Servo ESC; // create servo object to control the ESC
int inputVal = 90; // variable to store the input value
// Attach the ESC on pin 9
ESC.attach(9, 1000, 2000); // (pin, min pulse width, max pulse width in microseconds)
if (Serial.available()>1) { // check if there is any input available from Serial Plot
inputVal = Serial.parseInt(); // read the input value and store it in the variable
Serial.print("Input value is: "); // print a message to confirm the input value
Serial.println(inputVal);
ESC.write(inputVal); // Send the signal to the ESC (value between 0 and 180)
else Serial.println("nothing to read");
delay(100); // wait for a short period to avoid excessive readings
I just change my needs for this script and run into issues.
As you can see in the following code, its more or less the same but introducing a float instead of an integer:
#include <VescUart.h>
/** Initiate VescUart class */
VescUart UART;
float inputVal = 0.0;
/** Setup UART port (Serial1 on Atmega32u4) */
Serial1.begin(115200);
while (!Serial1) {;}
/** Define which ports to use as UART */
UART.setSerialPort(&Serial1);
if (Serial.available()>1.0)
inputVal = Serial.parseFloat();
UART.setRPM(inputVal);
delay(100);
What happens is that I introduce -let's say- 200.0- and then it works, it tells me "Input value is: 200.0" and actually i can see that the motor is moving, but just for a loop.
After that, the serial monitor puts again "nothing to read" and the motor stops (since i guess, the value returns to being 0)
So I guess what I need is the last value to remain until I put the next value
I hope someone can help me :slight_smile:
Thanks in advance
it could be that the end of lines characters() are being read as 0
after parsing the float try reading and throwing away any characters in the input buffer
while(Serial.available())Serial.read();
Did you expect some fraction of a character to be available?
Maybe not the best code, but that was working for my last script
instead of being offended, it is better to use the comments of others for learning.
See what is the meaning of the operation :
and what needs to be written here instead of 1.0
I have try
but doesn't work as well.
However, I just try the following and it works:
VescUart UART;
delay(100);
Why would you do this if you did not read a new value?
Side note: I would suggest to study Serial Input Basics to understand how to handle the Serial communication
