Issue with access point/web server on Nano 33 IoT
Hey all,
I have the following scenario:
  1. Arduino Nano 33 IoT with a NINA W-102 wifi/ble module. This board is acting as a wifi access point and a web server.
  2. Custom board, but similar to an Arduino Zero, with a SAMD21 microcontroller and an ATWINC1500 wifi module. This board is acting as a wifi client.
All I want to do is have the 2nd board connect to the Nano's web server, send a string, and then disconnect. The Nano only needs to do a Serial print of the string it receives from the web client. Unfortunately, I am having some serious issues with the client being able to connect to the server. To put it simply - it just isn't connecting. But it is connecting to the access point.
Here is my access point/server code which is running on the Nano 33 IoT. It is very similar to the code in the example "AP_SimpleWebServer" sketch for the Nano, except it's been simplified a bit:
#include <SPI.h>
#include <WiFiNINA.h>
WiFiServer server(80);
int wifi_status;
    //Begin serial communication
    SerialUSB.begin(115200);
    //Countdown to give user enough time to open Arduino serial monitor
    for (int i = 10; i > 0; i--)
        SerialUSB.println(i);
    // check for the WiFi module:
    if (WiFi.status() == WL_NO_MODULE)
        Serial.println("Communication with WiFi module failed!");
        while(true);
        String fv = WiFi.firmwareVersion();
        if (fv < WIFI_FIRMWARE_LATEST_VERSION)
            SerialUSB.print("Current firmware version: ");
            SerialUSB.println(fv);
            SerialUSB.print("Expected firmware version: ");
            SerialUSB.println(WIFI_FIRMWARE_LATEST_VERSION);
            SerialUSB.println("Please upgrade the firmware");
        //Print a message to the user
        SerialUSB.println("Launching access point: HabiTrak_Gateway");
        //Start the wifi access point
        int status = WiFi.beginAP("HabiTrak_Gateway");
        if (status != WL_AP_LISTENING)
            SerialUSB.println("FAILED to create access point");
            while(true);
            SerialUSB.println("SUCCESSFULLY created access point");
    if (wifi_status != WiFi.status())
        wifi_status = WiFi.status();
        if (wifi_status == WL_AP_CONNECTED)
            //a device has connected to the AP
            SerialUSB.println("Device connected to AP");
            //a device has disconnected from the AP, and we are back in listening mode
            SerialUSB.println("Device disconnected from AP");
    //Check if a client has connected to the server
    WiFiClient client = server.available();
    //If we have a client
    if (client)
        SerialUSB.println("Client connected to server");
        //Read the message from the client and print it to the serial monitor
        while (client.connected())
            if (client.available())
                char c = client.read();
                SerialUSB.write(c);
        //Close the connection to the client
        client.stop();
        SerialUSB.println("Client disconnected from server");
Now, here is the code running on the client board (custom board, but similar to a Zero - has a SAMD21 and an ATWINC1500):
#include <SPI.h>
#include <WiFi101.h>
#define WINC_IRQ          	6     		//Digital input for the ATWINC1500 interrupt output.
#define WINC_SS 			A1      	//Digital output for the ATWINC1500 SPI slave select.
#define WINC_RESET        	31          //Digital output for the ATWINC1500 reset input.
#define WINC_EN		       	30          //Digital output for the ATWINC1500 enable input.
#define WINC_WAKE			27			//Digital output for the ATWINC1500 wake input.
char ssid[] = "HabiTrak_Gateway";          //  your network SSID (name)
int status = WL_IDLE_STATUS;
WiFiClient client;
    //Initialize serial communication
    //Countdown sequence to allow user to open Arduino serial monitor
    //Set the pins being used for the wifi module
    WiFi.setPins(WINC_SS, WINC_IRQ, WINC_RESET, WINC_EN);
    //Connec to the wifi network
    SerialUSB.println("Attempting to connect to network...");
    SerialUSB.print("SSID: ");
    SerialUSB.println(ssid);
    status = WiFi.begin(ssid);
    if (status != WL_CONNECTED)
        SerialUSB.println("Couldn't get a wifi connection");
        //loop forever
        while(true)
            //empty
        SerialUSB.println("Connected to wifi access point");
        SerialUSB.println("Attempting to connect to server");
        //Attempt to connect to the server
        if (client.connect(IPAddress(192, 168, 1, 1), 80))
            SerialUSB.println("Client successfully connected to server.");
            //Make a HTTP request:
            client.println("GET /search?q=arduino HTTP/1.0");
            client.println();
            SerialUSB.println("Client FAILED to connect to server.");
    //empty
Here is the Serial output I am receiving from the access point on the Nano:
And here is the Serial output from the client:
SSID: HabiTrak_Gateway
Any suggestions on what I may be doing wrong? As far as I can tell, this is a minimal example, and there isn't anything "out of the ordinary" in what I am doing.
Also, as another note of interest: if I use two of my custom boards (the board similar to the Zero with an ATWINC1500), and have one act as the access point/server and the other act as the client, then this works perfectly. So it seems to me that the issue is the Nano 33 IoT board acting as the access point/server.
Any help would be appreciated. Thank you!
You pared it down a bit too much - you need to start your webserver if you want it to run
// start the web server on port 80
server.begin();
Thanks for catching that mistake. I've fixed it, but unfortunately it's not the cause of the issue.
While making my "minimal example" of the code for this forum post, I had forgotten to put that line of code in there. But I've now put it in there, and it still doesn't work. Also, in my "non-minimal" code which this minimal example is based on, I did have that line in there, and it doesn't work in that version of the code either.
Here is my new "minimal example" of the access point/server which now includes the server.begin() line of code at the end of the setup() function:
#include <SPI.h>
int wifi_status;
        while(true);
            while(true);
    server.begin();
    if (client)
                SerialUSB.write(c);
        client.stop();
Any suggestions?
How do you know your AP has this address? I would print out the IP address of the webserver after it begins to verify you are hitting the correct address
Good catch. I was assuming 192.168.1.1, because in previous tests it was always defaulting to that IP address, but it seems like it was now using a different IP address.
I've changed the code to specifically set it to a static IP of 192.168.1.1, and now the minimal example works. This will help me get my non-minimal code working. Thanks for the help!
