A few months ago, I built a arcade style controller for a friend using an Arduino Leonardo board with the Keyboard library to control a Mame emulator. I had issues with the LEFT ALT key since it would get stuck pressed for no apparent reason. I used the ‘pullup’ mode for my inputs, as it fit better with my build, and all of the other inputs seemed to work with no issue. I’ve been over the code many times, and can’t find where the problem lies. I’m looking to fix it soon, so if anyone can spot the problem, it would be greatly appreciated.
The code is included below:
(Any ‘Wire’ commands are to do with LED control on a separate board [Arduino UNO])
#include <Wire.h>
#include <Keyboard.h>
//input variables
const int butt1 = 2;
const int butt2 = 3;
const int butt3 = 4;
const int butt4 = 5;
const int butt5 = 6;
const int butt6 = 7;
const int sButt = 8;
const int lJoy = 11;
const int uJoy = 12;
const int rJoy = 9;
const int dJoy = 10;
//previous input variables
int butt1Prev = HIGH;
int butt2Prev = HIGH;
int butt3Prev = HIGH;
int butt4Prev = HIGH;
int butt5Prev = HIGH;
int butt6Prev = HIGH;
int sButtPrev = HIGH;
int lJoyPrev = HIGH;
int uJoyPrev = HIGH;
int rJoyPrev = HIGH;
int dJoyPrev = HIGH;
//other variables
long buttonTimer = 0;
long longPressTime = 500; //500 ms
bool buttonActive = false;
bool longPressActive = false;
pinMode(butt1, INPUT_PULLUP);
pinMode(butt2, INPUT_PULLUP);
pinMode(butt3, INPUT_PULLUP);
pinMode(butt4, INPUT_PULLUP);
pinMode(butt5, INPUT_PULLUP);
pinMode(butt6, INPUT_PULLUP);
pinMode(sButt, INPUT_PULLUP);
pinMode(lJoy, INPUT_PULLUP);
pinMode(uJoy, INPUT_PULLUP);
pinMode(rJoy, INPUT_PULLUP);
pinMode(dJoy, INPUT_PULLUP);
pinMode(13,OUTPUT);
digitalWrite(13,HIGH);
// initialize control over the keyboard
Keyboard.begin();
Keyboard.releaseAll();
// connect to slave arduino
Wire.begin(); // join i2c bus (address optional for master)
//read the pushbuttons
int butt1State = digitalRead(butt1);
int butt2State = digitalRead(butt2);
int butt3State = digitalRead(butt3);
int butt4State = digitalRead(butt4);
int butt5State = digitalRead(butt5);
int butt6State = digitalRead(butt6);
int sButtState = digitalRead(sButt);
int lJoyState = digitalRead(lJoy);
int uJoyState = digitalRead(uJoy);
int rJoyState = digitalRead(rJoy);
int dJoyState = digitalRead(dJoy);
//joystick
//if the input state has changed, and the button/joystick is pressed
if ((lJoyState != lJoyPrev) && (lJoyState == LOW)){
//press the key
Keyboard.press(KEY_LEFT_ARROW);
//otherwise, if the button/joystick is released
} else if (lJoyState == HIGH){
//release the key
Keyboard.release(KEY_LEFT_ARROW);
if ((uJoyState != uJoyPrev) && (uJoyState == LOW)){
Keyboard.press(KEY_UP_ARROW);
} else if (uJoyState == HIGH){
Keyboard.release(KEY_UP_ARROW);
if ((rJoyState != rJoyPrev) && (rJoyState == LOW)){
Keyboard.press(KEY_RIGHT_ARROW);
} else if (rJoyState == HIGH){
Keyboard.release(KEY_RIGHT_ARROW);
if ((dJoyState != dJoyPrev) && (dJoyState == LOW)){
Keyboard.press(KEY_DOWN_ARROW);
} else if (dJoyState == HIGH){
Keyboard.release(KEY_DOWN_ARROW);
//start / coin button
//press for start, hold for coin
if (digitalRead(sButt) == LOW) {
if (buttonActive == false) {
buttonActive = true;
buttonTimer = millis();
delay(3);
if ((millis() - buttonTimer > longPressTime) && (longPressActive == false)) {
//add coin
longPressActive = true;
// Send light command to slave arduino
Wire.beginTransmission(1); // transmit to device #1
Wire.write('7'); // sends one byte
Wire.endTransmission(); // stop transmitting
Keyboard.press('5');
delay(100);
Keyboard.release('5');
if (buttonActive == true) {
if (longPressActive == true) {
//start game
Wire.write('8'); // sends one byte
Keyboard.press('1');
delay(100);
Keyboard.release('1');
//action buttons
if ((butt1State != butt1Prev)
// and it's currently pressed
&& (butt1State == LOW)){
Keyboard.press(KEY_LEFT_CTRL);
} else if (butt1State == HIGH){
Keyboard.release(KEY_LEFT_CTRL);
if ((butt2State != butt2Prev) && (butt2State == LOW)){
Keyboard.press(KEY_LEFT_ALT);
} else if (butt2State == HIGH){
Keyboard.release(KEY_LEFT_ALT);
if ((butt3State != butt3Prev) && (butt3State == LOW)){
Keyboard.press(' ');
} else if (butt3State == HIGH){
Keyboard.release(' ');
if ((butt4State != butt4Prev) && (butt4State == LOW)){
Keyboard.press(KEY_LEFT_SHIFT);
} else if (butt4State == HIGH){
Keyboard.release(KEY_LEFT_SHIFT);
if ((butt5State != butt5Prev) && (butt5State == LOW)){
Keyboard.press('z');
} else if (butt5State == HIGH){
Keyboard.release('z');
if ((butt6State != butt6Prev) && (butt6State == LOW)){
Keyboard.press('x');
} else if (butt6State == HIGH){
Keyboard.release('x');
// save the current button state for comparison next time:
butt1Prev = butt1State;
butt2Prev = butt2State;
butt3Prev = butt3State;
butt4Prev = butt4State;
butt5Prev = butt5State;
butt6Prev = butt6State;
sButtPrev = sButtState;
lJoyPrev = lJoyState;
uJoyPrev = uJoyState;
rJoyPrev = rJoyState;
dJoyPrev = dJoyState;
