I am encountering a problem while trying to upload code to my ESP32 board using Arduino IDE. I have to mention that I'm a beginner and I'm not familiar with how Arduino or esp32 work. Every time I attempt to upload the code, I receive the following error message:
Sketch uses 260173 bytes (19%) of program storage space. Maximum is 1310720 bytes.
Global variables use 21344 bytes (6%) of dynamic memory, leaving 306336 bytes for local variables. Maximum is 327680 bytes.
esptool.py v4.5.1
Serial port /dev/cu.usbserial-10
Connecting....
Chip is ESP32-D0WD-V3 (revision v3.1)
Features: WiFi, BT, Dual Core, 240MHz, VRef calibration in efuse, Coding Scheme None
Crystal is 40MHz
MAC: e4:65:b8:20:71:90
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 921600
Changed.
A fatal error occurred: Unable to verify flash chip connection (Invalid head of packet (0xA6): Possible serial noise or corruption.).
Failed uploading: uploading error: exit status 2
I have tried several troubleshooting steps, including:
Resetting the ESP32 board and trying again.
Using a different USB port and a different USB cable.
Updating the USB drivers and ESP32 firmware to the latest versions.
Verifying physical connections and relevant pins.
However, the issue persists. It seems to be related to a communication problem between Arduino IDE and the ESP32 board, possibly due to serial noise or corruption.
I know for sure that there is nothing wrong with the ESP32 because my faculty gave it to me.
Has anyone else encountered a similar issue before? Any suggestions or insights would be greatly appreciated.
I need to mention that I have Mac OS if it matters in any way.
esptool.py v4.5.1
Serial port COM9
Connecting....
Crystal is 40MHz
MAC: 34:5f:45:07:ba:60
Uploading stub...
Running stub...
Stub running...
Changed.
A fatal error occurred: Unable to verify flash chip connection (Invalid head of packet (0x80): Possible serial noise or corruption.).
Failed chip erase: uploading error: exit status 2 I am facing same issue. No baud rate changing work for me ...I am using ESP programmer to upload program
Same problem I am facing while uploading the code in XIAO ESP32 C3
Here is the error I received --->
esptool.py v4.6 Serial port COM23 Connecting... Chip is ESP32-C3 (revision v0.4) Features: WiFi, BLE Crystal is 40MHz MAC: 54:32:04:89:3e:84 Uploading stub... Running stub... Stub running... Changing baud rate to 921600
A fatal error occurred: No serial data received. A fatal error occurred: No serial data received.
I was able to upload the code two to three times but after that, I was unable to upload the code.
After that, I took a new XIAO ESP32 C3 board and tried but the same thing happened in the second board also.
If anyone has a solution regarding this, please share.
When you encounter the above two situations, you can try to put XIAO into BootLoader mode, which can solve most of the problems of unrecognized devices and failed uploads. The specific method is:
Long press the "BOOT BUTTON".
Connect the Seeed Studio XIAO ESP32C3 to your computer while holding the BOOT BUTTON.
Release it to enter bootloader mode
After this, I can upload the program without pressing any button.
Just confirming the changing the serial comminucatin rate to 115600 fixed it for me. I was running indirectly from MAC USBc port to LENTION USB hub to cheap Yellow Display dev board.
Funcionou comigo. Com a IDE aberta, desconectei o cabo USB, depois mantive o botĂŁo "boot" pressionado, conectei o cabo "USB e dei o comando de carregar na IDE. Bingo! (PortuguĂŞs). IDE 1.8.10
