Hello, I am trying to get a code working that sets a pwm duty cycle that uses voltage out as the control for the duty cycle.
Since I am trying to control voltage I am trying to make it as fast as possible.
I am just learning and always appreciate tips on things unrelated to my question, if variables arent used in the best way I am all ears to improving that sort of thing too.
I have this code that works well by using a potentiometer to control duty cycle.
One version will be 10-35v, the other version will be 10-80v. (different fet, divider resistor, and 7812 regulator replaced with drop in switching regulator).
I plan on switching at 62 khz , but may drop it down to 31khz if testing shows significant difference in fet heat generation.
Hoping to end up with a one size fits most high power PWM that can take various inputs.
The particular use I am struggling with here is to keep the output voltage steady regardless of what the current draw is on the load.
I can now see that trying to use Vin to PWM a load to drag Vin down wont work either (wind turbine dump load)
The polypropylene snubber capacitors are there to absorb the spike in voltage on the drain of the fet when it shuts off.
I was told the diode isnt fast enough and the caps keep everything ok till the diode (D1)"catches"
Hoping to use them for all kinds of loads, resistive, capacitive and inductive.
I will use them for everything they can do without letting the smoke out . (Will find this limit thru testing)
They work great so far, just burnt a 1/4" welding rod at 300 amps with the full weld current running thru the board.
Just trying to get them working as PWM voltage regulators for solar to send excess power to a heating element.
Really going for a one size fits most kind of thing here as I have a 10 year backlog of stuff I want to test.
PWM is a rectangular digital signal that also can be observed at the load as an increasing (ON) and decreasing (OFF) voltage. If you can not measure the voltages fast enough for building an average voltage you should add low pass filters before the analog inputs.
Also consider to measure the flowing current instead of the voltage, using a Hall sensor based or a clamp meter. This way you get only one signal that is easier to filter.
So I googled what an low pass filter was and added one on each voltage divider, now I get useable "voltage" readings from my dividers.
Thanks for that, I was fighting too many issues at the same time to figure that one out.
Did some more work on my code and got it to work, but it refuses to output anything if I comment the serial plotter? I of course want it off to speed things up.
The code also refuses to work if I uncomment the line "if (Vin < 60) (Output = 0); "
Any ideas what I am doing wrong?
#include <avdweb_AnalogReadFast.h>
byte Vin = 0, drain = 0, Vout = 0, Input = 0;
short int Output = 0;
delay(2000);
pinMode (5,OUTPUT);
TCCR0B = TCCR0B & B11111000 | B00000001; // for PWM frequency of 62500.00 Hz
Input = (analogReadFast(4)>>2);
Vin = (analogReadFast(5) >> 2);
drain = (analogReadFast(6) >> 2);
Vout = (Vin - drain);
if (Vout >= Input) Output = (Output - 5);
if (Vout < Input) Output = (Output + 3);
Output = constrain(Output, 0, 255);
//if (Vin < 60) (Output = 0); //this is supposed to keep controller from starting at full throttle when powered up,controller output stays at zero with this uncommented?
analogWrite(5, Output);
Serial.println("Output:");
Serial.print(Output);
Serial.print(" ");
Serial.print("Vin:");
Serial.print(Vin);
Serial.print(" ");
Serial.print("Vout:");
Serial.print(Vout);
Serial.print(" ");
Serial.print("Input:");
Serial.print(Input);
Serial.print(" ");
Got it working with, and without the serial plotter, thanks for the help and ideas.
Its amazing how much faster it runs without the serial plotter.
Looks like a lot of my issues were from having byte values maxing out, then rolling over to 0 or 255.
Hopefully others can use this since there dosent seem to be much like this geared towards the rookie.
I think this could be ideal to shunt excess solar power to a heater by making these changes, will test soon.
if (Vout > Input) Output = (Output - 5); // for voltage regulation on Vout
else if (Vout < Input) Output = (Output + 3)
to
if (Vin > Input) Output = (Output + 5); //for voltage regulation on Vin with shunt on Vout
else if (Vin < Input) Output = (Output - 3)
//Created by Chris Soro
byte Vin = 0, drain = 0, Input = 0;
short int Vout = 0, Output = 0; // these are to keep the values from maxing out and rolling over
//Serial.begin(9600);
delay(2000); // to allow you be fully plugged in before drawing current and arcing connections
pinMode (5,OUTPUT);
Input = (analogReadFast(4)>>2); // if you need to map input you will probably need to change Input from a byte to a short int, this might slow it down a little
Vin = (analogReadFast(5) >> 2); // these inputs are fed by voltage dividers with low pass filters, this one on positive in
drain = (analogReadFast(6) >> 2); // this one on drain of low side fet
Vout = (Vin - drain); // this is to exclude the fet voltage drop from Vout measurement
else if (Vout < Input) Output = (Output + 3);
if (Vin < 60) Output = 0; // to keep from starting at full throttle
Serial.print(" ");
Serial.print(Vin);
Serial.print(" ");
Serial.print(Vout);
Serial.print(" ");
Serial.print(" ");
Good point, I do want a steady voltage, I will edit my post to change it.
This project has been throwing me a lot of curve balls and I have been working crazy hours to get it sorted. Im not firing on all cylinders at 3am... And firing on all cylinders often isnt very impressive...
Code is updated.
its probably not right, but I have a 223 ceramic cap across R8 and another across R9
in between j2.6 and R6/R9 theres a 330 ohm resistor
in between j2.7 and R7/R8 theres a 330 ohm resistor
This hopefully is a 24khz low pass filter, no idea if thats the optimum value, but it seems to work
Where did you update it??? Please do not update OLD posts, it throws a spanner in the flow of the thread, and anybody trying to use this tread to solve their particular problem will be confused.
