grape
December 21, 2018, 12:39pm
1
Group,
I just installed the mac 10.11 (El Capitan) OS on my older MacBook Pro last night and was disappointed to find the arduino IDE shuts down and gives the attached errors when I attempt to launch the application. The Arduino starter kit owners manual states (p.17) that the IDE download is compatible with "OS 10.5 or later."
I have searched several posts by others in this forum and outside but nothing I have tried so far has helped. A bit frustrating since my current hardware will only support up to OS 10.11 and I took arduino at it's word with the OS versions supported.
Any feedback is appreciated.
Thanks,
Dan
pert
December 21, 2018, 1:18pm
2
I believe you have encountered this bug:
opened 05:44PM - 08 Dec 18 UTC
closed 02:38PM - 11 Dec 18 UTC
Type: Bug
OS: OSX
Type: Regression
Upgraded from 1.6.6.
v1.8.8 immediately crashes on startup with exception in… log console and crash report:
Process: Arduino [1153]
Path: /Applications/development/Arduino.app/Contents/MacOS/Arduino
Identifier: cc.arduino.Arduino
Version: 1.8.8 (1.8.8)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: Arduino [1153]
User ID: 501
Date/Time: 2018-12-08 18:02:00.194 +0100
OS Version: Mac OS X 10.11.6 (15G22010)
Report Version: 11
Anonymous UUID: D68992EA-87DB-CDED-6913-AA92AAE020A6
Time Awake Since Boot: 740 seconds
System Integrity Protection: enabled
Crashed Thread: 0 AppKit Thread Dispatch queue: com.apple.main-thread
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Application Specific Information:
*** Terminating app due to uncaught exception 'NSInvalidArgumentException', reason: '-[NSApplicationAWT setAutomaticCustomizeTouchBarMenuItemEnabled:]: unrecognized selector sent to instance 0x7fd003d71ae0'
terminating with uncaught exception of type NSException
abort() called
Java version is:
java version "1.8.0_102"
Java(TM) SE Runtime Environment (build 1.8.0_102-b14)
Java HotSpot(TM) 64-Bit Server VM (build 25.102-b14, mixed mode)
Also removing `~/Library/Arduino15` did not help.
Downloaded 1.8.6. : no problems, only slow File menu.
That bug has already been fixed but there has not been a new release of the Arduino IDE since that time.
My recommended workaround for this bug is to use Arduino IDE 1.8.7 instead of Arduino IDE 1.8.8. You can download 1.8.7 here:
