Issues with ADXL335
Hello, I bought an Adafruit 5V ADXL335 that I am using with an Arduino Nano EVERY.
Current wiring order:
ADXL335 -> Arduino Nano EVERY
Xout -> A2
Yout -> A1
Zout -> A0
GND -> GND
3V -> AREF
Vin -> 5V
Current Code (credit to https://lastminuteengineers.com/adxl335-accelerometer-arduino-tutorial/):
const int xInput = A2;
const int yInput = A1;
const int zInput = A0;
// initialize minimum and maximum Raw Ranges for each axis
int RawMin = 0;
int RawMax = 1023;
// Take multiple samples to reduce noise
const int sampleSize = 10;
analogReference(EXTERNAL);
//Read raw values
int xRaw = ReadAxis(xInput);
int yRaw = ReadAxis(yInput);
int zRaw = ReadAxis(zInput);
// Convert raw values to 'milli-Gs"
long xScaled = map(xRaw, RawMin, RawMax, -3000, 3000);
long yScaled = map(yRaw, RawMin, RawMax, -3000, 3000);
long zScaled = map(zRaw, RawMin, RawMax, -3000, 3000);
// re-scale to fractional Gs
float xAccel = xScaled / 1000.0;
float yAccel = yScaled / 1000.0;
float zAccel = zScaled / 1000.0;
Serial.print("X, Y, Z :: ");
Serial.print(xRaw);
Serial.print(", ");
Serial.print(yRaw);
Serial.print(", ");
Serial.print(zRaw);
Serial.print(" :: ");
Serial.print(xAccel,0);
Serial.print("G, ");
Serial.print(yAccel,0);
Serial.print(zAccel,0);
Serial.println("G");
delay(200);
// Take samples and return the average
int ReadAxis(int axisPin) {
long reading = 0;
analogRead(axisPin);
delay(1);
for (int i = 0; i < sampleSize; i++) {
reading += analogRead(axisPin);
return reading/sampleSize;
The current issue is, for all 3 axis, only 1023 is printed constantly. Moving the accelerometer doesn't change anything. If I remove the AREF wire and get rid of analogReference(EXTERNAL), it returns a stream of random data that does not respond to tilt, i.e, it the data floats.
Any help is appreciated!
Do you have a DMM? A good start would be to measure the X, Y, and Z outputs less anything else connected. The ADXL Data Sheet tells you what voltage changes you can expect to see based on rotation.
If you see changes with respect to the data sheet you know at least your ADXL335 module is giving a correct voltage out.
Ron
