Issues with array and summation
Hi, so I'm having issues with storing the 6 integers into the array and then the multiplying/summation of them at the end. The code is meant to Prompt the user to enter 6 signed integers. Scold if anything other than an integer and re-prompt until the user has entered six. Allow users to enter "x" to start again. After receiving 6 integers query the user for "sum" or "product". Begin the program again after printing the result. And the code is:
//  integer read from user
int userInt;
int i = 0;
//  character array read from user
char userArray[] = {0, 0, 0, 0, 0, 0};
  // Set up the serial port, baud rate argument can be changed
  // to others supported by serial monitor
void loop () {
  // prompt the user
  int intCount = 0;
  while (intCount < 6) {
    Serial.println("Enter six signed but non-zero integers, or 'x' to quit"); //change to x eventually
    while (Serial.available() == 0) {
      delay(20);  //Seems to work better when delaying a tiny bit between reads
    if (Serial.peek() == 'x' || Serial.peek() == 'X') {
      //  Now, read and ignore all characters from the serial monitor
      //  Allows user to type qzw134ks5 and still quit without leaving zw134ks5
      //  in the buffer for the next read
      while (Serial.available() > 0) {//had this at start of og code and it just deletes available char
        Serial.read();  //Ignoring the returned value just empties the queue of characters
      Serial.println("OK, quitting");
      intCount = 6;// exit this loop
      userInt = Serial.parseInt(); // if not 'q' read code
      intCount++; //counter +1
      if (userInt == 0) {
        Serial.println("You did not enter a valid integer or entered zero.");
        intCount--;// so that you dont have to start over return counter as this input was invalid
        Serial.print("Integer number "); Serial.print(intCount); Serial.print(" is ");
        Serial.println(userInt);// print each number as it appears
        userInt = userArray[intCount];
  for (i = 0; i < 5; i++) {
    Serial.println(userArray[i]);
  Serial.println("Sum or Product?");
  Serial.println("For Sum type 's' or 'S'");
  Serial.println("For Product type 'p' or 'P'");
        Serial.read();  //  Ignoring the returned value just empties the queue of characters
      intCount = 6;
    if (Serial.readString() == 'p' || Serial.readString() == 'P') { //if user chooses product
      int p = 1;
      //set p to 1
      for (i = 0; i < 6; i++) {
        p *= userArray[i];
        //(1)*int1*int2...
    if (Serial.readString() == 's' || Serial.readString() == 'S') { // if user chooses sum
      int s = 0;
      //set s to 0
        s += userArray[i];
        //(0) + each number in array for all 6 spots ( 0 + int1 +int2...)
    else {
      Serial.println("invalid");
please help and please don't be rude I am new to Arduino.
I see several issues with this code:
  1. Serial.parseInt() returns a long so I would suggest making all arrays and temporary variables of type long
  2. The following assignment is backwards:
  1. You are incrementing intCount too early causing userArray[0] not to be populated.
      if (userInt == 0) {
  1. The following code has several issues:
      int p = 1;
      //set p to 1
        p *= userArray[i];
        //(1)*int1*int2...
      int s = 0;
      //set s to 0
        s += userArray[i];
    else {
  • You are comparing String against char
  • You need to do a Serial.readString() into a temporary String variable and then do all your compares.
  • You should restructure this into if/elseif
  1. This should be i<6 not i<5
Here is a version with the above corrections. There are still issues handling 'x' (quit) but I'm not sure exactly how you want that to work.
long userInt;
int i = 0;
//  integer array read from user
long userArray[] = {0, 0, 0, 0, 0, 0};
void loop () {
  // prompt the user
  int intCount = 0;
      if (userInt == 0) {
        userArray[intCount++] = userInt;
      intCount = 6;
    String oper = Serial.readString();
    if (oper == "p" || oper == "P") { //if user chooses product
      long p = 1;
      //set p to 1
        p *= userArray[i];
        //(1)*int1*int2...
      Serial.print("Product = ");
      Serial.println(p);
    } else if (oper == "s" || oper == "S") { // if user chooses sum
      long s = 0;
      //set s to 0
        s += userArray[i];
      Serial.print("Sum = ");
      Serial.println(s);
    else {
Thank you this is very informative and helpful. However, now when running the program it is never-ending and doesn't tell what number you are on i.e. 1-6. I am thinking this may have something to do with the userArray[intCount++] = userInt?
The 'x' is meant to be a way to restart the program if the user wants to quit and enter different values for integers 1-6 in the userArray.
This is the output I got when I ran my version:
Integer number 0 is 1
Integer number 1 is 1
Integer number 2 is 1
Integer number 3 is 1
Integer number 4 is 1
Integer number 5 is 1
1
1
1
1
1
1
Sum or Product?
Sum = 6
I realized that I did not delete a line before, sorry. but now when I run the program it still does not wait for input and I cannot do either function at the end. It reads:
integer number 0 is 1
integer number 1 is 1
and so on until the end where it reads them back correctly but does not wait to choose sum or product and decides it is invalid before restarting.
It works for me. Check your line ending in your serial monitor.
Yep, that was it! Thank you so much
erinmags:
Glad it worked for you!
