Issues with CANbus on Arduino and external CANbus Analyzer
We're using an Arduino Uno with the MCP2515 module and successfully tested message exchange with another Arduino via CANbus.
However, we're having trouble when using a single Arduino with a CANbus analyzer (Microchip CANbus Analyzer) or with a different microcontroller like the PIC18F46K80 for testing message transmit and recieve via CANbus. We're using the MCP2515 CAN library by Sandeep Mistry and standard receive code (attached).
Any guidance or advice would be greatly appreciated.
// Copyright (c) Sandeep Mistry. All rights reserved.
// Licensed under the MIT license. See LICENSE file in the project root for full license information.
#include <CAN.h>
  while (!Serial);
  Serial.println("CAN Receiver");
  // start the CAN bus at 500 kbps
  if (!CAN.begin(500E3)) {
    Serial.println("Starting CAN failed!");
    while (1);
  // try to parse packet
  int packetSize = CAN.parsePacket();
  if (packetSize) {
    // received a packet
    Serial.print("Received ");
    if (CAN.packetExtended()) {
      Serial.print("extended ");
    if (CAN.packetRtr()) {
      // Remote transmission request, packet contains no data
      Serial.print("RTR ");
    Serial.print("packet with id 0x");
    Serial.print(CAN.packetId(), HEX);
      Serial.print(" and requested length ");
      Serial.println(CAN.packetDlc());
      Serial.print(" and length ");
      Serial.println(packetSize);
      // only print packet data for non-RTR packets
      while (CAN.available()) {
        Serial.print((char)CAN.read());
I do not know if that analyzer will acknowledge a message but connect the two that worked. When working connect the analyzer. Use only 2 termination resistors one at each physical end of the bus.
Is it a shield that plugs into the Uno, or a separate board that you connect with jumper wires?
If it's a separate board, what number do you see written on the crystal can?
We have used two termination resistors, one was setup externally and the other one is built internally with the module that we used. Do you have any ideas why we might have this issue, I am starting to think that Arduino CAN communication does not work with non-arduino controllers/peripherals.
We use an external CAN module (see the picture below). The number on the crystal is "8000". If you are interested, the number on the arduino crystal we used is "16000". Would the mismatch be the reason of failure?
That indicates a 8 MHz crystal, however the library assumes that you are using a 16 MHz crystal.
When using an 8 MHz crystal the documentation says you need to add
CAN.setClockFrequency(8E6);
before the
line
I have had different crystals on my CAN modules. I use Gary Fowler's mcp-can library and one of the first lines in setup is the crystal frequency. I also played around and would set it for 2x baud and it worked fine. If you cannot set the crystal frequency try 2x baud.
using mcp-can I set the CANbus baudrate and the crystal frequency
e.g. setting 250KBS on a Adafruit Feather RP2040 CAN (onboard MCP2515) which has a 16MHz crystal
 if (CAN0.begin(MCP_ANY, CAN_250KBPS, MCP_16MHZ) == CAN_OK)
    Serial.println("CAN Receive - MCP2515 Initialized Successfully!");
    Serial.println("Error Initializing MCP2515...");
That needs to be 8MHZ. CAN_250KBPS Needs to be the baud you want. You should get "
MCP2515 Initialized Successfully! when initializing, with or without a bus connected.
I missed some details - the board is a Adafruit Feather RP2040 CAN (with onboard MCP2515) which has a 16MHz crystal
when using a RP2040 with an external MCP2515 module the setup is
  if (CAN0.begin(MCP_ANY, CAN_250KBPS, MCP_8MHZ) == CAN_OK)
Set it to whatever the crystal is.
