issues with delaying servo from 0 to 45 degrees and vice versa
Hello I am new to arduino and I have a question regarding a servo delay issue that I am having. With the code I have I can go from 0 to 45 degrees and from 45 to 0 degrees. The problem that I am having is that I want it to once it goes from 0 to 45 degrees stop for a period of time and when it goes 45 to 0 degrees stop for a period of time. Code that I have worked on is below.
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
                // a maximum of eight servo objects can be created
int pos = 0;    // variable to store the servo position
  myservo.attach(9);  // attaches the servo on pin 9 to the servo object
  for(pos = 0; pos < 45; pos += 1)  // goes from 0 degrees to 45 degrees
  {                                 // in steps of 1 degree
    myservo.write(pos);              // tell servo to go to position in variable 'pos'
    delay(5);                        // waits 5ms for the servo to reach the position
    if(pos == 45)
      delay(100);
  for(pos = 45; pos>=1; pos-=1)     // goes from 45 degrees to 0 degrees
    if(pos == 0)
    delay (100);
Can you recognize the portion that makes the servo move from 0 to 45? Can you recognize the portion that makes the servo go from 45 to 0? Can you see where to put a delay(someAmountOfTime); between them?
When I commented out one portion and tested it there wasn't much difference on how the program was executed. I could see the delay difference though. I think I meant to say that I want to do -45 to 45 degrees instead of 0 to 45 degrees.
Really? Is your servo capable of moving to -45 degrees? Most aren't. And those that can are rarely smart enough to stop there.
Have you tried a delay between the two for loops?
Do you realize that delay(100) is for one tenth of a second?
The numbers are in milliseconds.
...R
if(pos == 0)
    delay (100);
Inside a loop where pos can never reach zero?
Not gonna happen.
Same (similar) for the other loop.
PaulS:
I wanted it to go from -45 to 45 degrees but for the servo that I am using that is not the case. It is more so in the 90 to 0 degree range to make the sweep motion that I want. I got it to delay like I want but now I want it to go from 90 degrees to the middle then from the middle to 0 degrees and vice versa.
AWOL:
if(pos == 0)
   delay (100);
Not gonna happen.
So I cant say if the position value is 0 degrees stay here for this amount of time?
Robin2:
...R
I do, I was just testing certain delay times, after I posted this code I tried it for 10000ms
Yes, you can. But the value needs to be one that is reached during the for loop.
But, since the for loop runs from 0 to 44, and you want the delay to happen at 45, AFTER the for loop is a better place to put the delay.
Yes, of course you can.
Just not in those loops.
Why bother with a test?
Just put the delay outside the loop.
(You shouldn't always believe what a comment tells you)
AWOL:
I'm trying to picture what your telling me because I go it to work with those loops. I'll post what I coded up, could you show me what you are referring to?
#include <Servo.h>
int pos = 52;    // variable to store the servo position
  for(pos = 52; pos < 90; pos += 1)  // goes from 52 degrees to 90 degrees
    delay(10);                        // waits 5ms for the servo to reach the position
   if(pos == 52)                     //At the middle wait for 1000ms
  for(pos = 52; pos > 0; pos-=1)     // goes from 52 degrees to 0 degrees
That's totally different to what you posted earlier
(Though the comments are still as wrong)
AWOL:
Yes, but the loops are still the same.
What don't you understand about "totally"?
AWOL:
I understand you don't have to be a jerk about it
So you don't see that the starting conditions of a loop are different to the end conditions?
AWOL:
I do see it that's why I understood what you said, before it didn't fit the parameters but now it does.
I see a sequence of words.
AWOL:
Ok man this is getting nowhere
