Hello everyone,
I am working on a project using the Arduino Giga R1, where I need to establish communication between the M7 and M4 processors. My goal is to have the M4 processor read values from four pressure sensors, process the data, and then send the values to the M7 processor. The M7 processor should then display these values—currently via the serial interface, but later through a graphical interface using LVGL.
The problem I am facing is that I am unable to transmit multiple integer values simultaneously using the RPC function. I have already tried different approaches, but none have worked as expected.
M4 Code:
#include <Arduino.h>
#include <RPC.h>
int counter = 0;
char pressure_string[30];
RPC.bind("get_pressure", get_pressure);
char *get_pressure() {
int values[4] = { 1000, 150, 1200, 300};
int current_pressure_melting_coarse = int(values[0] + counter);
int current_pressure_melting_fine = int(values[1] + counter);
int current_pressure_tower_coarse = int(values[2] + counter);
int current_pressure_tower_fine = int(values[3] + counter);
counter++;
snprintf(pressure_string, sizeof(pressure_string), "%d,%d,%d,%d",
current_pressure_melting_coarse, current_pressure_melting_fine, current_pressure_tower_coarse, current_pressure_tower_fine);
return pressure_string;
M7 Code:
#include <RPC.h>
#include <stdlib.h>
#include <string.h>
#include <stdio.h>
#include <MsgPack.h>
int current_pressure_melting_coarse = 0;
int current_pressure_melting_fine = 0;
int current_pressure_tower_coarse = 0;
int current_pressure_tower_fine = 0;
RPC.begin();
getPressure();
Serial.print("Melting Pressure coarse: ");
Serial.println(current_pressure_melting_coarse);
Serial.print("Melting Pressure fine: ");
Serial.println(current_pressure_melting_fine);
Serial.print("Tower Pressure coarse: ");
Serial.println(current_pressure_tower_coarse);
Serial.print("Tower Pressure fine: ");
Serial.println(current_pressure_tower_fine);
void getPressure() {
String data = String(RPC.call("get_pressure"));
int lastIndex = 0;
float values[4];
int index = 0;
for (int i = 0; i < data.length(); i++) {
if (data[i] == ',') {
String value = data.substring(lastIndex, i);
values[index] = value.toFloat();
index++;
lastIndex = i + 1;
// Letzten Wert auch hinzufügen
values[index] = data.substring(lastIndex).toFloat();
current_pressure_melting_coarse = values[0].as<int>();
current_pressure_melting_fine = values[1].as<int>();
current_pressure_tower_coarse = values[2].as<int>();
current_pressure_tower_fine = values[3].as<int>();
I would appreciate any advice or suggestions on how to properly send and receive multiple integer values between the two cores using RPC.
Thanks in advance for your help!
