I am planning to provide multiple GPS coordinates for the code below, and iterate through these points. As I get to each location, I want the LED to come on for 60 seconds (delay).
The code for this single location works.
I have searched on google, and it is possible to do this using for/loop command.
I don't know how to implement it on this code. Can somebody help me?
#include <TinyGPS++.h>
#include <SoftwareSerial.h>
static const int RXPin = 4, TXPin = 3;
static const uint32_t GPSBaud = 9600;
// The TinyGPS++ object
TinyGPSPlus gps;
// The serial connection to the GPS device
SoftwareSerial ss(RXPin, TXPin);
// For stats that happen every 5 seconds
unsigned long last = 0UL;
int ledPin = 13;
ss.begin(GPSBaud);
pinMode(ledPin, OUTPUT);
// Dispatch incoming characters
while (ss.available() > 0)
gps.encode(ss.read());
if (gps.location.isUpdated())
Serial.print(F(" Lat="));
Serial.print(gps.location.lat(), 6);
Serial.print(F(" Long="));
Serial.println(gps.location.lng(), 6);
Serial.print(F(" course="));
Serial.println(gps.course.deg());
else if (millis() - last > 5000)
if (gps.location.isValid())
// replace 'Dest_LAT' and 'Dest_LON' values basedon your location
// you can find Latitude and Longitude from Read_Lat_Lng.ino
static const double Dest_LAT = 38.210169, Dest_LON = -75.689734;
double distanceToDest =
TinyGPSPlus::distanceBetween(
gps.location.lat(),
gps.location.lng(),
Dest_LAT,
Dest_LON);
double courseTo =
TinyGPSPlus::courseTo(
gps.location.lat(),
gps.location.lng(),
Dest_LAT,
Dest_LON);
Serial.print(F("Distance to Destination ="));
Serial.print(distanceToDest/1000, 6); // *Prints distance to destination
Serial.print("Course to Destination: ");
Serial.println(courseTo);
if(distanceToDest/1000 < 6.050000) //Here when distanceToDest/1000 is less than 0.050000 LED turns on . So change *distance to destination as per your requirement.
digitalWrite(ledPin, HIGH);
digitalWrite(ledPin, LOW);
if (gps.charsProcessed() < 10)
Serial.println(F("WARNING: No GPS data. Check wiring."));
last = millis();
I want to use this system for point to point navigation. It is after I have gotten to Destination A, before the system should do the computation for Destination B,... and so on. That is, as I am moving, I only care about the next point.
Using @jremington method, I have the code looping through all the points without stopping.
I added a delay, but that didn't help.
While I was at Destination B, it was computing distances for Destinations C, D, E, back to A, B; and accordingly turning the LED on or off.
Finally, when I get to destination E, I want to break the loop.
Keep a global variable that points to the current destination. When you reach that destination, increment the global variable.
Note: Unless you plan to keep the Arduino powered on for the entire set of journeys, you should probably store the 'index' in EEPROM so you can continue with the same destination after a power cycle.
#include <EEPROM.h>
struct LatLon
double Lat;
double Lon;
static const LatLon LatLonList[] =
{38.210169, -75.689734},
{23.424076, 53.847818}, // United Arab Emirates
{33.93911, 67.709953}, // Afghanistan
{41.153332, 20.168331}, // Albania
{40.069099, 45.038189}, // Armenia
const int LatLonCount = sizeof LatLonList / sizeof LatLonList[0];
byte Index = 0;
TinyGPSPlus gps;
int ledPin = 13;
ss.begin(GPSBaud);
EEPROM.get(0, Index);
if (Index >= LatLonCount)
Index = 0;
gps.location.lat(),
gps.location.lng(),
LatLonList[Index].Lat,
LatLonList[Index].Lon);
double courseTo =
gps.location.lat(),
gps.location.lng(),
Serial.print(distanceToDest / 1000, 6); // *Prints distance to destination
Serial.print(" Course to Destination: ");
if (distanceToDest / 1000 < 6.050000) //Here when distanceToDest/1000 is less than 0.050000 LED turns on . So change *distance to destination as per your requirement.
// We have arrived.
Index++;
delay(10000);
Index = 0; // Start over when we run out of destinations
EEPROM.put(0, Index);
last = millis();
Please accept my apologies. Both codes you wrote, worked as expected. I had been doing a poor job fitting it into my project which included codes for a compass, and Wireless Nrf24l01.
I think the "one new fix every 10 seconds" might be a setting in the GPS module. You will need to find documentation for your particular GPS module and learn how to set the update rate.
