"itoa" was not declared in this scope
Hi. I have really interesting problem here. When using Arduino Uno, this code uploads without a problem, but when I try to uplod it to STM32F103C8T6, it makes error ---"itoa" was not declared in this scope ---. Unable to find solution I am asking for you help. Thanks
* Project: MAXREFDES117#
* Filename: RD117_ARDUINO.ino
* Description: This module contains the Main application for the MAXREFDES117 example program.
* Revision History:
*\n 1-18-2016 Rev 01.00 GL Initial release.
*\n 12-22-2017 Rev 02.00 Significantlly modified by Robert Fraczkiewicz
*\n 08-22-2018 Rev 02.01 Added conditional compilation of the code related to ADALOGGER SD card operations
* This code follows the following naming conventions:
* char              ch_pmod_value
* char (array)      s_pmod_s_string[16]
* float             f_pmod_value
* int32_t           n_pmod_value
* int32_t (array)   an_pmod_value[16]
* int16_t           w_pmod_value
* int16_t (array)   aw_pmod_value[16]
* uint16_t          uw_pmod_value
* uint16_t (array)  auw_pmod_value[16]
* uint8_t           uch_pmod_value
* uint8_t (array)   auch_pmod_buffer[16]
* uint32_t          un_pmod_value
* int32_t *         pn_pmod_value
#include <ctype.h>
#include <stdlib.h>
#include <Arduino.h>
#include <Wire.h>
#include <SPI.h>
#include "algorithm_by_RF.h"
#include "max30102.h"
#define DEBUG // Uncomment for debug output to the Serial stream
//#define USE_ADALOGGER // Comment out if you don't have ADALOGGER itself but your MCU still can handle this code
//#define TEST_MAXIM_ALGORITHM // Uncomment if you want to include results returned by the original MAXIM algorithm
//#define SAVE_RAW_DATA // Uncomment if you want raw data coming out of the sensor saved to SD card. Red signal first, IR second.
/*#ifdef USE_ADALOGGER
  #include <SD.h>
#endif
/*#ifdef TEST_MAXIM_ALGORITHM
  #include "algorithm.h"
#endif
// Interrupt pin
const byte oxiInt = PB8; // pin connected to MAX30102 INT
// ADALOGGER pins
  File dataFile;
  const byte chipSelect = 4;
  const byte cardDetect = 7;
  const byte batteryPin = 9;
  const byte ledPin = 13; // Red LED on ADALOGGER
  const byte sdIndicatorPin = 8; // Green LED on ADALOGGER
  bool cardOK;
#endif*/
uint32_t elapsedTime,timeStart;
uint32_t aun_ir_buffer[BUFFER_SIZE]; //infrared LED sensor data
uint32_t aun_red_buffer[BUFFER_SIZE];  //red LED sensor data
float old_n_spo2;  // Previous SPO2 value
uint8_t uch_dummy,k;
  pinMode(oxiInt, INPUT);  //pin D10 connects to the interrupt output pin of the MAX30102
  pinMode(cardDetect,INPUT_PULLUP);
  pinMode(batteryPin,INPUT);
  pinMode(ledPin,OUTPUT);
  digitalWrite(ledPin,LOW);
  pinMode(sdIndicatorPin,OUTPUT);
  digitalWrite(sdIndicatorPin,LOW);
#endif  */
  Wire.begin();
#if defined(DEBUG) || !defined(USE_ADALOGGER)
  // initialize serial communication at 115200 bits per second:
#endif
  maxim_max30102_reset(); //resets the MAX30102
  maxim_max30102_read_reg(REG_INTR_STATUS_1,&uch_dummy);  //Reads/clears the interrupt status register
  maxim_max30102_init();  //initialize the MAX30102
  old_n_spo2=0.0;
    // Measure battery voltage
  float measuredvbat = analogRead(batteryPin);
  measuredvbat *= 2;    // we divided by 2, so multiply back
  measuredvbat *= 3.3;  // Multiply by 3.3V, our reference voltage
  measuredvbat /= 1024; // convert to voltage
  char my_status[20];
  if(HIGH==digitalRead(cardDetect)) {
    // we'll use the initialization code from the utility libraries
    // since we're just testing if the card is working!
    if(!SD.begin(chipSelect)) {
      cardOK=false;
      strncpy(my_status,"CardInit!",9);
    } else cardOK=true;
    cardOK=false;
    strncpy(my_status,"NoSDCard!",9);
  if(cardOK) {
    long count=0;
    char fname[20];
    do {
//      if(useClock && now.month()<13 && now.day()<32) {
//        itoa(fname,"%d-%d_%d.txt",now.month(),now.day(),++count);
//      } else {
        itoa(fname,"data_%d.txt",++count);
    } while(SD.exists(fname));
    dataFile = SD.open(fname, FILE_WRITE);
    strncpy(my_status,fname,19);
#ifdef DEBUG
  while(Serial.available()==0)  //wait until user presses a key
    Serial.print(F("Vbatt=\t"));
    Serial.println(measuredvbat);
    Serial.println(my_status);
    Serial.println(dataFile,HEX);
    Serial.println(F("Press any key to start conversion"));
  uch_dummy=Serial.read();
#endif
  blinkLED(ledPin,cardOK);
  k=0;
  dataFile.println(F("Vbatt=\t"));
  dataFile.println(measuredvbat);
  dataFile.println(my_status);
  dataFile.print(F("Time[s]\tSpO2\tHR\tSpO2_MX\tHR_MX\tClock\tRatio\tCorr"));
#else // TEST_MAXIM_ALGORITHM
  dataFile.print(F("Time[s]\tSpO2\tHR\tClock\tRatio\tCorr"));
#endif // TEST_MAXIM_ALGORITHM
#ifdef SAVE_RAW_DATA
  int32_t i;
  // These are headers for the red signal
  for(i=0;i<BUFFER_SIZE;++i) {
    dataFile.print("\t");
    dataFile.print(i);
  // These are headers for the infrared signal
    dataFile.print(i);
#endif // SAVE_RAW_DATA
  dataFile.println("");
#else // USE_ADALOGGER
    delay(2000);
  Serial.print(F("Time[s]\tSpO2\tHR\tSpO2_MX\tHR_MX\tClock\tRatio\tCorr"));
  Serial.print(F("Time[s]\tSpO2\tHR\tClock\tRatio\tCorr"));
  int32_t i;
    Serial.print("\t");
    Serial.print(i);
    Serial.print("\t");
    Serial.print(i);
  Serial.println("");
#endif // USE_ADALOGGER
  timeStart=millis();
//Continuously taking samples from MAX30102.  Heart rate and SpO2 are calculated every ST seconds
  float n_spo2,ratio,correl;  //SPO2 value
  int8_t ch_spo2_valid;  //indicator to show if the SPO2 calculation is valid
  int32_t n_heart_rate; //heart rate value
  int8_t  ch_hr_valid;  //indicator to show if the heart rate calculation is valid
  int32_t i;
  char hr_str[10];
  //buffer length of BUFFER_SIZE stores ST seconds of samples running at FS sps
  //read BUFFER_SIZE samples, and determine the signal range
  for(i=0;i<BUFFER_SIZE;i++)
    while(digitalRead(oxiInt)==1);  //wait until the interrupt pin asserts
    maxim_max30102_read_fifo((aun_ir_buffer+i), (aun_red_buffer+i));  //read from MAX30102 FIFO
#ifdef DEBUG
    Serial.print(i, DEC);
    Serial.print(F("\t"));
    Serial.print(aun_red_buffer[i], DEC);
    Serial.print(aun_ir_buffer[i], DEC);
    Serial.println("");
#endif // DEBUG
  //calculate heart rate and SpO2 after BUFFER_SIZE samples (ST seconds of samples) using Robert's method
  rf_heart_rate_and_oxygen_saturation(aun_ir_buffer, BUFFER_SIZE, aun_red_buffer, &n_spo2, &ch_spo2_valid, &n_heart_rate, &ch_hr_valid, &ratio, &correl);
  elapsedTime=millis()-timeStart;
  millis_to_hours(elapsedTime,hr_str); // Time in hh:mm:ss format
  elapsedTime/=1000; // Time in seconds
#ifdef DEBUG
  Serial.println("--RF--");
  Serial.print(elapsedTime);
  Serial.print(" \t  ");
  Serial.print(n_spo2);
  Serial.print(n_heart_rate, DEC);
  Serial.println(hr_str);
  Serial.println(" ");
#endif // DEBUG
  //calculate heart rate and SpO2 after BUFFER_SIZE samples (ST seconds of samples) using MAXIM's method
  float n_spo2_maxim;  //SPO2 value
  int8_t ch_spo2_valid_maxim;  //indicator to show if the SPO2 calculation is valid
  int32_t n_heart_rate_maxim; //heart rate value
  int8_t  ch_hr_valid_maxim;  //indicator to show if the heart rate calculation is valid
  maxim_heart_rate_and_oxygen_saturation(aun_ir_buffer, BUFFER_SIZE, aun_red_buffer, &n_spo2_maxim, &ch_spo2_valid_maxim, &n_heart_rate_maxim, &ch_hr_valid_maxim);
#ifdef DEBUG
//  Serial.println("--MX--");
  Serial.print(n_spo2_maxim);
  Serial.print("  qwe   ");
  Serial.print(n_heart_rate_maxim, DEC);
 Serial.print("\t");
  //Serial.println("------");
#endif // DEBUG
  //save samples and calculation result to SD card
  if(ch_hr_valid && ch_spo2_valid || ch_hr_valid_maxim && ch_spo2_valid_maxim) {
  if(ch_hr_valid && ch_spo2_valid) {
    ++k;
    dataFile.print(elapsedTime);
    dataFile.print("\tt");
    dataFile.print(n_spo2);
    dataFile.print(n_heart_rate, DEC);
    dataFile.print(n_spo2_maxim);
    dataFile.print(n_heart_rate_maxim, DEC);
    dataFile.print(hr_str);
    dataFile.print(ratio);
    dataFile.print(correl);
    // Save raw data for unusual O2 levels
      dataFile.print(F("\t"));
      dataFile.print(aun_red_buffer[i], DEC);
      dataFile.print(aun_ir_buffer[i], DEC);
     // Blink green LED to indicate save event
    digitalWrite(sdIndicatorPin,HIGH);
    delay(10);
    // FLush SD buffer every 10 points
    if(k>=10) {
      dataFile.flush();
      k=0;
    Serial.print("\t   ");
    Serial.flush();
#endif //TEST_MAXIM_ALGORITHM
   Serial.print(hr_str);
    Serial.print("\t");
    Serial.print(ratio);
    Serial.print("\t");
    Serial.print(correl);
    Serial.println("");
    old_n_spo2=n_spo2;
void millis_to_hours(uint32_t ms, char* hr_str)
  char istr[6];
  uint32_t secs,mins,hrs;
  secs=ms/1000; // time in seconds
  mins=secs/60; // time in minutes
  secs-=60*mins; // leftover seconds
  hrs=mins/60; // time in hours
  mins-=60*hrs; // leftover minutes
  itoa(hrs, hr_str, 10);
  strcat(hr_str,":");
  itoa(mins, istr, 10);
  strcat(hr_str,istr);
  strcat(hr_str,":");
  itoa(secs, istr, 10);
// blink three times if isOK is true, otherwise blink continuously
void blinkLED(const byte led, bool isOK)
  byte i;
  if(isOK) {
    for(i=0;i<3;++i) {
      digitalWrite(led,HIGH);
      delay(200);
      digitalWrite(led,LOW);
      delay(200);
    while(1) {
      for(i=0;i<2;++i) {
        delay(50);
        delay(50);
#endif
Hello,
You can use sprintf
https://www.cplusplus.com/reference/cstdlib/itoa/
This function is not defined in ANSI-C and is not part of C++, but is supported by some compilers.
A standard-compliant alternative for some cases may be sprintf
And the examples given are:
sprintf(str,"%d",value) converts to decimal base.
sprintf(str,"%x",value) converts to hexadecimal base.
sprintf(str,"%o",value) converts to octal base.
The 'sprintf' formatting codes give a lot of options, like adding arbitrary characters before and after, field width, and leading zeroes:
sprintf(str,"0x%02x",  byte_value):
sprintf(str,"0x%04x",  int_value):
Thanks for the help, I managed to find out correct way to fix it.
//itoa(hrs, hr_str, 10);
  hrs=sprintf(hr_str, "%d" , hrs);  //(str, "%d", value)
  strcat(hr_str,":");
//itoa(mins, istr, 10);
  mins=sprintf(istr, "%d", mins);
  strcat(hr_str,":");
//itoa(secs, istr, 10);
  secs=sprintf(istr, "%d", secs);
sprintf() is a lot more versatile than itoa(). It can include the colons and make the minutes and seconds fields two digits with leading zeros:
sprintf(hr_str, "%d:%02d:%02d" , hrs, mins, secs);
"%2d" would mean "Two digits, without leading zeroes".
"%02d" means "Two digits, with leading zeroes"
Thank you for the tips, it works fine now.
