I've problem with MPU-6050
When i verify this code, arduino send this error message:
fatal error: I2Cdev.h: No such file or directory
compilation terminated.
Please help me, thanks.
This is the code:
#include <Wire.h>
#include<I2Cdev.h>
#include<MPU6050.h>
MPU6050 mpu;
int16_t ax, ay, az;
int16_t gx, gy, gz;
#define pin1 3
#define pin2 5
void setup(){
Serial.println("Initialize MPU");
mpu.initialize();
//Serial.println(mpu.testConnection() ? "Connected" : "Connection failed"); pinMode(pin1,OUTPUT);
pinMode(pin2,OUTPUT);
void loop(){
mpu.getMotion6(&ax, &ay, &az, &gx, &gy, &gz);
ax = map(ax, -17000, 17000, -1500, 1500);
//Serial.println(ax);
if(ax > 0){
if(ax<255){
Serial.println(ax);
analogWrite(pin2,ax);
else{
Serial.println("+255");
analogWrite(pin2,255);
if(ax<0){
if(ax>-255){
Serial.println(ax);
analogWrite(pin1, ax-ax-ax);
else{
Serial.println("-255");
analogWrite(pin1, 255);
You want us to help you find the library and download it? PM me, and I'll send you an address where you can mail your computer.
Search on the web for the I2Cdev library, download and install it.
