İyi günler Nrf modül kaç gb veri gönderebilir
Yes
Does the transfer need to be wireless?
Yes
The distance must be at least 15 meters
Can I send 1 GB of packet at a time to Arduino with a range of 15 meters? If I can send it, which module should I use? I would appreciate it if you could give detailed information.
I moved your topic to an appropriate forum category @bty.
In the future, please take some time to pick the forum category that best suits the subject of your topic. There is an "About the _____ category" topic at the top of each category that explains its purpose.
This is an important part of responsible forum usage, as explained in the "How to get the best out of this forum" guide. The guide contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
Maybe, maybe not, rather depends on the application.
Perhaps describe the actual project like what is this 1GB of data and where is it coming from and going to, how long does it need to take, etc.
Actually, I meant how can I send 1 GB of data between two Arduinos?
I have merged your cross-posts @bty.
Cross-posting is against the Arduino forum rules. The reason is that duplicate posts can waste the time of the people trying to help. Someone might spend a lot of time investigating and writing a detailed answer on one topic, without knowing that someone else already did the same in the other topic.
Repeated cross-posting can result in a suspension from the forum.
In the future, please only create one topic for each distinct subject matter. This is basic forum etiquette, as explained in the "How to get the best out of this forum" guide. It contains a lot of other useful information. Please read it.
we would too :slight_smile:
what's the exact problem you are trying to solve?
yes. Not sure what you would do with that or how long it would take, but technically you can send data...
any radio would do or if a wired connection is possible, then that's possible too (15m is a bit far for a direct Serial connection so some hardware would be required)
The choice of over the air or wired and the expected throughput and quality of transmission will guide the choice
You can use
  1. WiFi
  2. ISM
  3. BT
Will this be a fair competition if you don’t write the code yourself, but ask on the forum?
If you have sample code for the modules you mentioned, please send it. I have the capacity to play on it.
