Hi, I've been working on a project for a while and have so far been able to compile and upload the sketch without problems until last night. Suddenly I got a " exec: "avr-g++": executable file not found in $PATH " error, which I fixed following this website's instructions Technoblogy - Programming ATtinys with Arduino 1.6.8 [Updated]. Then after I could compile I got this:
java.lang.NullPointerException
at cc.arduino.packages.uploaders.SerialUploader.uploadUsingPreferences(SerialUploader.java:81)
at cc.arduino.UploaderUtils.upload(UploaderUtils.java:78)
at processing.app.Sketch.upload(Sketch.java:1186)
at processing.app.Sketch.exportApplet(Sketch.java:1160)
at processing.app.Sketch.exportApplet(Sketch.java:1132)
at processing.app.Editor$DefaultExportHandler.run(Editor.java:2409)
at java.lang.Thread.run(Thread.java:745)
If I knew what it meant it would help, but any help would be appreciated !!
No, I can't even upload the Blink sketch. I thought it was to do with the new IDE version and the core I use for ATtiny, but my older 1.6.4 version, which also worked, gives a different .lang error
As I have said the problem only occurred last night, before then I was able to upload and compile any sketch. I recently upgraded from 1.6.4 to 1.6.9 but it was working after the upgrade. My current JRE version is 8.0.920.14, which I believe is the newest version. According to Java it ran the updater at 00:05 this morning. I am using Win8.1 x64.
