JOYSTICK <> ARDUINO <> VB.NET
Hello everyone. I'm such as new in all this Arduino stuff. Recently I've been trying to figure out how to make a serial communication with a Joystick (http://www.elecfreaks.com/1999.html), with VB.NET. But unfortunately, I've been experimenting a lot of problems, and I'm really starting to become frustrated. Below I posted my codes, please, look at them and if you have some ideas to fix it, I'll really appreciate. Thanks.
//ARDUINO UNO <> INPUT JOYSTICK (5 DIGITAL INPUTS = 5 BUTTONS AND 2 ANALOG INPUTS= AXIS X and Y) <> SEND SERIAL DATA TO RECEIVE INTO VB.NET //
const byte PIN_BUTTON_SELECT = 9;
const byte PIN_BUTTON_RIGHT = 5;
const byte PIN_BUTTON_UP = 4;
const byte PIN_BUTTON_DOWN = 6;
const byte PIN_BUTTON_LEFT = 7;
const byte PIN_ANALOG_X = 0;
const byte PIN_ANALOG_Y = 1;
int valueX = 0;
int valueY = 0;
int vbNetIn = 0;
  pinMode(PIN_BUTTON_RIGHT, INPUT);
  digitalWrite(PIN_BUTTON_RIGHT, HIGH);
  pinMode(PIN_BUTTON_LEFT, INPUT);
  digitalWrite(PIN_BUTTON_LEFT, HIGH);
  pinMode(PIN_BUTTON_UP, INPUT);
  digitalWrite(PIN_BUTTON_UP, HIGH);
  pinMode(PIN_BUTTON_DOWN, INPUT);
  digitalWrite(PIN_BUTTON_DOWN, HIGH);
  pinMode(PIN_BUTTON_SELECT, INPUT);
  digitalWrite(PIN_BUTTON_SELECT, HIGH);
int treatValue(int data) {
  return (data * 9 / 1024) + 48;
case = Serial.read();
if (Serial.available()>0){
switch (vbNetIn){
  case 10:
      while (Serial.available() == 10){
      if (digitalRead(PIN_BUTTON_RIGHT) == LOW){
          Serial.println("10");
      else if (digitalRead(PIN_BUTTON_LEFT) == LOW){
          Serial.println("20");
      else if (digitalRead(PIN_BUTTON_UP) == LOW){
          Serial.println("30");
      else if (digitalRead(PIN_BUTTON_DOWN) == LOW){
          Serial.println("40");
      else if (digitalRead(PIN_BUTTON_SELECT) == LOW){
          Serial.println("50");
  case 20:
        while (Serial.available() == 20){
        valueX = analogRead(PIN_ANALOG_X);
        valueX = map (valueX, 0, 1023, 0, 100);
        String sx = String(valueX);
        Serial.println(sx);}
  case 30:
        while (Serial.available() == 30){
        valueY = analogRead(PIN_ANALOG_Y);
        valueY = map (valueY, 0, 1023, 100, 0); /*A put it in reverse, because the vertical scroll in VB.NET is from up to down, and I wanted from the "common" zero axis point.
        String sy = String(valueY);
        Serial.println(sy);}
  delay(30);
The main problem, is that apparently there are corrupted bytes, I don't really know, just when I run it with the digital reads, my form application in VB.NET doesn't work, but, when I run it without digital reads (buttons) and only the analog reads, it looks like works pretty good.
This one is my VB.NET code:
Imports System
Imports System.IO.Ports
Imports System.Threading
Imports System.ComponentModel
Public Class Form1
    Dim s As String
    Dim data As Integer
    Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
        SerialPort1.Open()
    End Sub
    Private Sub start_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles start.Click
        Timer1.Start()
    End Sub
    Private Sub Timer1_Tick(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Timer1.Tick
        comparison()    'If you quit this sub-rutine, you will see that apparently everything works fine, but whitin don't.
        axisX()
        axisY()
    End Sub
    Sub comparison()
        SerialPort1.Write(Chr(10))
        s = SerialPort1.ReadLine
        data = Integer.Parse(s)
        Select data
            Case 10
                TextBox2.Text = "UP"
            Case 20
                TextBox3.Text = "DOWN"
            Case 30
                TextBox4.Text = "RIGHT"
            Case 40
                TextBox5.Text = "LEFT"
            Case 50
                TextBox6.Text = "SELECT"
            Case Else
                TextBox3.Text = " "
                TextBox5.Text = " "
                TextBox2.Text = " "
                TextBox4.Text = " "
                TextBox6.Text = " "
        End Select
    End Sub
    Sub axisX()
        SerialPort1.Write(Chr(20))
        Try
            'TextBox1.Text = data
        Catch ex As Exception
        End Try
        If (data >= 0 AndAlso data <= 100)
            If (data >= 48 AndAlso data <= 51) Then
                data = 50
            End If
            HScrollBar1.Value = data
        End If
    End Sub
    Sub axisY()
        SerialPort1.Write(Chr(30))
        Try
            dato = Integer.Parse(s)
        End Try
        If (data >= 0 AndAlso data <= 100) Then
            If (data >= 48 AndAlso data <= 51) Then  'This one is jut to stabilize the fluctuant value,
                data = 50                                       'and put it exactly to half.
            End If
            VScrollBar1.Value = data
        End If
    End Sub
End Class
And finally this one below, is the form in VB.NET, the scrollbars depends from X and Y axis, and the 5 textbox in his property text, depends from pressed buttons in joystick. The textbox in the middle, is just a text to see the value of every single value input. And the button with "Start" is just to make a beggin of the communication, I think doesn't have a really function.
