Hi
Im working with a 5110 lcd and some sensors that provide information. (DHT22, engine crankcase oilcap termistor, etc.)
Information is provided in several "screens" and the movement among them is selected by a joystick.
Im a begginer so for my mental healthness, I will build the proyect (that my first idea) based on secuences. One secuence for each screen.
void secuence1()
void secuence2()
secuence1()
At this very moment at the end of each secuence there is a code that indicates by the joystick movement which is the secuence to move next.
Cons:
- I repeat almost the same code at the end of each secuence.
- While secuence is working the joystick is not responsive.
The second point is what now concerns me. Could you give any idea on how to make the joystick "available" at any time? Just an idea and I will work on it.
Please find the code below.
Thanks
//*******************************************librerias********************
#include <math.h>
#include <SPI.h>
#include <Adafruit_GFX.h>
#include <Adafruit_PCD8544.h>
#include "DHT.h"
// Software SPI (slower updates, more flexible pin options):
// pin 7 - Serial clock out (SCLK)
// pin 6 - Serial data out (DIN)
// pin 5 - Data/Command select (D/C)
// pin 4 - LCD chip select (CS)
// pin 3 - LCD reset (RST)
//****************************************DEFINICIÓN DE VARIABLES Y PINES
#define DHTPIN 2
#define DHTTYPE DHT22
Adafruit_PCD8544 display = Adafruit_PCD8544(7, 6, 5, 4, 3);
#define NUMFLAKES 10
#define XPOS 0
#define YPOS 1
#define DELTAY 2
DHT dht(DHTPIN, DHTTYPE);
int RGBb = 9; // led rgb azul
int RGBg =10; // led rgb verde
int RGBr = 11; // led rgb rojo
//********************************************Variables del joystick********************
long ejejoysty = A1;
long ejejoystx = A2;
int valorjoystx =0;//
pinMode (ejejoystx, INPUT);
pinMode (ejejoysty, INPUT);
display.begin();
display.setContrast(60);
dht.begin();
display.display(); // show splashscreen
delay(2000); // Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
display.clearDisplay(); // clears the screen and buffer
// Reading temperature or humidity takes about 250 milliseconds!
display.setTextSize(1);
display.setTextColor(BLACK);
display.setCursor(0,20);
delay(2500);
float Termistor() {
float Temp;
Temp = log(((1024L*10000L/analogRead(0)) - 10000L));
Temp = 1 / (0.001606355783 + (0.0002632458140 * Temp) + (-0.0000001658963196 * Temp * Temp * Temp));
Temp = Temp - 273.15; // Convert Kelvin to Celcius
return Temp;
//********************************************************SECUENCIAS************************
void secuencia1temphumedad(){ //******************************SECUENCIA 1*******secuencia1temphumedad**************************
for (int m=0;m<100;m++){
float h = dht.readHumidity();
// Read temperature as Celsius (the default)
float t = dht.readTemperature();
// Read temperature as Fahrenheit (isFahrenheit = true)
//float f = dht.readTemperature(true);
delay(4000);
// text display tests
display.setCursor(0,10);
display.print("Temp: ");
display.print(t);
display.println("C");
display.print("H%: ");
display.print(h);
display.println("%");
Serial.print(analogRead(0)); //********************** comprobar R y Tª
Serial.println (" Comprobacion R Termistor");
Serial.print(Termistor(),2); //Comprobar T Motor
Serial.println (" Comprobacion T Motor"); //------------comprobar R y Tª
display.print("Motor:");
display.print(Termistor(),2);
display.setCursor(50,0);
display.print(m);
display.display();
//******Si la temperatura es inferior hay riesgo de hielo (parpadeo de Led azul)
if (Termistor(),2 < 25.50) {
for (int a=0;a<=253;a++)
analogWrite (RGBb,a);
delay(4);
for (int a=254;a>=0;a--)
delay(3);
delay(2000);
//*****************************************************comprobar movimiento Joystick******
valorjoystx = analogRead (ejejoystx); //valor del eje x de 0 a 1023
Serial.print(valorjoystx); // para comprobar en serial monitor que los valores del eje se mueven
Serial.println(" valor ejex"); // para comprobar en serial monitor que los valores del eje se mueven
// ahora planteo que el eje se mueva a un lado o a otro
// A derecha
if(valorjoystx<=200){// caso contrario, si el joystick lo muevo al inicio de su recorrido los leds se encienden en sentido contrario
analogWrite (11,254); // se enciende el led rojo para indicar que sale de secuencia1temphumedad
digitalWrite (11,0);
display.display();
secuencia2motor(); //************************************* SECUENCIA 2*************secuencia2motor*****
void secuencia2motor(){
Serial.println (" secuencia2");
analogWrite (10,254); // lez verde para indicar que ha llegado a secuencia2motor
digitalWrite (10,0);
display.print(m);
display.display();
Serial.println(" valor ejex--------------"); // para comprobar en serial monitor que los valores del eje se mueven
if(valorjoystx>=1000) {
delay(4);
delay(3);
delay(2000);
secuencia1temphumedad();
