Joystick Controlling LED's
I have a line of 8 LED's that I am trying to control with a joystick that can turn a series of 3 LED's on at a time. I am also trying to have a "kill switch" that when the button of the joystick is pushed it turns all the lights off. I can accomplish the previous two configurations separately but when I try to combine the sketches I am not successful. In a sketch where I just want to turn LED's on and off by the push of the button I am successful and the LED's stay on or off. When I add that sketch to my joystick sketch the button flips between 0 and 1 and stays in said true or false state but the lights will only turn off if I hold the button instead of clicking the button to turn on or off.
int sensorPin = A0;
int ledPins2 = 2;
int ledPins3 = 3;
int ledPins4 = 4;
int ledPins5 = 5;
int ledPins6 = 6;
int ledPins7 = 7;
int ledPins8 = 8;
int ledPins9 = 9;
int sensorValue = 0;
int ButtonValue = 10;
int status = true;
pinMode(ledPins2, OUTPUT);
pinMode(ledPins3, OUTPUT);
pinMode(ledPins4, OUTPUT);
pinMode(ledPins5, OUTPUT);
pinMode(ledPins6, OUTPUT);
pinMode(ledPins7, OUTPUT);
pinMode(ledPins8, OUTPUT);
pinMode(ledPins9, OUTPUT);
pinMode(ButtonValue, INPUT_PULLUP);
digitalWrite(ledPins2, HIGH);
digitalWrite(ledPins3, HIGH);
digitalWrite(ledPins4, HIGH);
digitalWrite(ledPins5, HIGH);
digitalWrite(ledPins6, HIGH);
digitalWrite(ledPins7, HIGH);
digitalWrite(ledPins8, HIGH);
digitalWrite(ledPins9, HIGH);
sensorValue = analogRead(sensorPin);
Serial.print("Potentiometer = ");
Serial.print(sensorValue);
Serial.print(" Button Value = ");
Serial.println(status);
delay(100);
if (digitalRead(ButtonValue) == false) {
status = !status;
} while(digitalRead(ButtonValue) == false);{
if (sensorValue >=0 && sensorValue <172){
//turn the ledPin on
digitalWrite(ledPins2, LOW);
digitalWrite(ledPins3, LOW);
digitalWrite(ledPins4, LOW);
if (sensorValue >= 172 && sensorValue <342){
digitalWrite(ledPins5, LOW);
if (sensorValue >= 342 && sensorValue <512){
digitalWrite(ledPins6, LOW);
if (sensorValue >= 512 && sensorValue <682){
digitalWrite(ledPins7, LOW);
if (sensorValue >= 682 && sensorValue <852){
digitalWrite(ledPins8, LOW);
if (sensorValue >= 852 && sensorValue <1024){
digitalWrite(ledPins9, LOW);
You should format your code and post it in a <CODE> block. To do this, click the <CODE> button, and paste your code between the three backticks, over the words that say:
type or paste your code here
It should look like this... and here is your answer...
    status = !status;
const byte sensorPin = A0;
const byte ledPins2 = 2;
const byte ledPins3 = 3;
const byte ledPins4 = 4;
const byte ledPins5 = 5;
const byte ledPins6 = 6;
const byte ledPins7 = 7;
const byte ledPins8 = 8;
const byte ledPins9 = 9;
const byte ButtonPin = 10;
bool status = true;
pinMode(ButtonPin, INPUT_PULLUP);
status = !status;
Serial.println("Killed");
delay(100);
if (status) {
int sensorValue = analogRead(sensorPin);
if ( sensorValue < 172) {
} else if (sensorValue < 342) {
} else   if (sensorValue < 512) {
} else if (sensorValue < 682) {
} else if ( sensorValue < 852) {
more properly formatted
        if (sensorValue >=0 && sensorValue <172)  {
is there an extra ';'?
  • using an array of LED pins could significantly reduce the size of the program
not quite what you're doing.
const byte PinButton  = 10;
const byte PinLeds [] = { 2, 3, 4, 5, 6, 7, 8, 9, 10 };
const byte PinSensor = A0;
const int  Nled      = sizeof(PinLeds);
byte butState;
bool status;
enum { Off = HIGH, On = LOW };
void
ledsOn (
    int idx )
    for (int n = 0; n < Nled; n++)  {
        if (n == idx)
            digitalWrite (PinLeds [n], On);
            digitalWrite (PinLeds [n], Off);
void loop ()
    // monitor button press
    byte but = digitalRead (PinButton);
    if (butState != but)  {
        butState  = but;
        delay (20);
        if (LOW == but)
            status = !status;
    if (! status)  {
        ledsOn (-1);
        return;
    int sensorValue = analogRead (PinSensor);
    Serial.println (sensorValue);
    ledsOn (sensorValue * Nled / 400);
    delay (500);
    pinMode (PinButton, INPUT_PULLUP);
    butState = digitalRead (PinButton);
        pinMode      (PinLeds [n], OUTPUT);
Hi @elecarchitect,
here is a formatted version of your sketch:
int sensorPin = A0;
int ledPins2 = 2;
int ledPins3 = 3;
int ledPins4 = 4;
int ledPins5 = 5;
int ledPins6 = 6;
int ledPins7 = 7;
int ledPins8 = 8;
int ledPins9 = 9;
int status = true;
  delay(100);
    status = !status;
  } while (digitalRead(ButtonValue) == false); {
    if (sensorValue >= 0 && sensorValue < 172) {
    if (sensorValue >= 172 && sensorValue < 342) {
    if (sensorValue >= 342 && sensorValue < 512) {
    if (sensorValue >= 512 && sensorValue < 682) {
    if (sensorValue >= 682 && sensorValue < 852) {
    if (sensorValue >= 852 && sensorValue < 1024) {
I have created a Wokwi version of your application:
https://wokwi.com/projects/410824037311785985
and also an updated version that might do what you intend to do:
https://wokwi.com/projects/410824564717321217
Sketch:
  Forum: https://forum.arduino.cc/t/joystick-controlling-leds/1307844
  Wokwi: https://wokwi.com/projects/410824564717321217
  Original Version see Wokwi: https://wokwi.com/projects/410824037311785985
const byte buttonPin = 10;
const byte minLedPin = 2;
const byte maxLedPin = 9;
int oldSensorValue = -1;
byte status = false;
  pinMode(buttonPin, INPUT_PULLUP);
  for (int i = minLedPin; i <= maxLedPin; i++) {
    pinMode(i, OUTPUT);
  allLedsOn();
  checkButton();
  handleSensor();
void setLeds(byte fromPin, byte toPin, byte state) {
  for (int i = fromPin; i <= toPin; i++) {
    digitalWrite(i, state);
void allLedsOff(){
 setLeds(minLedPin, maxLedPin, LOW);
void allLedsOn(){
 setLeds(minLedPin, maxLedPin, HIGH);
void checkButton() {
  static unsigned long lastChange = 0;
  static byte state = HIGH;
  static byte lastState = HIGH;
  byte actState = digitalRead(buttonPin);
  if (actState != lastState) {
    lastChange = millis();
    lastState = actState;
  if (state != actState && millis() - lastChange > 30) {
    state = actState;
    if (state == LOW) {
      status = !status;
      if (status) {
void handleSensor() {
  if (status) {
    return;
  if (sensorValue != oldSensorValue) {
    oldSensorValue = sensorValue;
    Serial.println(sensorValue);
    handleLeds();
void handleLeds() {
  static byte oldMode = 255;
  byte mode = 0;
  if (sensorValue >= 172) {
    mode = 1;
  if (sensorValue >= 342)  {
    mode = 2;
  if (sensorValue >= 512) {
    mode = 3;
  if (sensorValue >= 682) {
    mode = 4;
  if (sensorValue >= 852) {
    mode = 5;
  if (mode != oldMode){
    oldMode = mode;
    allLedsOn();
    setLeds(minLedPin+mode,minLedPin+mode+2,LOW);
It's just one of many possibility to solve the issue ...
Have fun!
ec2021
Complete re-writes are a solutions to changing one series of HIGHs to LOWs?
A tree can hide in a forest.
