I'm working on a project where a user presses a button connected to a Sparkfun Redboard which sends a trigger character over UART to an Openscale. When the Openscale recieves the trigger character (.println()) it takes a reading from a loadcell, and sends it to the Redboard over UART with a delimiter character ('>') and the Redboard displays the reading on an I2C Alphanumeric display.
Everything is working as it should so far with the exception of a quirk I can't figure out. The first reading displays correctly- only the segments needed to display the reading are used; however, on any subsequent reading, any unused segments are turned on, in addition to the displayed reading. This behavior continues until the board is power cycled. See pictures below:
First readings
Anything after first reading
I've been through the library and have tried combinations of functions that make sense; E.g. .clear(), .displayOff() What am I missing?
Code
#include <Wire.h>
#include <SparkFun_Alphanumeric_Display.h>
#include <SoftwareSerial.h> // library for emulating UART on other pins while monitoring serial from USB
SoftwareSerial portOne(10, 11); // RX = 10, TX = 11
HT16K33 display; // Sparkfun Qwiic alphanumeric display
//constants
const byte rButton = 2; // button for taking reading from loadcell
//variable
int rLast = HIGH; // debounce; previous state of reading button
int rCurrent; // debounce; current state of reading button
unsigned long lastDebounce = 0; // last time button state was toggled
int debounceDelay = 50; // how long to compare button press to for debounce
pinMode(rButton, INPUT_PULLUP); // tie button to ground. high = open / low = pressed
Serial.begin(9600); // start USB UART
portOne.begin(9600); // start software UART connected to OpenScale
Wire.begin();
if (display.begin() == false) // Check to see if screen is connected before continuing
Serial.println("Device did not acknowledge! Freezing.");
while (1)
Serial.println("Display acknowledged.");
if (portOne.available())
//Serial.println("Serial data available");
portOne.readStringUntil("/r");
portOne.flush();
Serial.write(portOne.read());
display.print(portOne.read());
// Listen for reading button and debounce
int reading = digitalRead(rButton); // poll reading button
if (reading != rLast) // if button changed due to noise or pressing
Serial.println("state change detected");
lastDebounce = millis(); // reset debounce timer
if ((millis() - lastDebounce) > debounceDelay) // if signal exists longer than debounce delay
if (reading != rCurrent) // if button state has changed
rCurrent = reading;
if (rCurrent == LOW) // if button is pressed
Serial.println("button is pressed"); //debug
portOne.println(); // send trigger character to Openscale to get reading
display.print("----");
display.clear();
display.clear();
if (portOne.available() > 0) // if openscale responds to request with weight
String incoming = portOne.readStringUntil('>'); // store recieved data until delimiter
Serial.println(incoming); // debug; print recieved weight from Openscale
display.print(incoming); // print weight recieved from Openscale
display.clear();
rLast = reading; // save reading. Will become rlast next time through loop
EDIT: Forgot to add code
