Just Curious, not fatal, extraneous LED on, Low priority
First of all I'm not sure where something like this goes. Are there dedicated 8266 categories? Anyway I'm tinkering with learning Interrupts. (Well actually learning/re-learning everything 8266.) I'm going to be monitoring relays etc. My original method was polling now wandering into Interrupts. My initial stab at this is monitoring the state of 7 buttons. It all works but for some unknown reason, well unknown to me, when I press the button associated with pin D4 while I hold down the button the built in LED lights. This doesn't happen with any other button. From the NodeMCU 12E pinout I see that D4 is also associated with TXD1 but the other pins are associated with other things as well. Like I mentioned just curious and low priority as other than the blue light on for D4 when LOW, it does what I've told it to do.
#define numRelays 7
const int relayPins[] = {D1, D2, D3, D4, D5, D6, D7};
volatile bool relayFlags[numRelays];// = {false, false,false, false,false, false, false};
volatile unsigned long lastDebounceTimes[numRelays];
bool currentRelayStates[numRelays]; // Array to store the current relay states
const unsigned long debounceDelay = 50; // Debounce delay in milliseconds
void IRAM_ATTR relayISR();
  //Initialize arrays and Interrupt handlers
  for (int i = 0; i < numRelays; i++) {
    relayFlags[i] = false;
    lastDebounceTimes[i] = 0;
    currentRelayStates[i] = HIGH;
    pinMode(relayPins[i], INPUT_PULLUP); // Set relay pins as input with internal pull-up resistors
    attachInterrupt(digitalPinToInterrupt(relayPins[i]), relayISR, CHANGE); // Attach interrupt
  Serial.println("ESP8266 ready");
  unsigned long currentTime = millis();
    if (relayFlags[i]) {
      if ((currentTime - lastDebounceTimes[i]) > debounceDelay) {
        bool state = digitalRead(relayPins[i]);
        if (state != currentRelayStates[i]) {
          currentRelayStates[i] = state; // Update the current state
          if (state == LOW) {
            Serial.print("Relay ");
            Serial.print(i+1);
            Serial.println(" activated!");
            Serial.print(i+1);
            Serial.println(" deactivated!");
void IRAM_ATTR relayISR() {
    relayFlags[i] = true;
    lastDebounceTimes[i] = currentTime; // Reset debounce timer
The on board LED's cathode is hooked up through a current limiting resistor to GPIO2. GPIO2 is D4. When you ground the D4 pin, you ground GPIO2, current flows thru the associated current limiting resistor and the LED, and the LED lights up. The same as if you made GPIO2/D4 an output and set t low.
Oh that makes sense that LED has to be hooked to something. Thanks!
