aparis1983:
My k-type thermocouple is giving me a reading that is roughly 5 degrees Fahrenheit higher than actual.
So, I've read that the accuracy can be up to +-6 C, and I also read that with most thermocouples the temperature voltage relationship is almost completely linear. Can anyone attest to this? If I just use an offset of -5 F, would I be ok for readings down to -70 F?
Why that low?
About a year ago I launched a high altitude balloon that, among a barrage of other sensors, had a DHT22 onboard. The sensor reached its lower limit of -40 degrees F. Therefore, my next balloon will have a thermocouple instead. Bit of an overkill? Not really, stratosphere temperatures reach about -65 to -70 degrees Fahrenheit (depends on time of year, latitude, altitude, etc.). So, a LM60 or a TMP36 would not work.
Any input, or tips on calibration are appreciated.
Andres
You are going to have to insulate the MAX6675 from the cold temperatures, it is only rated down to -20C, if your outside temp is -70F (-59C) you are outside the envelope for the MAX6675.
the 'Cold Junction' is where the K-type wires terminate. each connection of the thermocouple wires form a temperature sensor. So, A simple K-type has actually three thermocouple joints. One at the measurement point (welded Junction), one on the T+ junction, one on the T- Junction. The MAX6675 assumes the T+ and T- junction are at the same temperature as it's die. It (the MAX6675) uses an internal reference table to subtract it's temperature equivalent voltage from the voltage it is measuring from the K-type thermocouple. It then translates this 'corrected' voltage to the probe temperature.
assume the MAX6675 is at 15C and the Probe Junction is at -40C, the Raw voltage at the MAX6675 input is:
'cold Junction' 15C = 0.597mV
Probe (welded Joint) -40C = -1.527mV
Raw voltage at input of MAX6675 = -0.93mV or (-24C using K-Type conversion table for -0.93mV);
Correction factor because the MAX6675 measures it's internal temp of 15C= -0.597mV
Net Voltage after correction is -1.527mV (-40C)
Now lets say the 'cold Junction' is not actually at 15C, but because it is actually colder because it is not as well insulated, or has no active heating, or is in the airstream. And it's actual temperate is -20C.
Cold Junction at -20C = -0.778mV
Raw voltage at input of MAX6675 = -2.305mV (-62C )
Correction factor because the MAX6675 internal temp is 15C =-0.597mV
Net Voltage after correction is -2.902mV (-79.5C)
As this example shows, you need to make sure the 'cold junction' is at the same temperature as the MAX6675.
You should calibrate the sensor against a know reference, (freezing water, accurate thermometer).
Make sure the 'cold Junction' and the MAX6675 are at the same temperature, Insulate both in a common compartment.
There does not have to be any difference between the 'cold junction' temperature and the 'joint' temperature, BUT, there CANNOT be any temperature difference between the 'cold Junction' and the MAX6675.
Chuck.
