I am using the following code to display a digital clock using my arduino uno:
#include <Time.h>
#include <LiquidCrystal.h>
#define TIME_MSG_LEN 11 // time sync to PC is HEADER followed by Unix time_t as ten ASCII digits
#define TIME_HEADER 'T' // Header tag for serial time sync message
#define TIME_REQUEST 7 // ASCII bell character requests a time sync message
// T1262347200 //noon Jan 1 2010
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
int clockSet = 0;
lcd.begin(16, 2);
if(clockSet == 0)
if(Serial.available() )
processSyncMessage();
clockSet = 1;
digitalClockDisplay();
void digitalClockDisplay()
lcd.setCursor(1,0);
lcd.print(hour());
lcdPrintDigits(minute());
lcdPrintDigits(second());
void lcdPrintDigits(int digits){
// utility function for digital clock display: prints preceding colon and leading 0
lcd.print(":");
if(digits < 10)
lcd.print('0');
lcd.print(digits);
void processSyncMessage() {
// if time sync available from serial port, update time and return true
while(Serial.available() >= TIME_MSG_LEN ){ // time message consists of header & 10 ASCII digits
char c = Serial.read() ;
Serial.print(c);
if( c == TIME_HEADER ) {
time_t pctime = 0;
for(int i=0; i < TIME_MSG_LEN -1; i++){
c = Serial.read();
if( c >= '0' && c <= '9'){
pctime = (10 * pctime) + (c - '0') ; // convert digits to a number
setTime(pctime); // Sync Arduino clock to the time received on the serial port
Most of this is out of the example code for the time.h library. The problem is the clock loses about 2 minutes each day (i.e. it is 2 minutes slower than my computer clock). Any ideas on why this might be? I have cut down the code as much as I can such that it only calls processSyncMessage once (the first time I send the time to the arduino). I thought maybe executing processSyncMessage every time through the loop was slowing it down but that doesn't seem to be the case. Maybe I should change the delay to delayMicroseconds()?
Thanks.
