Hi! I'm incredibly new to programming in general, so please bear with me.
I'm working on a project and I want to incorporate an LED that flashes on 1 sec intervals after a push button is pressed, and the LED to keep flashing until the button is pressed again and the system turns off. I have a very simple code that I found online that triggers the LED to stay on when the button is pressed and off when pressed again. As well as the code that Arduino provides for blinking. But I have absolutely no idea how and if codes like these could be combined so that the system works as I want it to.
If you have any explanation, examples or guidance that I could use it would be very much appreciated!
In the Arduino IDE, use Ctrl T or CMD T to format your code then copy the complete sketch.
Use the </> icon from the ‘posting menu’ to attach the copied sketch.
Always show us a good schematic of your proposed circuit.
Show us a good image of your ‘actual’ wiring.
Give links to components.
This is the code that I have for toggle switch without blinking. The blinking one is the one Arduino provides.
int button = 2;
int led = 13;
int status = false;
pinMode(led, OUTPUT);
pinMode(button, INPUT_PULLUP);
if (digitalRead(button) == true) {
status = !status;
digitalWrite(led, status);
} while (digitalRead(button) == true);
delay(50);
This is more or less the circuit that I have physically and it seems to work just fine for the purpose it was intended.
Common LEDs need a current limiting resistor, 220R will be enough.
digitalRead(button) returns HIGH or LOW
Wire switches as S3 below and look for a LOW for switch closed/pressed.
Edit
#define OPENED HIGH
#define CLOSED LOW
#define LEDon HIGH
#define LEDoff LOW
#define ENABLED true
#define DISABLED false
const byte button = 2;
const byte LED = 13;
bool toggleFlag = DISABLED;
byte lastStatus = OPENED;
byte LEDstatus = LEDoff;
//timing stuff
const unsigned long toggleInterval = 1000ul;
unsigned long toggleMillis;
digitalWrite(LED, LEDoff);
pinMode(LED, OUTPUT);
pinMode(button, INPUT_PULLUP); //+5V---[Internal 50k]---[pin]---[switch]---GND
} //END of setup()
byte currentState = digitalRead(button);
//has the switch changed state ?
if (lastStatus != currentState)
//let the switch settle
delay(30);
//are still at the same level ?
if (digitalRead(button) == currentState)
//update to the new state
lastStatus = currentState;
//is the switch closed ?
if (currentState == CLOSED)
//if the TIMER is disabled, enable it now
if (toggleFlag == DISABLED)
//enable the TIMER
toggleFlag = ENABLED;
//restart the TIMER
toggleMillis = millis();
LEDstatus = LEDon;
digitalWrite(LED, LEDstatus);
//the TIMER was enabled, disable it now
//disable the TIMER
LEDstatus = LEDoff;
} //END of if (lastStatus != currentState)
//**************************************** L E D T I M E R
//if this TIMER is enabled, is it time to toggle the LED ?
if (toggleFlag == ENABLED && millis() - toggleMillis >= toggleInterval)
//restart the TIMER
//toggle the LED
LEDstatus = !LEDstatus;
} //END of loop()
