Keyboard Code Error Arduino
Hello everyone, can somebody help me fix my code, the error message says:
error message
// Standard Libraries
#include <Wire.h>
#include <Keyboard.h>
#include <Mouse.h> //there are some mouse move functions for encoder_Mode 2 and 3
int check_State = 0;
#include <Encoder.h>
Encoder RotaryEncoderB(14, 15); //the RIGHT encoder (encoder B)
#include <Keypad.h>
//Define the rols column matrix roots
const byte ROWS = 2; //two rows
const byte COLS = 4; //four columns
//define the physical matrix layout
char keys[ROWS][COLS] = {
{'1', '2', '3', 'B'}, // the keyboard hardware is a 2x4 grid...
{'5', '6', '7', '8'},
// The library will return the character inside this array when the appropriate
// button is pressed then look for that case statement. This is the key assignment lookup table.
// Layout(key/button order) looks like this
// | [6/5]* | *TRS breakout connection. Keys 5 and 6 are duplicated at the TRS jack
// | [1] [2] [3] [4] | * Encoder B location = Key[4]
// | [5] [6] [7] [8] |
// Variables that will change:
int modePushCounter = 0; // counter for the number of button presses
int buttonState = 0; // current state of the button
int lastButtonState = 0; // previous state of the button
int mouseMove;
String password; // string for rando password generator, its a global variable because i might do something fancy with it?
long positionEncoderA = -999; //encoderA LEFT position variable
long positionEncoderB = -999; //encoderB RIGHT position variable
const int ModeButton = A0; // the pin that the Modebutton is attached to
const int pot = A1; // pot for adjusting attract mode demoTime or mouseMouse pixel value
const int Mode1= A2;
const int Mode2= A3; //Mode status LEDs
byte rowPins[ROWS] = {4, 5}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {6, 7, 8, 9 }; //connect to the column pinouts of the keypad
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
void encoderB_Mode0(){
long newPos = RotaryEncoderB.read()/4; //When the encoder lands on a valley, most encoders use an increment of 4.
if (newPos != positionEncoderB && newPos > positionEncoderB) {
positionEncoderB = newPos;
Keyboard.press(KEY_DOWN_ARROW);
Keyboard.release(KEY_DOWN_ARROW); }
if (newPos != positionEncoderB && newPos < positionEncoderB) {
Keyboard.press(KEY_UP_ARROW);
Keyboard.release(KEY_UP_ARROW);                         }
void checkModeButton(){
buttonState = digitalRead(ModeButton);
if (buttonState != lastButtonState) { // compare the buttonState to its previous state
if (buttonState == LOW) { // if the state has changed, increment the counter
// if the current state is LOW then the button cycled:
modePushCounter++;
delay(50); // Delay a little bit to avoid bouncing
lastButtonState = buttonState; // save the current state as the last state, for next time through the loop
if (modePushCounter >3){ //reset counter after 4 presses (remember we start counting at 0) change this number to add more modes
modePushCounter = 0;}
void loop(){
char key = keypad.getKey();
mouseMove = (analogRead(pot)); //reading the analog input, pot = pin A1
mouseMove = map(mouseMove, 0,1023, 1,124); //remap the analog pot values fron 1 to 124
checkModeButton();
switch (modePushCounter) { // switch between keyboard configurations:
case 0: // Application Alpha or MODE 0 ========================================================================
encoderB_Mode0();
if (key) {
//Serial.println(key);
switch (key) {
case '2': Keyboard.press(KEY_LEFT_CTRL);
Keyboard.press(0x25);
  case '3': Keyboard.press(KEY_LEFT_CTRL);
            Keyboard.press(0x27);
            //4 is the encoder big man :)
  case '5': Keyboard.press(KEY_LEFT_SHIFT);
            Keyboard.press(KEY_RIGHT_CTRL);
  case '6': Keyboard.press(KEY_LEFT_GUI);
            Keyboard.press('r');
            Keyboard.release(KEY_LEFT_GUI);
            Keyboard.release('r');
            delay(50);
            Keyboard.println("cmd");
            break;}
  case '7': Keyboard.press(KEY_LEFT_ALT);
            Keyboard.print('0x46');
  case '8': Keyboard.press(KEY_LEFT_GUI);
            delay(50);
            Keyboard.println("calc");
delay(50); Keyboard.releaseAll(); // this releases the buttons
//=============Encoder B Function ====== Set 0 =========================================================
#define DEBUG
#define pinA 14
#define pinB 15
#define mutePin 11
bool isMutePressed = false;
bool isMuted = false;
bool ignoreMute = false;
#ifdef DEBUG
while (!Serial)
Serial.println("The setup starts");
#endif
    pinMode(pinA, INPUT);
    pinMode(pinB, INPUT);
    pinMode(mutePin, INPUT_PULLUP);
    Keyboard.begin();
if (!isMutePressed
&& digitalRead(mutePin) == LOW)
isMutePressed = true;
    if (digitalRead(pinA) == LOW)
            if (isMutePressed)
                    ignoreMute = true;
             ///clockwise
            if (digitalRead(pinB) != LOW)
#ifdef DEBUG
Serial.println("U");
#endif
Keyboard.press(0xDE);
delay(100);
                    if (isMutePressed)
#ifdef DEBUG
Serial.println("U2");
#endif
delay(100);
} else
#ifdef DEBUG
Serial.println("D");
#endif
Keyboard.press(0xBF);
delay(100);
                     if (isMutePressed)
#ifdef DEBUB
Serial.println("D2");
#endif
delay(100);
            //wait until rotation to next detent is complete
            while (digitalRead(pinA) != HIGH)
                    //debounce delay
                    delay(5);
    //mute button previoulsy pressed// ?~? //
    if (isMutePressed)
            //mute button now released?
            if (digitalRead(mutePin) == HIGH)
                    //resets flag and waits for a debounce interval
                    //should we ignore the mute request because
                    //we did a fast volume change?
                    if (ignoreMute)
                            //resets that flag but nothing else
                            ignoreMute = false;
                            Keyboard.press(0x77);
                            delay(100);
                            Serial.println(isMuted ? "Unmuted" : "Muted");
                            isMuted = !isMuted;
Looks like you are missing a '}' somewhere in your code.
You also have multiple declarations of several functions, including encoderB_Mode0() and loop().
You are using '0x46' where you mean 0x46 or '\x46' (you can't fit four characters into a character constant).
Please follow the advice given in the link below when posting code . Use code tags when posting code here to make it easier to read and copy for examination
