Keyboard.h not found on Arduino Micro and v2 IDE beta
Hello,
I am running into an odd issue. I am playing with an Arduino Micro-based device https://www.aliexpress.com/item/1005001392862719.html(, and I have it ...mostly working.
I am using beta 5 of the latest Arduino IDE, which on plugging the device in, detects it as being on comm3 and as being an Arduino Micro. On selecting the board I try to write an easy script which includes Keyboard.h, which according to the references I've seen should be available for micro, however, I get the rather cryptic error the IDE gives you when it can't find a library:
"C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-5A1B563C5978B2D51289338A3F6C27EC\\sketch\\sketch_may9a.ino.cpp" -o nul
Alternatives for Keyboard.h: []
ResolveLibrary(Keyboard.h)
  -> candidates: []
Compilation error: Error: 2 UNKNOWN: exit status 1
Given Keyboard.h should be included with the IDE rather than an external library, I'm not sure how to resolve this one? :slight_smile:
Thanks,
Your topic has been moved here as this forum section is more appropriate than where it was originally posted.
Hi @zersiax. The classic Arduino IDE comes with a collection of the most popular official libraries pre-installed. For this reason, we're used to having them always available, and many tutorials and documentation also make this assumption.
The Arduino IDE 2.x does not currently come with any libraries pre-installed. You must install any library your sketch requires.
Fortunately, this is very easy to do via Library Manager. Please do this:
  1. Select Sketch > Library > Manage Libraries... from the Arduino IDE's menus.
  2. In the "Filter your search..." field, type keyboard.
  3. Scroll down through the list of search results until you see "Keyboard by Arduino.
  4. Click the Install button.
  5. Wait for the installation to finish.
Now try compiling your sketch again.
Worked like a charm, thanks a lot :slight_smile:
Not related but worth mentioning, that portion of the IDE could use some accessibility TLC :slight_smile: For screenreader users, it is not clear you can (or need to) click the name of the name of the library for the Install button to become visible; only the "More info" link seems actionable at first glance :slight_smile:
Oh huh. So ...it compiled once, and then when I want to actually upload it, I got the following in the compile log:
Using board 'micro' from platform in folder: C:\Users\flori\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3
Using core 'arduino' from platform in folder: C:\Users\flori\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3
Detecting libraries used...
"C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MICRO -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8037 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Micro\"" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\micro" "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-4C91175DA25D18A0CD613413B19F7D5D\\sketch\\sketch_may9a.ino.cpp" -o nul
Alternatives for Keyboard.h: [Keyboard@1.0.2]
  -> candidates: [Keyboard@1.0.2]
"C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MICRO -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8037 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Micro\"" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\micro" "-IC:\\Users\\flori\\Documents\\Arduino\\libraries\\Keyboard\\src" "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-4C91175DA25D18A0CD613413B19F7D5D\\sketch\\sketch_may9a.ino.cpp" -o nul
Alternatives for HID.h: [HID@1.0]
ResolveLibrary(HID.h)
  -> candidates: [HID@1.0]
"C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MICRO -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8037 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Micro\"" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\micro" "-IC:\\Users\\flori\\Documents\\Arduino\\libraries\\Keyboard\\src" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\libraries\\HID\\src" "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-4C91175DA25D18A0CD613413B19F7D5D\\sketch\\sketch_may9a.ino.cpp" -o nul
"C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MICRO -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8037 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Micro\"" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\micro" "-IC:\\Users\\flori\\Documents\\Arduino\\libraries\\Keyboard\\src" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\libraries\\HID\\src" "C:\\Users\\flori\\Documents\\Arduino\\libraries\\Keyboard\\src\\Keyboard.cpp" -o nul
"C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MICRO -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8037 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Micro\"" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\micro" "-IC:\\Users\\flori\\Documents\\Arduino\\libraries\\Keyboard\\src" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\libraries\\HID\\src" "C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\libraries\\HID\\src\\HID.cpp" -o nul
Generating function prototypes...
"C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MICRO -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8037 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Micro\"" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\micro" "-IC:\\Users\\flori\\Documents\\Arduino\\libraries\\Keyboard\\src" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\libraries\\HID\\src" "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-4C91175DA25D18A0CD613413B19F7D5D\\sketch\\sketch_may9a.ino.cpp" -o "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-4C91175DA25D18A0CD613413B19F7D5D\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\builtin\\tools\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-4C91175DA25D18A0CD613413B19F7D5D\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MICRO -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8037 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Micro\"" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\micro" "-IC:\\Users\\flori\\Documents\\Arduino\\libraries\\Keyboard\\src" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\libraries\\HID\\src" "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-4C91175DA25D18A0CD613413B19F7D5D\\sketch\\sketch_may9a.ino.cpp" -o "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-4C91175DA25D18A0CD613413B19F7D5D\\sketch\\sketch_may9a.ino.cpp.o"
Compiling libraries...
Compiling library "Keyboard"
"C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MICRO -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8037 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Micro\"" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\micro" "-IC:\\Users\\flori\\Documents\\Arduino\\libraries\\Keyboard\\src" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\libraries\\HID\\src" "C:\\Users\\flori\\Documents\\Arduino\\libraries\\Keyboard\\src\\Keyboard.cpp" -o "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-4C91175DA25D18A0CD613413B19F7D5D\\libraries\\Keyboard\\Keyboard.cpp.o"
Compiling library "HID"
"C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MICRO -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8037 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Micro\"" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\micro" "-IC:\\Users\\flori\\Documents\\Arduino\\libraries\\Keyboard\\src" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\libraries\\HID\\src" "C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\libraries\\HID\\src\\HID.cpp" -o "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-4C91175DA25D18A0CD613413B19F7D5D\\libraries\\HID\\HID.cpp.o"
Compiling core...
Using precompiled core: C:\Users\flori\AppData\Local\Temp\arduino-core-cache\core_arduino_avr_micro_13a0c564ab1b5e36358b59463d3ffc97.a
Linking everything together...
"C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega32u4 -o "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-4C91175DA25D18A0CD613413B19F7D5D/sketch_may9a.ino.elf" "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-4C91175DA25D18A0CD613413B19F7D5D\\sketch\\sketch_may9a.ino.cpp.o" "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-4C91175DA25D18A0CD613413B19F7D5D\\libraries\\Keyboard\\Keyboard.cpp.o" "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-4C91175DA25D18A0CD613413B19F7D5D\\libraries\\HID\\HID.cpp.o" "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-4C91175DA25D18A0CD613413B19F7D5D/..\\arduino-core-cache\\core_arduino_avr_micro_13a0c564ab1b5e36358b59463d3ffc97.a" "-LC:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-4C91175DA25D18A0CD613413B19F7D5D" -lm
"C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-4C91175DA25D18A0CD613413B19F7D5D/sketch_may9a.ino.elf" "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-4C91175DA25D18A0CD613413B19F7D5D/sketch_may9a.ino.eep"
Using library Keyboard at version 1.0.2 in folder: C:\Users\flori\Documents\Arduino\libraries\Keyboard
Using library HID at version 1.0 in folder: C:\Users\flori\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\libraries\HID
Compilation error: Error: 2 UNKNOWN: exec: "C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy": file does not exist
Subsequent compilations of the same code , even when just verifying, now give the same output. Is this another library I missed? :slight_smile:
You're welcome.
When using a mouse, it appears on mouse over. I do usually say "click on it" when I'm giving instructions just because that's easier to explain than "hover over it", and older versions of the classic Arduino IDE did require a click.
But I understand that the situation may be different when using a screen reader. You are welcome to submit a formal report about this to the Arduino IDE developers here:
I did a search and didn't find anything about this problem in specific (though there are a few other reports of deficiencies when it comes to accessibility.
No. This is some problem with the build process itself. Part of the toolchain is missing for some reason.
This can happen if the Boards Manager installation fails. You can usually fix that by deleting the whole data folder and then reinstalling the boards platform (Arduino AVR Boards in this case).
  1. Close all Arduino IDE windows.
  2. Rename C:\Users\flori\AppData\Local\Arduino15 to C:\Users\flori\AppData\Local\Arduino15.backup (or you can just delete it if you aren't concerned with saving a copy of the previous contents.
  3. Start the Arduino IDE.
  4. Select Tools > Board > Boards Manager from the Arduino IDE's menus. This will open Boards Manager from the left side bar of the IDE.
  5. Scroll down through the list of available boards platforms in Boards Manager until you see "Arduino AVR Boards". Click on it.
  6. Click the Install button.
  7. Wait for the installation to finish.
Ok ...so there appears to be a pattern.
If I delete the data folder and restart the IDE, a popup will ask me to reinstall the board. Clicking "Yes" and subsequently verifying or uploading works, in the sense that I get an upload failed, but the compile does succeed.
Any compilation after that fails with the objcopy message, until I reinstall the tools again. It's almost like part of the toolchain gets deleted after first compilation.
Second interesting issue is that the upload does fail, in that I see the device disconnect, then reconnect, and I get an "blah.ino.hex failed" error, without too much else to go off even with verbose logs enabled. Do I need to do something specific before uploading to make that part work? Also, I realize this is getting a little off-topic, not sure how to handle that?
Ok, another progress report. I thought there was only a tiny bit of log, but that was , evidently, another accessibility issue. I have a full log, but something odd seems to be happening.
TLDR: In my previous message I said it looked like some of the files in the arduino15 data folder get deleted after a compilation. I have reason to believe the same may be happening to the final build output. After this log runs, it can't find sketch_name_here.hex, which makes sense, since that file isn't there. I see a .elf, but the .hex is missing. Here's the log:
"C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MICRO -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8037 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Micro\"" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\micro" "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\sketch\\sketch_may9a.ino.cpp" -o nul
"C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MICRO -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8037 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Micro\"" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\micro" "-IC:\\Users\\flori\\Documents\\Arduino\\libraries\\Keyboard\\src" "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\sketch\\sketch_may9a.ino.cpp" -o nul
"C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MICRO -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8037 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Micro\"" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\micro" "-IC:\\Users\\flori\\Documents\\Arduino\\libraries\\Keyboard\\src" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\libraries\\HID\\src" "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\sketch\\sketch_may9a.ino.cpp" -o nul
"C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MICRO -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8037 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Micro\"" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\micro" "-IC:\\Users\\flori\\Documents\\Arduino\\libraries\\Keyboard\\src" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\libraries\\HID\\src" "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\sketch\\sketch_may9a.ino.cpp" -o "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\builtin\\tools\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MICRO -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8037 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Micro\"" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\micro" "-IC:\\Users\\flori\\Documents\\Arduino\\libraries\\Keyboard\\src" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\libraries\\HID\\src" "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\sketch\\sketch_may9a.ino.cpp" -o "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\sketch\\sketch_may9a.ino.cpp.o"
"C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MICRO -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8037 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Micro\"" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\micro" "-IC:\\Users\\flori\\Documents\\Arduino\\libraries\\Keyboard\\src" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\libraries\\HID\\src" "C:\\Users\\flori\\Documents\\Arduino\\libraries\\Keyboard\\src\\Keyboard.cpp" -o "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\libraries\\Keyboard\\Keyboard.cpp.o"
"C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MICRO -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8037 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Micro\"" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\micro" "-IC:\\Users\\flori\\Documents\\Arduino\\libraries\\Keyboard\\src" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\libraries\\HID\\src" "C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\libraries\\HID\\src\\HID.cpp" -o "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\libraries\\HID\\HID.cpp.o"
Compiling core...
"C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -x assembler-with-cpp -flto -MMD -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MICRO -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8037 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Micro\"" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\micro" "C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino\\wiring_pulse.S" -o "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\core\\wiring_pulse.S.o"
"C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MICRO -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8037 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Micro\"" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\micro" "C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino\\WInterrupts.c" -o "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\core\\WInterrupts.c.o"
"C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MICRO -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8037 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Micro\"" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\micro" "C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino\\wiring.c" -o "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\core\\wiring.c.o"
"C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MICRO -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8037 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Micro\"" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\micro" "C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino\\wiring_analog.c" -o "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\core\\wiring_analog.c.o"
"C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MICRO -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8037 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Micro\"" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\micro" "C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino\\wiring_pulse.c" -o "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\core\\wiring_pulse.c.o"
"C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MICRO -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8037 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Micro\"" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\micro" "C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino\\hooks.c" -o "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\core\\hooks.c.o"
"C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MICRO -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8037 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Micro\"" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\micro" "C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino\\wiring_shift.c" -o "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\core\\wiring_shift.c.o"
"C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MICRO -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8037 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Micro\"" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\micro" "C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino\\wiring_digital.c" -o "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\core\\wiring_digital.c.o"
"C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MICRO -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8037 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Micro\"" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\micro" "C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino\\HardwareSerial1.cpp" -o "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\core\\HardwareSerial1.cpp.o"
"C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MICRO -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8037 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Micro\"" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\micro" "C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino\\HardwareSerial0.cpp" -o "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\core\\HardwareSerial0.cpp.o"
"C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MICRO -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8037 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Micro\"" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\micro" "C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino\\Tone.cpp" -o "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\core\\Tone.cpp.o"
"C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MICRO -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8037 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Micro\"" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\micro" "C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino\\main.cpp" -o "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\core\\main.cpp.o"
"C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MICRO -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8037 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Micro\"" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\micro" "C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino\\WMath.cpp" -o "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\core\\WMath.cpp.o"
"C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MICRO -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8037 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Micro\"" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\micro" "C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino\\CDC.cpp" -o "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\core\\CDC.cpp.o"
"C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MICRO -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8037 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Micro\"" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\micro" "C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino\\HardwareSerial.cpp" -o "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\core\\HardwareSerial.cpp.o"
"C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MICRO -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8037 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Micro\"" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\micro" "C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino\\PluggableUSB.cpp" -o "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\core\\PluggableUSB.cpp.o"
"C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MICRO -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8037 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Micro\"" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\micro" "C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino\\Stream.cpp" -o "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\core\\Stream.cpp.o"
"C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MICRO -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8037 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Micro\"" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\micro" "C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino\\Print.cpp" -o "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\core\\Print.cpp.o"
"C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MICRO -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8037 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Micro\"" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\micro" "C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino\\USBCore.cpp" -o "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\core\\USBCore.cpp.o"
"C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MICRO -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8037 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Micro\"" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\micro" "C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino\\abi.cpp" -o "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\core\\abi.cpp.o"
"C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MICRO -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8037 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Micro\"" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\micro" "C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino\\IPAddress.cpp" -o "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\core\\IPAddress.cpp.o"
"C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MICRO -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8037 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Micro\"" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\micro" "C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino\\HardwareSerial2.cpp" -o "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\core\\HardwareSerial2.cpp.o"
"C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MICRO -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8037 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Micro\"" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\micro" "C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino\\WString.cpp" -o "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\core\\WString.cpp.o"
"C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MICRO -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8037 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Micro\"" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\micro" "C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino\\HardwareSerial3.cpp" -o "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\core\\HardwareSerial3.cpp.o"
"C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MICRO -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8037 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Micro\"" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\micro" "C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino\\new.cpp" -o "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\core\\new.cpp.o"
"C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\core\\core.a" "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\core\\wiring_pulse.S.o"
"C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\core\\core.a" "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\core\\WInterrupts.c.o"
"C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\core\\core.a" "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\core\\hooks.c.o"
"C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\core\\core.a" "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\core\\wiring.c.o"
"C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\core\\core.a" "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\core\\wiring_analog.c.o"
"C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\core\\core.a" "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\core\\wiring_digital.c.o"
"C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\core\\core.a" "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\core\\wiring_pulse.c.o"
"C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\core\\core.a" "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\core\\wiring_shift.c.o"
"C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\core\\core.a" "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\core\\CDC.cpp.o"
"C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\core\\core.a" "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\core\\HardwareSerial.cpp.o"
"C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\core\\core.a" "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\core\\HardwareSerial0.cpp.o"
"C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\core\\core.a" "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\core\\HardwareSerial1.cpp.o"
"C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\core\\core.a" "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\core\\HardwareSerial2.cpp.o"
"C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\core\\core.a" "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\core\\HardwareSerial3.cpp.o"
"C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\core\\core.a" "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\core\\IPAddress.cpp.o"
"C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\core\\core.a" "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\core\\PluggableUSB.cpp.o"
"C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\core\\core.a" "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\core\\Print.cpp.o"
"C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\core\\core.a" "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\core\\Stream.cpp.o"
"C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\core\\core.a" "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\core\\Tone.cpp.o"
"C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\core\\core.a" "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\core\\USBCore.cpp.o"
"C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\core\\core.a" "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\core\\WMath.cpp.o"
"C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\core\\core.a" "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\core\\WString.cpp.o"
"C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\core\\core.a" "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\core\\abi.cpp.o"
"C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\core\\core.a" "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\core\\main.cpp.o"
"C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\core\\core.a" "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\core\\new.cpp.o"
Archiving built core (caching) in: C:\Users\flori\AppData\Local\Temp\arduino-core-cache\core_arduino_avr_micro_13a0c564ab1b5e36358b59463d3ffc97.a
"C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega32u4 -o "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9/sketch_may9a.ino.elf" "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\sketch\\sketch_may9a.ino.cpp.o" "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\libraries\\Keyboard\\Keyboard.cpp.o" "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9\\libraries\\HID\\HID.cpp.o" "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9/core\\core.a" "-LC:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9" -lm
"C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9/sketch_may9a.ino.elf" "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9/sketch_may9a.ino.eep"
"C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -R .eeprom "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9/sketch_may9a.ino.elf" "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9/sketch_may9a.ino.hex"
"C:\\Users\\flori\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-size" -A "C:\\Users\\flori\\AppData\\Local\\Temp\\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9/sketch_may9a.ino.elf"
Sketch uses 5508 bytes (19%) of program storage space. Maximum is 28672 bytes.
Global variables use 256 bytes (10%) of dynamic memory, leaving 2304 bytes for local variables. Maximum is 2560 bytes.
Compilation complete.
Performing 1200-bps touch reset on serial port COM3
Waiting for upload port...
"C:\Users\flori\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude" "-CC:\Users\flori\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf" -v -V -patmega32u4 -cavr109 "-PCOM4" -b57600 -D "-Uflash:w:C:\Users\flori\AppData\Local\Temp\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9/sketch_may9a.ino.hex:i"
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Users\flori\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
         Using Port                    : COM4
         Using Programmer              : avr109
         Overriding Baud Rate          : 57600
         AVR Part                      : ATmega32U4
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PA0
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  9000  9000 0x00 0x00
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : butterfly
         Description     : Atmel AppNote AVR109 Boot Loader
Connecting to programmer: .
Found programmer: Id = "CATERIN"; type = S
    Software Version = 1.0; No Hardware Version given.
Programmer supports auto addr increment.
Programmer supports buffered memory access with buffersize=128 bytes.
Programmer supports the following devices:
    Device code: 0x44
avrdude: devcode selected: 0x44
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e9587 (probably m32u4)
avrdude: reading input file "C:\Users\flori\AppData\Local\Temp\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9/sketch_may9a.ino.hex"
avrdude: can't open input file C:\Users\flori\AppData\Local\Temp\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9/sketch_may9a.ino.hex: No such file or directory
avrdude: read from file 'C:\Users\flori\AppData\Local\Temp\arduino-sketch-048B6DF7C15B8C193E3663EC0919DED9/sketch_may9a.ino.hex' failed
avrdude done.  Thank you.
Upload error: Error: 2 UNKNOWN: uploading error: uploading error: exit status 1
This sort of error could be caused by your antivirus software. Try TEMPORARILY disabling your antivirus for a single compilation to see if the problem goes away, then turn the antivirus back on.
If the problem doesn't occur with the antivirus off you will need to adjust the settings of your antivirus to whitelist the appropriate file, folder, or process so it doesn't interfere with compilation.
Please be cautious about working without an antivirus. This is only about temporarily disabling it for a quick test. If you don't feel comfortable doing that, fine. You can try going straight to configuring the antivirus to whitelist the Arduino software.
