Keypad with 7 segment display
Hello guys!
I need some help with this code:
#include <Key.h>
#include <Keypad.h>
byte digitPlace;
byte digit0;
byte digit1;
byte digit2;
byte digit3;
byte digit0pins[] = {14,15,16,17,18,19,20,}; // g-f-e-d-c-b-a for example
byte digit1pins[] = {21,22,23,24,25,26,27,};
byte digit2pins[] = {28,29,30,31,32,33,34,};
byte digit3pins[] = {35,36,37,38,39,40,41,};
byte fontArray[] = {
0b00111111, // 0  with x-g-f-e-d-c-b-a, 1 =- segment on
0b00000110, // 1
0b01011011, // 2
0b01001111, // 3
0b01100110, // 4
0b01101101, // 5
0b01111101, // 6
0b00000111, // 7
0b01111111, // 8
0b01101111, // 9
byte maskArray[] = {0b00000001, 0b00000010, 0b00000100, 0b00001000, 0b00010000, 0b00100000, 0b01000000,};
byte i;
const byte numRows= 4;
const byte numCols= 4;
char keymap [numRows][numCols]=
{'1', '2', '3', 'A'},
{'4', '5', '6', 'B'},
{'7', '8', '9', 'C'},
{'*', '0', '#', '+'}
byte rowPins[numRows] = {13,12,11,10}; //Rows 0 to 4
byte colPins[numCols]= {9,8,7,6}; //Columns 0 to 4
Keypad myKeypad= Keypad(makeKeymap(keymap), rowPins, colPins, numRows, numCols);
for (i=0; i<7; i=i+1){
pinMode (digit0pins[i], OUTPUT);
pinMode (digit1pins[i], OUTPUT);
pinMode (digit2pins[i], OUTPUT);
pinMode (digit3pins[i], OUTPUT);
char keypressed = myKeypad.getKey();
if (keypressed != NO_KEY)
if (keypressed >= 48){  // www.asciitable.com]www.asciitable.com see if at least a '0' came in
keypressed = keypressed - 48; // yes, so convert from ASCII character to a number,
if (keypressed >= 0 && keypressed <=9){ // display valid numbers
switch (digitPlace) // switch between the different digits
case 0: // digit0
for (i=0; i<7;i=i+1){
if ((fontArray[keypressed] && maskArray[i]) == 0){  // test if segment is equal to 0, turn it off
// for example digit0 = 1, then fontArray[1] = 0b00000110. With i = 0, then 0b00000110 && 0b00000001 = 0,
// so pin for segment A gets turned off
// for example digit0 = 1, then fontArray[1] = 0b00000110. With i = 1, then 0b00000110 && 0b0000010 = 0b00000010,
// so pin for segment B gets turned on
digitalWrite (digit0pins[i], LOW);
Serial.println("digit0");
Serial.println(digit0pins[i]);
else {   // otherwise, turn it on
digitalWrite (digit0pins[i], HIGH);
Serial.println("digit 0");
case 1: // digit1
digitalWrite (digit1pins[i], LOW);
Serial.println("digit1");
Serial.println(digit1pins[i]);
digitalWrite (digit1pins[i], HIGH);
Serial.println("digit 1");
case 2: // digit2
digitalWrite (digit2pins[i], LOW);
Serial.println("digit2");
Serial.println(digit2pins[i]);
digitalWrite (digit2pins[i], HIGH);
Serial.println("digit 2");
case 3: // digit3
digitalWrite (digit3pins[i], LOW);
Serial.println("digit3");
Serial.println(digit3pins[i]);
digitalWrite (digit3pins[i], HIGH);
Serial.println("digit 3");
if (keypressed =='#'){  // if # came in, move to next digit
digitPlace = digitPlace +1;
if (digitPlace == 4){
digitPlace = 0;
When I pressed e.g. 1 on serial monitor shows this :
digit 0
14
digit 0
15
digit 0
16
digit 0
17
digit 0
18
digit 0
19
digit 0
20
What is the problem?
My project is to make a 4 7-led segment display. Something like this 1#3#5#7 ---> display shows 1357.
      if (keypressed == '#') { // if # came in, move to next digit
        digitPlace = digitPlace + 1;
        if (digitPlace == 4) {
          digitPlace = 0;
Is this correctly positioned?
Format and indent your code properly and it makes mistakes easier to notice.
Tools->Autoformat or Ctrl-T
Okey here is a code after Autoformat
#include <Key.h>
#include <Keypad.h>
byte digitPlace;
byte digit0;
byte digit1;
byte digit2;
byte digit3;
byte digit0pins[] = {14, 15, 16, 17, 18, 19, 20,}; // g-f-e-d-c-b-a for example
byte digit1pins[] = {21, 22, 23, 24, 25, 26, 27,};
byte digit2pins[] = {28, 29, 30, 31, 32, 33, 34,};
byte digit3pins[] = {35, 36, 37, 38, 39, 40, 41,};
  0b00000110, // 1
  0b01011011, // 2
  0b01001111, // 3
  0b01100110, // 4
  0b01101101, // 5
  0b01111101, // 6
  0b00000111, // 7
  0b01111111, // 8
  0b01101111, // 9
byte i;
const byte numRows = 4;
const byte numCols = 4;
char keymap [numRows][numCols] =
byte rowPins[numRows] = {13, 12, 11, 10}; //Rows 0 to 4
byte colPins[numCols] = {9, 8, 7, 6}; //Columns 0 to 4
Keypad myKeypad = Keypad(makeKeymap(keymap), rowPins, colPins, numRows, numCols);
  for (i = 0; i < 7; i = i + 1) {
    if (keypressed >= 48) { // www.asciitable.com]www.asciitable.com see if at least a '0' came in
    if (keypressed >= 0 && keypressed <= 9) { // display valid numbers
        case 0: // digit0
            if ((fontArray[keypressed] && maskArray[i]) == 0) { // test if segment is equal to 0, turn it off
        case 1: // digit1
        case 2: // digit2
        case 3: // digit3
          digitPlace = 0;
I have no oder idea where to put this :frowning: . Do you?
          digitPlace = 0;
Looks right?
when i pressed '#' digitplace does not change.
mclavtar:
Yes, because your if (keypressed == '#') is inside of the if (keypressed >= 0 && keypressed <= 9) block.
if you put that part of the code there is false, because '#' is not >=0 && <=9. Am i right?
mclavtar:
Yes.
Current code:
#include <Key.h>
#include <Keypad.h>
byte digitPlace;
byte digit0;
byte digit1;
byte digit2;
byte digit3;
  0b00000110, // 1
  0b01011011, // 2
  0b01001111, // 3
  0b01100110, // 4
  0b01101101, // 5
  0b01111101, // 6
  0b00000111, // 7
  0b01111111, // 8
  0b01101111, // 9
byte i;
      Serial.println(digitPlace);
        digitPlace = 0;
      case 0: // digit0
      case 1: // digit1
      case 2: // digit2
      case 3: // digit3
Now when i press '#' program shifts to next digit. But it turn all 7 segments on (e.g if i press 3 turn all segments not just abcdg segments). How to slove this?
Serial monitor situation:
digit 0
14
digit 0
15
digit 0
16
digit 0
17
digit 0
18
digit 0
19
digit 0
20
0
1
digit 1
21
digit 1
22
digit 1
23
digit 1
24
digit 1
25
digit 1
26
digit 1
27
1
2
digit 2
28
digit 2
29
digit 2
30
digit 2
31
digit 2
32
digit 2
33
digit 2
34
2
3
digit 3
35
digit 3
36
digit 3
37
digit 3
38
digit 3
39
digit 3
40
digit 3
41
3
4
digit 0
14
digit 0
15
digit 0
16
digit 0
17
digit 0
18
digit 0
19
digit 0
20
mclavtar:
&& is a logical operator.
You want to use & for bitwise operation.
I've run out of time, just at this moment, but I suspect there may be other errors in your code.
i think the problem is here:
mclavtar:
Did you change the && to & ? Fix the easy stuff first, then you will be more likely to find any more difficult issues.
I did, but this does not slove the problem. I think the program does not read, which pins must be high properly. I'm trying different things to slove it. If you have any idea what could be wrong, I would be very happy.
Try this untested code:
#include <Key.h>
#include <Keypad.h>
byte digitPlace;
byte digitPins[][7] = {
  {14, 15, 16, 17, 18, 19, 20}, // digit 1
  {21, 22, 23, 24, 25, 26, 27}, // digit 2
  {28, 29, 30, 31, 32, 33, 34}, // digit 3
  {35, 36, 37, 38, 39, 40, 41}  // digit 4
  0b00000110, // 1
  0b01011011, // 2
  0b01001111, // 3
  0b01100110, // 4
  0b01101101, // 5
  0b01111101, // 6
  0b00000111, // 7
  0b01111111, // 8
  0b01101111, // 9
  for (int i = 0; i < 7; i++) {
    pinMode(digitPins[0][i], OUTPUT);
    pinMode(digitPins[1][i], OUTPUT);
    pinMode(digitPins[2][i], OUTPUT);
    pinMode(digitPins[3][i], OUTPUT);
    Serial.print("keypressed: ");
    Serial.print(keypressed);
    Serial.print(", digitPlace: ");
    if (keypressed >= '0' && keypressed <= '9') {
      // convert from ASCII character to a number
      int digit = keypressed - '0';
        bool segmentOn = fontArray[digit] & (1 << i);
        Serial.print("segment: ");
        Serial.print(i);
        Serial.print(", pin: ");
        Serial.print(digitPins[digitPlace][i]);
        Serial.print(", ");
        Serial.println(segmentOn ? "ON" : "OFF");
        digitalWrite (digitPins[digitPlace][i], segmentOn ? HIGH : LOW);
    else if (keypressed == '#') {
        digitPlace = 0;
Yes, it works great. I was doing new code in the same way, but i got some errors. Here in this code i see what i was doing wrong. I have learned with this code a lot. So it not just copy-paste. THANK YOU VERY MUCH!
Glad to have helped.
mclavtar, are you all set now?
Yes, thank you!
