I'm working with a clone Arduino micro board, I've got the color sensor up and running fine. So the problem isn't the card.
I'm using the example code, just to try out the module:
// the setup routine runs once when you press reset:
// initialize serial communication at 9600 bits per second:
// the loop routine runs over and over again forever:
// read the input on analog pin 0:
int sensorValue = analogRead(A0);
// print out the value you read:
Serial.println(sensorValue);
delay(1); // delay in between reads for stability
A0 is on the output, ground and 5V wires are setup right. The red light on the module is red. I'm getting readings about 200-ish. That's about 1.5V if I convert it. I can't block it with an opaque object, that doesn't change the readings. I removed the cover, to see if it helps, still the same. I've tried three different sensors.
The one I'm using is this device: https://www.elecrow.com/ts-300b-turbidity-sensor-water-turbidity-module-turbidity-detection-module.html
Any suggestions as to how and why is this happening, thank you.
