Killed my bootloader?
Last night I was happily coding away for my LED cube until I tried this one particular animation that seemed to have killed my Arduino. When I power it up, all LEDs flash like the code is supposed to and then it just goes dark. When I try to upload again I get:
stk500_recv(): programmer is not responding
long Random;
////////////////0 1 2 3 4 5 6 7 8  9  10 11
//int pins[] = {2,3,4,5,6,7,8,9,10,11,12,13};
int pins[] = {2,6,10,3,7,13,4,8,12,5,9,11};
int time = 10;
int time2 = 250;
int time3 = 0;
int time4 = 100;
  pinMode(pins[0], OUTPUT); //2 g
  pinMode(pins[1], OUTPUT); //3 3
  pinMode(pins[2], OUTPUT); //4 6
  pinMode(pins[3], OUTPUT); //5 9
  pinMode(pins[4], OUTPUT); //6 g
  pinMode(pins[5], OUTPUT); //7 2
  pinMode(pins[6], OUTPUT); //8 5
  pinMode(pins[7], OUTPUT); //9 8
  pinMode(pins[8], OUTPUT); //10 g
  pinMode(pins[9], OUTPUT); //11 1
  pinMode(pins[10], OUTPUT); //12 4
  pinMode(pins[11], OUTPUT); //13 7
  //Serial.begin(9600);
//START Moving Walls
digitalWrite(pins[0], LOW);
digitalWrite(pins[1], HIGH);
digitalWrite(pins[2], HIGH);
int c = 3;
while(c<=9)
for(int l = 0; l<=2; l++) //Controls which layer is lit
for(int i =c; i < i+3; i++)
    digitalWrite(pins[i], HIGH);
    digitalWrite(pins[i], LOW);
 digitalWrite(pins[l], HIGH); //Increments layer in voltage
 if(l != 2)
 digitalWrite(pins[l+1], LOW);
c = c+3;
delay(time2);
if(c > 9)
  c=3;
//END Moving Walls
I'm not entirely sure what caused the issue, it was working fine until I uploaded the above sketch and now I can't do anything.
Am I completely screwed and need to reburn the bootloader or is there something I can do? Any idea what my code did?
EDIT: Forgot to add some stuff.
I'm running the latest version of OS X(intel) and the latest Arduino software with a Diecimila. Pin 13 flashes like crazy on boot and stops when I try to upload something, then starts on the next upload. Holding the reset button stops the light until released and then it flickers like mad again.
EDIT 2: I just tried it on Windows and I get a different set of errors.
avrdude: stk500_getsync(): not in sync: resp=0x00
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51
I have the same exact problem, after downloading the PCMAudio demo program to my Diecimila. Luckily I grabbed a Stickduino too, to fall back to, for now. Have you had any luck fixing yours?
Sounds to me like you did loose your bootloader. This seems to happen rarely.
I never lost one by loading sketches but I did loose 4 when experimenting with an onboard switching power supply- no ground plane & inductor too close to crystal. In any case, the predicament was the same.
You may get various advice on this subject - here's mine:
If you have a PC with a parallel port, you could build a parallel ISP cable for almost nothing- see
If you build one, keep it short ~ 1.5' (.5m). The first one I built was 4' long and was flakey (and I have been soldering for almost 50 years.)
If you don't want to build one, than you can buy some ATMega168 chips with the bootloader already burnt. Nkelectronics & Lady Ada are 2 sources.
Of course if you think you will have interest in other things you can do with an ISP programmer, you can buy a "real" one. Lady Ada has a good one I hear.
I had the very same problem, rapidly flashing LED but no answer from the bootloader (Arduine Diecimila). And unfortunately I have neither a parallel port nor another ISP programmer available. But I remembered that the FT232R has a bit-bang mode. After some search I found a tool that can be used to "un-brick" dead Arduinos, including instructions and everything!
http://www.geocities.jp/arduino_diecimila/bootloader/index_en.html
After reflashing the bootloader and setting the fuses everything started to work again. The programming is not even all that slow! (Compared to some experiments with half-finished avrdude patches from avrdude-dev).
Definitely saved my day!
Cheers,
Sebastian
