Bonjour,
Je démarre dans l'univers Arduino avec le KIT Explore IoT.
Lors de la mise en pratique de l'activité 1, j'ai inscrit le code donné sur WEB EDITOR,
mais lors de la vérification du code, j'ai l'erreur suivante :
/usr/local/bin/arduino-cli compile --fqbn arduino:samd:mkrwifi1010 --libraries /home/builder/opt/libraries/latest --build-cache-path /tmp --output-dir /tmp/529215192/build --build-path /tmp/arduino-build-A2CC48AA1B728BF9EAA77F114F2C3A74 --library /mnt/create-efs/webide/a7/89/a7895957722f17c6a4c85b8b2fd49eea:noor6/libraries_v2/Arduino_MKRIoTCarrier /tmp/529215192/Activite_1
Using library adafruit_dotstar_1_2_1 at version 1.2.1 in folder: /home/builder/opt/libraries/adafruit_dotstar_1_2_1
Using library adafruit_unified_sensor_1_1_7 at version 1.1.7 in folder: /home/builder/opt/libraries/adafruit_unified_sensor_1_1_7
/mnt/create-efs/webide/a7/89/a7895957722f17c6a4c85b8b2fd49eea:noor6/libraries_v2/Arduino_MKRIoTCarrier/src/AirQualityClass.cpp: In member function 'int AirQualityClass::begin()':
/mnt/create-efs/webide/a7/89/a7895957722f17c6a4c85b8b2fd49eea:noor6/libraries_v2/Arduino_MKRIoTCarrier/src/AirQualityClass.cpp:38:24: error: 'BME680_I2C_ADDR_PRIMARY' was not declared in this scope
iaqSensor->begin(BME680_I2C_ADDR_PRIMARY, Wire);
/mnt/create-efs/webide/a7/89/a7895957722f17c6a4c85b8b2fd49eea:noor6/libraries_v2/Arduino_MKRIoTCarrier/src/EnvClass.cpp: In member function 'int EnvClass::begin()':
/mnt/create-efs/webide/a7/89/a7895957722f17c6a4c85b8b2fd49eea:noor6/libraries_v2/Arduino_MKRIoTCarrier/src/EnvClass.cpp:39:24: error: 'BME680_I2C_ADDR_PRIMARY' was not declared in this scope
/mnt/create-efs/webide/a7/89/a7895957722f17c6a4c85b8b2fd49eea:noor6/libraries_v2/Arduino_MKRIoTCarrier/src/PressureClass.cpp: In member function 'int PressureClass::begin()':
/mnt/create-efs/webide/a7/89/a7895957722f17c6a4c85b8b2fd49eea:noor6/libraries_v2/Arduino_MKRIoTCarrier/src/PressureClass.cpp:38:24: error: 'BME680_I2C_ADDR_PRIMARY' was not declared in this scope
/mnt/create-efs/webide/a7/89/a7895957722f17c6a4c85b8b2fd49eea:noor6/libraries_v2/Arduino_MKRIoTCarrier/src/AirQualityClass.cpp:38:24: note: suggested alternative: 'BME68X_I2C_ADDR_HIGH'
/mnt/create-efs/webide/a7/89/a7895957722f17c6a4c85b8b2fd49eea:noor6/libraries_v2/Arduino_MKRIoTCarrier/src/AirQualityClass.cpp:48:9: error: 'BSEC_OUTPUT_IAQ' was not declared in this scope
BSEC_OUTPUT_IAQ,
/mnt/create-efs/webide/a7/89/a7895957722f17c6a4c85b8b2fd49eea:noor6/libraries_v2/Arduino_MKRIoTCarrier/src/EnvClass.cpp:39:24: note: suggested alternative: 'BME68X_I2C_ADDR_HIGH'
/mnt/create-efs/webide/a7/89/a7895957722f17c6a4c85b8b2fd49eea:noor6/libraries_v2/Arduino_MKRIoTCarrier/src/EnvClass.cpp:49:9: error: 'BSEC_OUTPUT_IAQ' was not declared in this scope
BSEC_OUTPUT_IAQ,
/mnt/create-efs/webide/a7/89/a7895957722f17c6a4c85b8b2fd49eea:noor6/libraries_v2/Arduino_MKRIoTCarrier/src/PressureClass.cpp:38:24: note: suggested alternative: 'BME68X_I2C_ADDR_HIGH'
/mnt/create-efs/webide/a7/89/a7895957722f17c6a4c85b8b2fd49eea:noor6/libraries_v2/Arduino_MKRIoTCarrier/src/PressureClass.cpp:48:9: error: 'BSEC_OUTPUT_IAQ' was not declared in this scope
BSEC_OUTPUT_IAQ,
/mnt/create-efs/webide/a7/89/a7895957722f17c6a4c85b8b2fd49eea:noor6/libraries_v2/Arduino_MKRIoTCarrier/src/AirQualityClass.cpp:48:9: note: suggested alternative: 'BSEC_OUTPUT_RAW_GAS'
BSEC_OUTPUT_IAQ,
BSEC_OUTPUT_RAW_GAS
/mnt/create-efs/webide/a7/89/a7895957722f17c6a4c85b8b2fd49eea:noor6/libraries_v2/Arduino_MKRIoTCarrier/src/AirQualityClass.cpp:49:9: error: 'BSEC_OUTPUT_STATIC_IAQ' was not declared in this scope
BSEC_OUTPUT_STATIC_IAQ,
/mnt/create-efs/webide/a7/89/a7895957722f17c6a4c85b8b2fd49eea:noor6/libraries_v2/Arduino_MKRIoTCarrier/src/EnvClass.cpp:49:9: note: suggested alternative: 'BSEC_OUTPUT_RAW_GAS'
BSEC_OUTPUT_IAQ,
BSEC_OUTPUT_RAW_GAS
/mnt/create-efs/webide/a7/89/a7895957722f17c6a4c85b8b2fd49eea:noor6/libraries_v2/Arduino_MKRIoTCarrier/src/EnvClass.cpp:50:9: error: 'BSEC_OUTPUT_STATIC_IAQ' was not declared in this scope
/mnt/create-efs/webide/a7/89/a7895957722f17c6a4c85b8b2fd49eea:noor6/libraries_v2/Arduino_MKRIoTCarrier/src/PressureClass.cpp:48:9: note: suggested alternative: 'BSEC_OUTPUT_RAW_GAS'
BSEC_OUTPUT_IAQ,
BSEC_OUTPUT_RAW_GAS
/mnt/create-efs/webide/a7/89/a7895957722f17c6a4c85b8b2fd49eea:noor6/libraries_v2/Arduino_MKRIoTCarrier/src/PressureClass.cpp:49:9: error: 'BSEC_OUTPUT_STATIC_IAQ' was not declared in this scope
/mnt/create-efs/webide/a7/89/a7895957722f17c6a4c85b8b2fd49eea:noor6/libraries_v2/Arduino_MKRIoTCarrier/src/AirQualityClass.cpp:49:9: note: suggested alternative: 'BSEC_OUTPUT_RAW_GAS'
BSEC_OUTPUT_RAW_GAS
/mnt/create-efs/webide/a7/89/a7895957722f17c6a4c85b8b2fd49eea:noor6/libraries_v2/Arduino_MKRIoTCarrier/src/AirQualityClass.cpp:50:9: error: 'BSEC_OUTPUT_CO2_EQUIVALENT' was not declared in this scope
BSEC_OUTPUT_CO2_EQUIVALENT,
/mnt/create-efs/webide/a7/89/a7895957722f17c6a4c85b8b2fd49eea:noor6/libraries_v2/Arduino_MKRIoTCarrier/src/EnvClass.cpp:50:9: note: suggested alternative: 'BSEC_OUTPUT_RAW_GAS'
BSEC_OUTPUT_RAW_GAS
/mnt/create-efs/webide/a7/89/a7895957722f17c6a4c85b8b2fd49eea:noor6/libraries_v2/Arduino_MKRIoTCarrier/src/EnvClass.cpp:51:9: error: 'BSEC_OUTPUT_CO2_EQUIVALENT' was not declared in this scope
/mnt/create-efs/webide/a7/89/a7895957722f17c6a4c85b8b2fd49eea:noor6/libraries_v2/Arduino_MKRIoTCarrier/src/PressureClass.cpp:49:9: note: suggested alternative: 'BSEC_OUTPUT_RAW_GAS'
BSEC_OUTPUT_RAW_GAS
/mnt/create-efs/webide/a7/89/a7895957722f17c6a4c85b8b2fd49eea:noor6/libraries_v2/Arduino_MKRIoTCarrier/src/PressureClass.cpp:50:9: error: 'BSEC_OUTPUT_CO2_EQUIVALENT' was not declared in this scope
/mnt/create-efs/webide/a7/89/a7895957722f17c6a4c85b8b2fd49eea:noor6/libraries_v2/Arduino_MKRIoTCarrier/src/AirQualityClass.cpp:50:9: note: suggested alternative: 'BSEC_OUTPUT_IAQ_ESTIMATE'
/mnt/create-efs/webide/a7/89/a7895957722f17c6a4c85b8b2fd49eea:noor6/libraries_v2/Arduino_MKRIoTCarrier/src/AirQualityClass.cpp:51:9: error: 'BSEC_OUTPUT_BREATH_VOC_EQUIVALENT' was not declared in this scope
BSEC_OUTPUT_BREATH_VOC_EQUIVALENT,
/mnt/create-efs/webide/a7/89/a7895957722f17c6a4c85b8b2fd49eea:noor6/libraries_v2/Arduino_MKRIoTCarrier/src/EnvClass.cpp:51:9: note: suggested alternative: 'BSEC_OUTPUT_IAQ_ESTIMATE'
/mnt/create-efs/webide/a7/89/a7895957722f17c6a4c85b8b2fd49eea:noor6/libraries_v2/Arduino_MKRIoTCarrier/src/EnvClass.cpp:52:9: error: 'BSEC_OUTPUT_BREATH_VOC_EQUIVALENT' was not declared in this scope
/mnt/create-efs/webide/a7/89/a7895957722f17c6a4c85b8b2fd49eea:noor6/libraries_v2/Arduino_MKRIoTCarrier/src/PressureClass.cpp:50:9: note: suggested alternative: 'BSEC_OUTPUT_IAQ_ESTIMATE'
/mnt/create-efs/webide/a7/89/a7895957722f17c6a4c85b8b2fd49eea:noor6/libraries_v2/Arduino_MKRIoTCarrier/src/PressureClass.cpp:51:9: error: 'BSEC_OUTPUT_BREATH_VOC_EQUIVALENT' was not declared in this scope
/mnt/create-efs/webide/a7/89/a7895957722f17c6a4c85b8b2fd49eea:noor6/libraries_v2/Arduino_MKRIoTCarrier/src/AirQualityClass.cpp:51:9: note: suggested alternative: 'BSEC_OUTPUT_IAQ_ESTIMATE'
/mnt/create-efs/webide/a7/89/a7895957722f17c6a4c85b8b2fd49eea:noor6/libraries_v2/Arduino_MKRIoTCarrier/src/AirQualityClass.cpp:56:53: error: 'BSEC_SAMPLE_RATE_CONTINUOUS' was not declared in this scope
iaqSensor->updateSubscription(sensorList, 10, BSEC_SAMPLE_RATE_CONTINUOUS);
/mnt/create-efs/webide/a7/89/a7895957722f17c6a4c85b8b2fd49eea:noor6/libraries_v2/Arduino_MKRIoTCarrier/src/EnvClass.cpp:52:9: note: suggested alternative: 'BSEC_OUTPUT_IAQ_ESTIMATE'
/mnt/create-efs/webide/a7/89/a7895957722f17c6a4c85b8b2fd49eea:noor6/libraries_v2/Arduino_MKRIoTCarrier/src/EnvClass.cpp:57:53: error: 'BSEC_SAMPLE_RATE_CONTINUOUS' was not declared in this scope
/mnt/create-efs/webide/a7/89/a7895957722f17c6a4c85b8b2fd49eea:noor6/libraries_v2/Arduino_MKRIoTCarrier/src/PressureClass.cpp:51:9: note: suggested alternative: 'BSEC_OUTPUT_IAQ_ESTIMATE'
/mnt/create-efs/webide/a7/89/a7895957722f17c6a4c85b8b2fd49eea:noor6/libraries_v2/Arduino_MKRIoTCarrier/src/PressureClass.cpp:56:53: error: 'BSEC_SAMPLE_RATE_CONTINUOUS' was not declared in this scope
/mnt/create-efs/webide/a7/89/a7895957722f17c6a4c85b8b2fd49eea:noor6/libraries_v2/Arduino_MKRIoTCarrier/src/AirQualityClass.cpp:56:53: note: suggested alternative: 'BSEC_SAMPLE_RATE_ULP'
/mnt/create-efs/webide/a7/89/a7895957722f17c6a4c85b8b2fd49eea:noor6/libraries_v2/Arduino_MKRIoTCarrier/src/AirQualityClass.cpp: In member function 'int AirQualityClass::checkIaqSensorStatus()':
/mnt/create-efs/webide/a7/89/a7895957722f17c6a4c85b8b2fd49eea:noor6/libraries_v2/Arduino_MKRIoTCarrier/src/AirQualityClass.cpp:71:18: error: 'class Bsec' has no member named 'status'; did you mean 'bsecStatus'?
if (iaqSensor->status != BSEC_OK) {
bsecStatus
/mnt/create-efs/webide/a7/89/a7895957722f17c6a4c85b8b2fd49eea:noor6/libraries_v2/Arduino_MKRIoTCarrier/src/AirQualityClass.cpp:72:20: error: 'class Bsec' has no member named 'status'; did you mean 'bsecStatus'?
if (iaqSensor->status < BSEC_OK) {
bsecStatus
/mnt/create-efs/webide/a7/89/a7895957722f17c6a4c85b8b2fd49eea:noor6/libraries_v2/Arduino_MKRIoTCarrier/src/AirQualityClass.cpp:77:18: error: 'class Bsec' has no member named 'bme680Status'; did you mean 'bme68xStatus'?
if (iaqSensor->bme680Status != BME680_OK) {
bme68xStatus
/mnt/create-efs/webide/a7/89/a7895957722f17c6a4c85b8b2fd49eea:noor6/libraries_v2/Arduino_MKRIoTCarrier/src/AirQualityClass.cpp:77:34: error: 'BME680_OK' was not declared in this scope
/mnt/create-efs/webide/a7/89/a7895957722f17c6a4c85b8b2fd49eea:noor6/libraries_v2/Arduino_MKRIoTCarrier/src/EnvClass.cpp:57:53: note: suggested alternative: 'BSEC_SAMPLE_RATE_ULP'
/mnt/create-efs/webide/a7/89/a7895957722f17c6a4c85b8b2fd49eea:noor6/libraries_v2/Arduino_MKRIoTCarrier/src/EnvClass.cpp: In member function 'int EnvClass::checkIaqSensorStatus()':
/mnt/create-efs/webide/a7/89/a7895957722f17c6a4c85b8b2fd49eea:noor6/libraries_v2/Arduino_MKRIoTCarrier/src/EnvClass.cpp:76:18: error: 'class Bsec' has no member named 'status'; did you mean 'bsecStatus'?
bsecStatus
/mnt/create-efs/webide/a7/89/a7895957722f17c6a4c85b8b2fd49eea:noor6/libraries_v2/Arduino_MKRIoTCarrier/src/EnvClass.cpp:77:20: error: 'class Bsec' has no member named 'status'; did you mean 'bsecStatus'?
bsecStatus
/mnt/create-efs/webide/a7/89/a7895957722f17c6a4c85b8b2fd49eea:noor6/libraries_v2/Arduino_MKRIoTCarrier/src/EnvClass.cpp:82:18: error: 'class Bsec' has no member named 'bme680Status'; did you mean 'bme68xStatus'?
bme68xStatus
/mnt/create-efs/webide/a7/89/a7895957722f17c6a4c85b8b2fd49eea:noor6/libraries_v2/Arduino_MKRIoTCarrier/src/EnvClass.cpp:82:34: error: 'BME680_OK' was not declared in this scope
/mnt/create-efs/webide/a7/89/a7895957722f17c6a4c85b8b2fd49eea:noor6/libraries_v2/Arduino_MKRIoTCarrier/src/AirQualityClass.cpp:77:34: note: suggested alternative: 'BME68X_OK'
BME68X_OK
/mnt/create-efs/webide/a7/89/a7895957722f17c6a4c85b8b2fd49eea:noor6/libraries_v2/Arduino_MKRIoTCarrier/src/AirQualityClass.cpp:78:20: error: 'class Bsec' has no member named 'bme680Status'; did you mean 'bme68xStatus'?
if (iaqSensor->bme680Status < BME680_OK) {
bme68xStatus
/mnt/create-efs/webide/a7/89/a7895957722f17c6a4c85b8b2fd49eea:noor6/libraries_v2/Arduino_MKRIoTCarrier/src/PressureClass.cpp:56:53: note: suggested alternative: 'BSEC_SAMPLE_RATE_ULP'
/mnt/create-efs/webide/a7/89/a7895957722f17c6a4c85b8b2fd49eea:noor6/libraries_v2/Arduino_MKRIoTCarrier/src/PressureClass.cpp: In member function 'int PressureClass::checkIaqSensorStatus()':
/mnt/create-efs/webide/a7/89/a7895957722f17c6a4c85b8b2fd49eea:noor6/libraries_v2/Arduino_MKRIoTCarrier/src/PressureClass.cpp:76:18: error: 'class Bsec' has no member named 'status'; did you mean 'bsecStatus'?
bsecStatus
/mnt/create-efs/webide/a7/89/a7895957722f17c6a4c85b8b2fd49eea:noor6/libraries_v2/Arduino_MKRIoTCarrier/src/PressureClass.cpp:77:20: error: 'class Bsec' has no member named 'status'; did you mean 'bsecStatus'?
bsecStatus
/mnt/create-efs/webide/a7/89/a7895957722f17c6a4c85b8b2fd49eea:noor6/libraries_v2/Arduino_MKRIoTCarrier/src/PressureClass.cpp:82:18: error: 'class Bsec' has no member named 'bme680Status'; did you mean 'bme68xStatus'?
bme68xStatus
/mnt/create-efs/webide/a7/89/a7895957722f17c6a4c85b8b2fd49eea:noor6/libraries_v2/Arduino_MKRIoTCarrier/src/PressureClass.cpp:82:34: error: 'BME680_OK' was not declared in this scope
/mnt/create-efs/webide/a7/89/a7895957722f17c6a4c85b8b2fd49eea:noor6/libraries_v2/Arduino_MKRIoTCarrier/src/EnvClass.cpp:82:34: note: suggested alternative: 'BME68X_OK'
BME68X_OK
/mnt/create-efs/webide/a7/89/a7895957722f17c6a4c85b8b2fd49eea:noor6/libraries_v2/Arduino_MKRIoTCarrier/src/EnvClass.cpp:83:20: error: 'class Bsec' has no member named 'bme680Status'; did you mean 'bme68xStatus'?
bme68xStatus
/mnt/create-efs/webide/a7/89/a7895957722f17c6a4c85b8b2fd49eea:noor6/libraries_v2/Arduino_MKRIoTCarrier/src/PressureClass.cpp:82:34: note: suggested alternative: 'BME68X_OK'
BME68X_OK
/mnt/create-efs/webide/a7/89/a7895957722f17c6a4c85b8b2fd49eea:noor6/libraries_v2/Arduino_MKRIoTCarrier/src/PressureClass.cpp:83:20: error: 'class Bsec' has no member named 'bme680Status'; did you mean 'bme68xStatus'?
bme68xStatus
Error during build: exit status 1
Pouvez-vous m'aider a le resoudre s'il vous plait.
