Hi All
This is my first post here, so I'm quickly going to introduce myself
I've been playing around with an Arduino Uno since quite a while now, hacked a couple of toys to make useless but fun stuff. I would still consider myself a complete newbie though since I never deeply dived into the world of electronics.
I know bits and stuff here and there and am able to put together and code some very basic stuff, but I decided to work on a (hopefully) simple project I want to keep rather than use for a day and get rid of again almost immediately
So here's the plan:
I want to build a knight-rider style Voicebox using 6x 10 segment LED graph bars which react to a soundsource (pretty much like a simple VU meter really). I might even hook up a small speaker and an amp (already build that stuff, should be easy to include).
What I have found so far:
6x10 segment LED bar graph: http://shop.boxtec.ch/segment-led-bar-graph-rot-p-41877.html
I have not found orange ones, so I'll go with red...
LM3914 or LM3916 LED Driver > Dot/Bar Display Driver Hookup Guide - SparkFun Learn
...And some resistors
And that's where the questions already start..
I think I can use the LM3914 or LM3916 to apply a technique similiar to the LED Cube's where you don' t need a lot of pins to switch on/off individual led's. I have however never used an LED driver.. Is my assumption correct that I'll need to have resistors hooked up to every single LED? I will have to go through some tutorials to figure out how to use the LM3914, but any help here is highly appreciated Also, I'm not sure how the difference between the LM3914 and LM3916 has (if at all) an impact on the project.. Any hints?
Another thing I'm not quite sure about: How do I acchieve the "LED dimm effect" (see this video > - YouTube).
I'll probably find out how to get the LED's to behave like a VU meter by finding some sketches and following tutorials. However I'm not sure how to achieve the dimming effect. The LED's are not simply on/off, they also seem to be more dimmed at the higher / lower section (and also left/right section, see video above). Is this achievable with PWM for 60 led's? I guess I'm asking because I'm still not sure how that LED Driver works.
So hopefully I'll be able to put this together with the help of you guys
Thanks for any help!
Carl
