Hello,
using XUbuntu 22.04 LTS, Arduino IDE 2.0.0-rc8 and megaTinyCore 2.5.11… editor suggestions do not work for the following board entries:
ATtiny3224/1624/824/424 w/Optiboot
ATtiny3226/1626/826/426 w/Optiboot
ATtiny3227/1627/827/427 w/Optiboot
Initially suspecting it affected all "w/Optiboot" postfixed entries, I went through all boards of this extension to verify and actually came up with the above mentioned list of entries that have this issue.
For keywords that already exist in the sketch (like in this example "digitalWrite"), this is the behavior:
Otherwise nothing is being suggested.
Compilation (and upload) works fine.
I attached logfiles from the language server.
[languageserverlog.zip](https://github.com/SpenceKonde/megaTinyCore/files/9076215/languageserverlog.zip)
Relevant error from inols-clangd-err.log seems to be:
`V[11:37:29.057] Ignored diagnostic. unknown target CPU 'attiny3226'
V[11:37:29.057] Ignored diagnostic. valid target CPU values are: avr1, avr2, avr25, avr3, avr31, avr35, avr4, avr5, avr51, avr6, avrxmega1, avrxmega2, avrxmega3, avrxmega4, avrxmega5, avrxmega6, avrxmega7, avrtiny, at90s1200, attiny11, attiny12, attiny15, attiny28, at90s2313, at90s2323, at90s2333, at90s2343, attiny22, attiny26, at86rf401, at90s4414, at90s4433, at90s4434, at90s8515, at90c8534, at90s8535, ata5272, attiny13, attiny13a, attiny2313, attiny2313a, attiny24, attiny24a, attiny4313, attiny44, attiny44a, attiny84, attiny84a, attiny25, attiny45, attiny85, attiny261, attiny261a, attiny441, attiny461, attiny461a, attiny841, attiny861, attiny861a, attiny87, attiny43u, attiny48, attiny88, attiny828, at43usb355, at76c711, atmega103, at43usb320, attiny167, at90usb82, at90usb162, ata5505, atmega8u2, atmega16u2, atmega32u2, attiny1634, atmega8, ata6289, atmega8a, ata6285, ata6286, atmega48, atmega48a, atmega48pa, atmega48pb, atmega48p, atmega88, atmega88a, atmega88p, atmega88pa, atmega88pb, atmega8515, atmega8535, atmega8hva, at90pwm1, at90pwm2, at90pwm2b, at90pwm3, at90pwm3b, at90pwm81, ata5790, ata5795, atmega16, atmega16a, atmega161, atmega162, atmega163, atmega164a, atmega164p, atmega164pa, atmega165, atmega165a, atmega165p, atmega165pa, atmega168, atmega168a, atmega168p, atmega168pa, atmega168pb, atmega169, atmega169a, atmega169p, atmega169pa, atmega32, atmega32a, atmega323, atmega324a, atmega324p, atmega324pa, atmega324pb, atmega325, atmega325a, atmega325p, atmega325pa, atmega3250, atmega3250a, atmega3250p, atmega3250pa, atmega328, atmega328p, atmega328pb, atmega329, atmega329a, atmega329p, atmega329pa, atmega3290, atmega3290a, atmega3290p, atmega3290pa, atmega406, atmega64, atmega64a, atmega640, atmega644, atmega644a, atmega644p, atmega644pa, atmega645, atmega645a, atmega645p, atmega649, atmega649a, atmega649p, atmega6450, atmega6450a, atmega6450p, atmega6490, atmega6490a, atmega6490p, atmega64rfr2, atmega644rfr2, atmega16hva, atmega16hva2, atmega16hvb, atmega16hvbrevb, atmega32hvb, atmega32hvbrevb, atmega64hve, at90can32, at90can64, at90pwm161, at90pwm216, at90pwm316, atmega32c1, atmega64c1, atmega16m1, atmega32m1, atmega64m1, atmega16u4, atmega32u4, atmega32u6, at90usb646, at90usb647, at90scr100, at94k, m3000, atmega128, atmega128a, atmega1280, atmega1281, atmega1284, atmega1284p, atmega128rfa1, atmega128rfr2, atmega1284rfr2, at90can128, at90usb1286, at90usb1287, atmega2560, atmega2561, atmega256rfr2, atmega2564rfr2, atxmega16a4, atxmega16a4u, atxmega16c4, atxmega16d4, atxmega32a4, atxmega32a4u, atxmega32c4, atxmega32d4, atxmega32e5, atxmega16e5, atxmega8e5, atxmega32x1, atxmega64a3, atxmega64a3u, atxmega64a4u, atxmega64b1, atxmega64b3, atxmega64c3, atxmega64d3, atxmega64d4, atxmega64a1, atxmega64a1u, atxmega128a3, atxmega128a3u, atxmega128b1, atxmega128b3, atxmega128c3, atxmega128d3, atxmega128d4, atxmega192a3, atxmega192a3u, atxmega192c3, atxmega192d3, atxmega256a3, atxmega256a3u, atxmega256a3b, atxmega256a3bu, atxmega256c3, atxmega256d3, atxmega384c3, atxmega384d3, atxmega128a1, atxmega128a1u, atxmega128a4u, attiny4, attiny5, attiny9, attiny10, attiny20, attiny40, attiny102, attiny104, attiny202, attiny402, attiny204, attiny404, attiny804, attiny1604, attiny406, attiny806, attiny1606, attiny807, attiny1607, attiny212, attiny412, attiny214, attiny414, attiny814, attiny1614, attiny416, attiny816, attiny1616, attiny3216, attiny417, attiny817, attiny1617, attiny3217
E[11:37:29.057] Indexing /home/sigi/.arduino15/packages/megaTinyCore/hardware/megaavr/2.5.11/cores/megatinycore/UART.cpp failed: Couldn't build compiler instance`
So, naturally, I was curious and been wondering what the difference between a working and a non-working entry is.
So I compared
`"ATtiny3226/1626/826/426 w/Optiboot"
with the "3226" entry without optiboot (which includes the 3216 as well - Please don't make my manually type in the entry name...)`
And it seems that according to
`/tmp/arduino-language-server[YOURFREENUMBERSHERE]/compile_commands.json`
even though you select the "3226" under "Tools/Chip/" it uses "3216" in the entire params (for example "-mmcu=attiny3216").
Maybe this helps, I'm completely unfamiliar with all of this, and I find that bit very odd, so I thought I'd mention it as well.
