Ky-028 temperature sensor interface
I have connected a KY-028 digital temperature sensor for measurement of body temperature . I have interfaced but I'm not getting proper output even though I adjusted with potentiometer values. it reads the environmental temperature but when I place my hand on thermistor my value is getting decreased. what should I do? how should I rectify this issue? I need this help.
I have connected the LED for external observation.
Thank you.
Here's the code:
int led = 12; // define the LED pin
int digitalPin = 2; // KY-028 digital interface
int analogPin = A0; // KY-028 analog interface
int digitalVal; // digital readings
int v_input; //analog readings
  pinMode(led, OUTPUT);
  pinMode(digitalPin,  INPUT);
  pinMode(analogPin, INPUT);
  // Read the digital interface
  digitalVal = digitalRead(digitalPin);
  if(digitalVal == HIGH) // if temperature threshold reached
    digitalWrite(led, HIGH); // turn ON Arduino's LED
    digitalWrite(led, LOW); // turn OFF Arduino's LED
  Serial.print("Digital Value : ");
  Serial.println(digitalVal);
//   Read the analog interface
int v_input = analogRead(analogPin);//1024 VALUE
float b = 10000*(1024.0/(float)v_input-1.0);
float c    = (1.0/(0.001129148+(0.000234125*log(b)) + 0.0000000876741*log(b)*log(b)*log(b)))-273.15;
//b = b - 273.15;
//b=(b − 32.0) * 5.0/9.0;
//b = (b * 9.0)/ 5.0 + 32.0; // Convert Celcius to Fahrenheit
Serial.print("temperature in celsius :");
Serial.println(c);
delay(2000);
//Temp = log(10000.0*((1024.0/RawADC-1)));
 // Temp = 1 / (0.001129148 + (0.000234125 + (0.0000000876741 * Temp * Temp ))* Temp );
 // Temp = Temp - 273.15;            // Convert Kelvin to Celcius
   //Temp = (Temp * 9.0)/ 5.0 + 32.0; // Convert Celcius to Fahrenheit
Proof pictures:
Can anyone help me with this?
Which Arduino board do you have? How have you connected the sensor to it?
Try:
int v_input = 1023 - analogRead(analogPin);
Arduino Nano I'm using it now.
let me try and say
Not familiar with your sensor but maybe it's a negative temperature coefficient one.
In your code can you also print the raw data from the analog input pin?
Thanks.. Tom... :smiley: :+1: :coffee: :australia:
Circuit:
Code:
float temp = 125.315-0.175529*v_input-2.5;
//float b = 10000*(1024.0/(float)v_input-1.0);
//float c    = (1.0/(0.001129148+(0.000234125*log(b)) + 0.0000000876741*log(b)*log(b)*log(b)))-273.15;
//b = b - 273.15;
Serial.println(temp);
delay(2000);
Did you try what I suggested in post 3
Yes sir but it didnt work.
Can you print out the ' v_input ' value in the line after you analogRead?
So you can see what your raw input is.
Something like;
Serial.print("raw v_input :");
Serial.println(v_input);
Tom... :smiley: :+1: :coffee: :coffee: :australia:
The value is still decreasing when you put your hand on it?
as of now it is increasing but it is not showing accurately even though I calibrate it.
okay ill try
What do you meas "as of now"
How did you calibrate it?
@jim-p I connected again today . my values started increasing and i made some changes in program so that it comes with the accurate values when I checked with standard device.
What does this do?
heres the raw output:
this is the code which converts from raw voltage to Celsius (and the subtraction of -2.5 is for calibration purpose.
I cannot find any information about the thermistor used on that module, so I would just be guessing as to what the correct formula would be.
