I was using the KY 039 heart rate sensor and everything worked fine, but then it broke. Once I used another one, it only gave values 90 and 100. I tried multiple other KY 039 sensors to make sure it wasn’t the new one I got. I checked the wiring and everything is wired correctly, with the sensor hooked up to analog pin 0, ground, and 5V. I have a red led light that blinks with your heart rate on pin 8. Someone please help as soon as possible. THX!!
/// Copyright (c)2015 Dan Truong
/// Permission is granted to use this software under the MIT
/// licence, with my name and copyright kept in source code
/// http://http://opensource.org/licenses/MIT
/// KY039 Arduino Heartrate Monitor V1.0 (April 02, 2015)
/// @param[in] IRSensorPin Analog pin on which IR detector is connected
/// @param[in] delay (msec) delay between calls to this method. It is
/// best to call it at least 5 times per beat, aka
/// no slower than 150msec for 70bpm. An ideal value
/// is 60ms or faster to handle up to 200 BPM.
/// @brief
/// True if heartbeat is detected on the sensor.
/// This code is trivial and just does a peak detection, instead of
/// trying to detect the heart's pulse waveform.
/// Note: I am fudging sensor data with the delay to make the integer
/// math after that uses constants, somewhat independant of the sleep
/// delay used in the main loop. Otherwise if maxValue decays too slow
/// or too fast, it causes glitches and false beat detection.
//#define HBDEBUG(i) i
#define HBDEBUG(i)
bool heartbeatDetected(int IRSensorPin, int delay)
static int maxValue = 0;
static bool isPeak = false;
int rawValue;
bool result = false;
rawValue = analogRead(IRSensorPin);
// Separated because analogRead() may not return an int
rawValue *= (1000/delay);
HBDEBUG(Serial.print(isPeak); Serial.print("p, "));
HBDEBUG(Serial.print(rawValue); Serial.print("r, "));
HBDEBUG(Serial.print(maxValue); Serial.print("m, "));
// If sensor shifts, then max is out of whack.
// Just reset max to a new baseline.
if (rawValue * 4L < maxValue) {
maxValue = rawValue * 0.8;
HBDEBUG(Serial.print("RESET, "));
// Detect new peak
if (rawValue > maxValue - (1000/delay)) {
// Only change peak if we find a higher one.
if (rawValue > maxValue) {
maxValue = rawValue;
// Only return true once per peak.
if (isPeak == false) {
result = true;
HBDEBUG(Serial.print(result); Serial.print(", *"));
isPeak = true;
} else if (rawValue < maxValue - (3000/delay)) {
isPeak = false;
// Decay max value to adjust to sensor shifting
// Note that it may take a few seconds to re-detect
// the signal when sensor is pushed on meatier part
// of the finger. Another way would be to track how
// long since last beat, and if over 1sec, reset
// maxValue, or to use derivatives to remove DC bias.
maxValue-=(1000/delay);
HBDEBUG(Serial.print("\n"));
return result;
// Arduino main code
int ledPin=8;
int analogPin=0;
// Built-in arduino board pin for the display LED
pinMode(ledPin,OUTPUT);
// Init serial console
Serial.println("Heartbeat detection sample code.");
const int delayMsec = 60; // 100msec per sample
// The main loop blips the LED and computes BPMs on serial port.
static int beatMsec = 0;
int heartRateBPM = 0;
if (heartbeatDetected(analogPin, delayMsec)) {
heartRateBPM = 60000 / beatMsec;
digitalWrite(ledPin,1);
// Print msec/beat and instantaneous heart rate in BPM
Serial.print(beatMsec);
Serial.print(", ");
Serial.println(heartRateBPM);
beatMsec = 0;
digitalWrite(ledPin,0);
// Note: I assume the sleep delay is way longer than the
// number of cycles used to run the code hence the error
// is negligible for math.
delay(delayMsec);
beatMsec += delayMsec;
