I want to control 4 solenoid valve (24vDC) with a L298N 4 channel MOTOR DRIVER.
Can anyone help me in wiring and its related code?
i have done it similar to a 2 channel one, but it does not work (it does not supply 24v to its outputs).
Is that really - and + 24V going in ?
What voltage, if any, do you get out ?
Why are the inputs labelled PWM 3 and PWM 2 when you are using digital pins ?
Are the ENA and ENB inputs enable pins as their name suggests and if so are they active HIGH or LOW ?
1- yes. it is exactly 24v. i have a power supply.
2- 24v. it does not supply to out 7 and 8.
3- sorry. i write wrong. they are digital pins.
4- ENA , ENB are enable pins. they are high by default with jumper. and i dont write in code
1- oh. excuse me. the arrows of + - 24 vDC is reverse. i am sorry.
2- i dont see 24 volt any where. i want to see it between out 7 and 8 but it shows 0.
Hi, @rashad_rhl
Welcome to the forum.
Why do you want to control valve solenoids with a motor controller.
Do you need to apply current in one direction to open and the other to close?
If not then just a MOSFET for each valve could have done the job instead of a module that is not very efficient.
plus and minus must always be in relation to something, you can't have a plus voltage unless you have something to measure it against. So, when you have plus 24V and minus 24V the difference between them could actually be 48V
I never thought for minute that is what your labels meant but there were other obvious things wrong so this could have been too, hence me asking
