I am experiencing an issue with the l298n motor driver board.I have a arduino controlling the l298n motor driver board.Even I set the same instruction to both the motors,they spin at different rpm :o .I am not able to find where the problem lies(arduino or the motor driver).I have a 10v power supply powering the board.Any help will be appreciatedThe code i am using is:
/* L298N_Dual_H_Bridge
This program controls 2 separate DC motors using the L298N
H Bridge Chip.
*THE SUBROUTINES WORK AS FOLLOWS*
motorA(mode, speed)
% replace A with B to control motor B %
mode is a number 0 -> 3 that determines what the motor
will do.
0 = coast/disable the H bridge
1 = turn motor clockwise
2 = turn motor counter clockwise
3 = brake motor
speed is a number 0 -> 100 that represents percentage of
motor speed.
0 = off
50 = 50% of full motor speed
100 = 100% of full motor speed
EXAMPLE
Say you need to have motor A turn clockwise at 33% of its
full speed. The subroutine call would be the following...
motorA(1, 33);
Created by
Iain Portalupi http://www.youtube.com/iainportalupi
1/2/2014
This code is in the public domain.
#define ENA 5 //enable A on pin 5 (needs to be a pwm pin)
#define ENB 3 //enable B on pin 3 (needs to be a pwm pin)
#define IN1 2 //IN1 on pin 2 conrtols one side of bridge A
#define IN2 4 //IN2 on pin 4 controls other side of A
#define IN3 6 //IN3 on pin 6 conrtols one side of bridge B
#define IN4 7 //IN4 on pin 7 controls other side of B
int sensor = 0;
//set all of the outputs
pinMode(ENA, OUTPUT);
pinMode(ENB, OUTPUT);
pinMode(IN1, OUTPUT);
pinMode(IN2, OUTPUT);
pinMode(IN3, OUTPUT);
pinMode(IN4, OUTPUT);
motorA(1,30);
motorB(1,30);
delay(5000);
motorA(1,70);
motorB(1,70);
delay(5000);
//****************** Motor A control *******************
void motorA(int mode, int percent)
//change the percentage range of 0 -> 100 into the PWM
//range of 0 -> 255 using the map function
int duty = map(percent, 0, 100, 0, 255);
switch(mode)
case 0: //disable/coast
digitalWrite(ENA, LOW); //set enable low to disable A
case 1: //turn clockwise
//setting IN1 high connects motor lead 1 to +voltage
digitalWrite(IN1, HIGH);
//setting IN2 low connects motor lead 2 to ground
digitalWrite(IN2, LOW);
//use pwm to control motor speed through enable pin
analogWrite(ENA, duty);
case 2: //turn counter-clockwise
//setting IN1 low connects motor lead 1 to ground
digitalWrite(IN1, LOW);
//setting IN2 high connects motor lead 2 to +voltage
digitalWrite(IN2, HIGH);
case 3: //brake motor
//setting IN2 high connects motor lead 2 to ground
//use pwm to control motor braking power
//through enable pin
//****************** Motor B control *******************
void motorB(int mode, int percent)
switch(mode)
digitalWrite(ENB, LOW); //set enable low to disable B
//setting IN3 high connects motor lead 1 to +voltage
digitalWrite(IN3, HIGH);
//setting IN4 low connects motor lead 2 to ground
digitalWrite(IN4, LOW);
analogWrite(ENB, duty);
//setting IN3 low connects motor lead 1 to ground
digitalWrite(IN3, LOW);
//setting IN4 high connects motor lead 2 to +voltage
digitalWrite(IN4, HIGH);
//setting IN4 high connects motor lead 2 to ground
