I need to make visible laser beam and detector for crossing this laser (like in spy movies :).
Can I use laser like this Laser Module - Green - COM-09906 - SparkFun Electronics and simple photoresistor connected to arduino?
Distance between photoresistor and laser will be around 5 meters.
You might want to look at the below kit.
http://www.ramseyelectronics.com/cgi-bin/commerce.exe?preadd=action&key=LTS1
Be advised, that laser (dispute what they show in movies) usually is not visible in clear air, untill it hits some substance which make it disperse around (smoke , fog, dust). Photoresistor approach should works, only you'd need create high pass filtering in software to make it reliable in different lighting conditions.
