Laser harp
So i'm somewhat new to arduino and i'm building a laser harp for my brother's birthday. I found a code that works for nine lasers, but i bought a ten pack and i'd like to use either all ten or only use six for a laser guitar. either way, i need help altering the provided code so that i can adjust the number of lasers. thanks.
laser_harp.ino (4.17 KB)
Why not just post the code?
this code had 7 notes, 1 octave up, 1 octave down. i'm looking for 10 notes, no octave adjustment
MIDI-enabled Laser Harp
SOURCE: http://open-source-energy.org/?topic=1129.0
See: MIDI Technical Specifications
#define MIDI_LASER_COUNT 9
#define MIDI_LASER_OCTAVE_DOWN 0
#define MIDI_LASER_OCTAVE_UP 8
short midiCalibrateAmbientLight = 1023;
boolean midiLaserState[MIDI_LASER_COUNT] = {false, false, false, false, false, false, false, false, false};
byte midiNotes[MIDI_LASER_COUNT] = {0, 0, 2, 4, 5, 7, 9, 11, 0};
byte midiOctave = 5;
byte midiPinLaser[MIDI_LASER_COUNT] = {3, 4, 5, 6, 7, 8, 9, 10, 11};
byte midiPinVelocity = A0;
unsigned long midiRateLimit[MIDI_LASER_COUNT] = {0, 0, 0, 0, 0, 0, 0, 0, 0};
unsigned long midiRateLimitThreshold = 35;
unsigned long midiRateLimitThresholdOctave = 70;
byte midiVelocity = 127;
calibrateAmbientLight();
midiInitSerial();
midiInitPins();
midiIntroSong();
midiReadLasers();
midiReadVelocity();
void calibrateAmbientLight() {
delay(100);
midiCalibrateAmbientLight = analogRead(midiPinVelocity);
void midiIntroSong() {
delay(1);
midiSendNoteOn(60, 127);
delay(125);
midiSendNoteOff(60);
midiSendNoteOn(64, 127);
delay(125);
midiSendNoteOff(64);
midiSendNoteOn(67, 127);
delay(125);
midiSendNoteOff(67);
midiSendNoteOn(72, 127);
delay(250);
midiSendNoteOff(72);
delay(125);
boolean midiHandleOctave(byte thePin, boolean theState) {
if (!theState) {return false;}
if ((thePin == MIDI_LASER_OCTAVE_DOWN) && midiOctave == 0) {return false;}
if ((thePin == MIDI_LASER_OCTAVE_UP) && midiOctave == 9) {return false;}
midiOctaveKill();
switch(thePin) {
case MIDI_LASER_OCTAVE_DOWN:
midiOctave--;
case MIDI_LASER_OCTAVE_UP:
midiOctave++;
return true;
boolean midiHandleRateLimit(byte thePin) {
unsigned long theMillis = millis();
unsigned long theThreshold = 0;
switch (thePin) {
theThreshold = midiRateLimitThresholdOctave;
default:
theThreshold = midiRateLimitThreshold;
if (theMillis - midiRateLimit[thePin] >= theThreshold) {
midiRateLimit[thePin] = theMillis;
return true;
return false;
void midiHandleReadLaser(byte thePin, boolean theState) {
if ((midiLaserState[thePin] != theState) && midiHandleRateLimit(thePin)) {
midiLaserState[thePin] = theState;
if ((thePin == MIDI_LASER_OCTAVE_DOWN) || (thePin == MIDI_LASER_OCTAVE_UP)) {
midiHandleOctave(thePin, theState);
} else if (theState) {
midiSendNoteOn(midiNotes[thePin] + (12 *midiOctave), midiVelocity);
midiSendNoteOff(midiNotes[thePin] + (12 *midiOctave));
void midiInitPins() {
for (byte thePin = 0; thePin < MIDI_LASER_COUNT; thePin++) {
pinMode(midiPinLaser[thePin], INPUT);
void midiInitSerial() {
Serial.begin(31250);
void midiOctaveKill() {
if ((thePin == MIDI_LASER_OCTAVE_DOWN) || (thePin == MIDI_LASER_OCTAVE_UP)) {continue;}
midiHandleReadLaser(thePin, LOW);
void midiReadLasers() {
midiHandleReadLaser(thePin, digitalRead(midiPinLaser[thePin]));
void midiReadVelocity() {
midiVelocity = map(analogRead(midiPinVelocity), 0, midiCalibrateAmbientLight, 1, 127);
void midiSendCC(byte theCC, byte theValue) {
Serial.write(B10110000);
Serial.write(theCC);
Serial.write(theValue);
void midiSendNoteOff(byte theNote) {
Serial.write(B10000000);
Serial.write(theNote);
Serial.write(0);
delay(1);
void midiSendNoteOn(byte theNote, byte theVelocity) {
Serial.write(B10010000);
Serial.write(theVelocity);
delay(1);
Do you have the existing code working in hardware? That's where I'd start.
the existing code works, i just need to get rid of the octave changes and add a 10th laser.
Well, that part is trivial.
Actually, you need to add 3 more lasers to the non-octave-changers list. Have you tried just making that array larger, and adding the extra pin numbers to it?
