I bought PLR 15 and going to solder wires to debug pins.
I need to know how to connect it to computer for checking commands codes.
I don't understand this:
"I think, it is a command to pin 7 needed, to start the communication. Caution RX and TX are working together on the same debug pin no. 7."
is it possible to connect it via FT232RL FTDI USB to TTL Serial Adapter like this:
I'm using it for connect Arduino Mini to my laptop and send/receive commands to COM port.
I am unfamiliar with the device you are using but the rs232 protocol uses both negative and positive voltages , this would be unsuitable.
Check the device no on the chip and look it up.
But how did you connect your PLR15 to COM port?
You said that
Send to debug pin 7 with 9600 baud, 8 data, 1 stop, no parity a command higher or equal than C0h. The response is always the same after 60ms with 3 bytes: 01h 00h FAh. And the laser go never in the power on state. Only the LCD backlight is on. Anyone have a good idea for the communication?
Or it is not you?
I would also connect it and send some commands.
But I need first connect it, but don't know how.
Another possibility.
I tried the prigonal 390B but was shipped the 390B+ instead which has the hacking port removed.
I would not be surprised if other vendors have likewise made modifications to make hacking harder.
Those that hacked the 390 got lucky i think.
If that is a debug port it will not necessarily give useful information and it is possible to brick the unit.
Best to look for I2C or similar interface between the display and processor. IF it exists.
If you could align two lasers parallel to put 2 dots of light on a target, the apparent distance between those 2 spots could give you a good idea of range.
But if the light reflected made an interference pattern, the distance between the nodes might tell more.
What can I say? Back in 73 when we did the double-slit using lightbulb light through red filter for source light we knew the distance and calculated the wavelength by holding a meter stick and judging the distance of the red nodes that appeared in front of us. And it worked. So knowing the wavelength we could get distance at probably twice as far or more.
