LCD CHARACTERS millis() PROBLEM !!!
Hello. I have a problem with my code.I have a lcd and I want to blink a character every 0.5 seconds BUT I don't want to use delay.I want to use MILLIS function.Everything is ok ,but many times the character lag about 0.5-1 second MORE than 0.5 seconds.I don't know if the problem is in the code or not ,but I want your help!!!
Then,I would like to know if exists another way...
CODE:
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
unsigned long previousMillis = 0;
bool real = true;
byte A[8] =
B11111,
B11111,
B11111,
B11111,
B11111,
B11111,
B11111,
B11111
lcd.begin(20, 4);
void characters_for_AI()
lcd.createChar(0, A);
lcd.setCursor(5, 3);
lcd.write(byte(0));
lcd.setCursor(6, 2);
lcd.write(byte(0));
lcd.setCursor(7, 1);
lcd.write(byte(0));
lcd.setCursor(8, 0);
lcd.write(byte(0));
lcd.setCursor(9, 0);
lcd.write(byte(0));
lcd.setCursor(10, 1);
lcd.write(byte(0));
lcd.setCursor(11, 2);
lcd.write(byte(0));
lcd.setCursor(12, 3);
lcd.write(byte(0));
lcd.setCursor(7, 2);
lcd.write(byte(0));
lcd.setCursor(8, 2);
lcd.write(byte(0));
lcd.setCursor(9, 2);
lcd.write(byte(0));
lcd.setCursor(10, 2);
lcd.write(byte(0));
lcd.setCursor(15, 0);
lcd.write(byte(0));
lcd.setCursor(15, 1);
lcd.write(byte(0));
lcd.setCursor(15, 2);
lcd.write(byte(0));
lcd.setCursor(15, 3);
lcd.write(byte(0));
void function()
if (currentMillis - previousMillis >= 500)
if (real)
characters_for_AI();
lcd.clear();
real = !real;
function();
SOLVED
What was the problem?
Repetive calling of lcd.createChar()?
No .I should have put the command (real = !real;) a position over...
Of course....
Suggestion:
Create the custom character only once in "characters_for_AI()" as it doesn't change.
Call "characters_for_AI()" in "setup()" and use "display/noDisplay" for blinking the display (without loosing its contents).
Writing to the display may be relative slow, and this would save some time for other tasks.
(untested)
void function()
    if (real)
      lcd.display();
      lcd.noDisplay();
    real = !real;
When you skip character zero, and start with 1, then you can use a zero-terminated string with the lcd.print().
lcd.print("\1\1\1\1");
The \1 is the octal notation. You may use \x01 as well.
