I’m having trouble with my project. I use ACS712 and NodeMCU ESP8266 for my project, but how do I make the 16x2 LCD display LOAD OFF when the AC Power is below 10 Watts, and LOAD ON when the Power is above 10 Watt. thank you
here is my code.
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27, 16, 2);
const int sensorIn = A0;
int mVperAmp = 66;
int Watt = 0;
double Voltage = 0;
double VRMS = 0;
double AmpsRMS = 0;
Serial.begin (9600);
Serial.println (“ACS712 current sensor”);
lcd.begin();
lcd.backlight();
lcd.print(“Robojax ACS712”);
lcd.setCursor(0,1);
lcd.print(“Demo”);
delay(2000);
Serial.println ("");
Voltage = getVPP();
VRMS = (Voltage/2.0) *0.707;
AmpsRMS = (VRMS * 1000)/mVperAmp;
Serial.print(AmpsRMS);
Serial.print(" Amps RMS — “);
Watt = (AmpsRMS*240/1.3);
Serial.print(Watt);
Serial.println(” W");
lcd.clear();
lcd.setCursor (0,0);
lcd.print("PLN ON: ");
lcd.print(Watt);
lcd.print(“W”);
float getVPP()
float result;
int readValue;
int maxValue = 0;
int minValue = 1024;
int LIMIT = 10;
uint32_t start_time = millis();
while((millis()-start_time) < 1000)
readValue = analogRead(sensorIn);
if (readValue > maxValue)
maxValue = readValue;
if (readValue < minValue)
minValue = readValue;
result = ((maxValue - minValue) * 5.0)/1024.0;
return result;
void lcd_control (){
lcd. setCursor (0, 1);
lcd.print (Watt);
lcd.print (" watt ");
delay (100);
